Question about Kitchen Appliances - Others
Maximum time inbetween hours forced to work on 2 shifts
  • 2,113 Answers
Make yoghurt the Lebanese way... Unpasturized milk in a large pot. Bring it to near a boil then turn it off and let it sit all night.
Posted on Nov 25, 2013
Just wondering what is: P1811 Maximum Adapt And Long Shift
P1811
The transmission pressure is modified by an adaptive modifier which controls the shift execution time. This diagnostic tests the time required to accomplish the shift. If the shift takes longer than 0.65 seconds and the adaptive modifier cannot shorten this time, then a counter increases by one.
If the PCM detects a counter value of 2 during one trip, then DTC P1811 sets. DTC P1811 is a type C DTC
The 1-2, 2-3 or 3-4 shift is longer than 0.65 seconds, twice in one trip.
Ask the customer about possible overloading, exceeding the trailer towing limit, or towing in overdrive.
Ensure that the current PCM calibration is correct for the final drive ratio.
  1. Use the scan tool snapshot mode in order to record the shift times.
  2. Drive the vehicle in D4 in order to obtain a 1-2, 2-3 and 3-4 upshift.
  3. Record the shift times.
Did all the shift times exceed the specified value?
0.65 seconds
Perform the Line Pressure Check Procedure.
Refer to the Line Pressure Check .
Is the line pressure within specifications?
Go to Diagnostic Aids
You may want to take this to the dealer !
Apr 20, 2015 | 2003 Chevrolet Impala
HOW MAN HOURS BREAK IN CALIFORNIA AFTER 8 HOUR SHIFT?
Employees must, with two exceptions, receive at least eight hours free from work between shifts, whether they are "split shifts," "on call shifts," "back-to-back" shifts or ordinary daily shifts.
Rest between shifts is not required if:
  • the total time worked during both shifts does not exceed 13 hours; or
  • the employer and employee agree in writing to reduce or forego the eight-hour rest period.
Example
Monica works in a restaurant. She is on split shifts, working from 11:30 am to 2:30 pm and then from 4:00 pm to 7:00 pm. The total time of her two shifts is 6 hours. Monica does not need to have eight hours off between the shifts because her total hours worked on the shifts do not exceed 13 hours.
Note: The requirement for rest between shifts operates simultaneously with the requirement for daily rest; an employee's schedule must satisfy both requirements. For example, an employee might agree in writing to work two eight-hour shifts in a row without any time free from work between them (the employee's agreement means there is no violation of the rest between shifts rule), but if that results in the employee receiving less than 11 consecutive hours off in a day, the employer will be in violation of the daily rest rule* and therefore it is not permitted.
* Unlike the case with the rest between shifts requirement, an employee cannot agree to waive the daily rest requirement.
Oct 13, 2014 | Cars & Trucks
1990 f-150 wont shift in to 1st gear, I can force it. just started doing this
The 1-2 shift synchro is worn . A transmission overhaul is in order.
Sep 25, 2014 | Cars & Trucks
Car dies while driving wont start replaced fuel pump and filter twice still having same problem
i would check to see if your loosing spark not fuel when this happens
Jun 29, 2012 | 1995 Ford Explorer
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
TO SET ALARM
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
TO CANCEL ALARM
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
TO SET HOURLY NOTIFICATION OFF AND ON
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
My Lg refrigerator is not working after shifting the home. i started it after 24 hours from shifting then one night it ran properly but next day morning it was totally dead. At the time of shifting i...
Here is a tip that I wrote on moving refrigerators...if you did not do it thisway then you may well have ruined a perfectly good refrigerator.
Moving a Refrigerator What is thebest way
If you already have moved it wrong, you can sometimes get it working byplugging it in and unplugging it a number of times with an hour or so inbetween.
heatman101
Jun 08, 2011 | Refrigerators
Transmission does not shift in the third and fourth gear
Well could be a couple of different things wrong.
If it is an automatic transmission could be the pressure solenoids in the transmission. or some thing is broken in the gears.
If it is a standard it could be the synchro gears inbetween that let you shift into the next gear.
Needless to say unless you are a transmission mechanic, take it to the transmission professionals and they will tell u if it can be fixed or depending on the hours for labor, or if u really need your car, you can have a rebuilt transmission installed in about 2 days. Rebuilding yours could take up to a week depending on the experience of the mechanic. I have worked on standard transmissions but I wouldnt even try an automatic.
I had a rebuilt automatic put into my chev pickup in under a weekend for 1300 bucks, but I had a shift kit installed as well while I waited lol.
hope it helps
D
Jan 06, 2011 | 1995 Chevrolet Monte Carlo
No manual for my old Crock Watcher by Proctor Silex
The auto setting cooks on high for the first hour, then adjusts the setting to low for the remaining cooking time.
Auto Shift allows the slow cooker to heat up to high and then internally shift down to low, so it gives more flexibility in cooking time. Example: A certain recipe may take 4 hours on high, 5-6 hours on Auto Shift and 7-8 hours on Low.
Oct 19, 2009 | Crock Pots & Slow Cookers
Maximum hours of gaming
slim type ps2 don't have a cooling fan the maximum game play time is probably around 2-3 hours then a 1 hour rest.
Oct 19, 2007 | Sony PlayStation 2 (PS2) Console
Kitchen Appliances - Others Logo
265 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
