Question about Kohler Plumbing
Kohler 77809-AA leaking at base, where the fixture meets the sink top. I can't figure out how to get the base unit off.
sledge1863
  • 149 Answers
SOURCE: leak at spout pivot point on Kohler K-378 traditional kitchen fau
Not going to stop the leak by tightening. Go to local plumbing or home store and they make a repair kit that has the pieces to fix your problem. Also has a diagram on the back of the kit to guide you, its really an easy fix, shut off water under the sink, both hot and cold,and just remove the handle and unscrewing the top of the valve assembly. Good luck dont forget to rate.
Posted on Mar 30, 2009
carfreakt
  • 68 Answers
SOURCE: my faucet leaks at the base where it meets the
replace the faucet if thighting the fittings does not work
Posted on Oct 05, 2009
  • 25 Answers
SOURCE: My Kohler bathtub hot water faucet 77809-AA needs
My husband is a plumber. He says u need to pull it off with pliers. U need to just pull it off. It may take a couple tries, but it should come out.
Posted on Jan 04, 2010
FixinFax
  • 3085 Answers
SOURCE: Water is seeping from the base of the unit into
That's correct, you have a bad rubber o-ring at the base. Take it to Home Depot or Lowe's and match it up
Posted on May 15, 2010
snowghost1
  • 784 Answers
SOURCE: My faucet leaks where the base of the spout meets
the problem is most likely a bad seal or O-ring. turn off water under the sink, remove the handle from the unit and the remove cartridge from inside the faucet and examine the seals. if you need to replace the cartridge then replace it. but before you do - try and tighten the cartridge body down into the unit and see if that will stop the leak. don't tighten to tight though as this could make the function hard to turn or damage the unit.
if you need to buy a new cartridge - take the old one down to your local hardware store or a plumbing supply store and match it up to a new one. the cost is about 25 dollars ( depending on where you live ).
if you need further help -- please feel free to write me back here and I will do my best to walk you through the steps needed.
c...
Posted on Feb 11, 2011
Kohler soap dispenser leaks onto counter
Your dispenser nut is either not tightened down underneath or your plastic base/o-ring needs to be replaced. Turn off water at value. Using sink nut removal & installation tool that is available at any Lowe's or Home Depot. Remove it and look at what is wrong. Conntact Kohler for free parts to repair it. Reinstall dispenser .
Mar 01, 2014 | Kohler Home
I have a kohler 77809-aa shower tub. The drain is clogged. How do you remove the drain. I see no set screws. But I do see a couple of pins near the top of the drain cap.
If you want to clear your clogged drain you do not need to take the drain cap off. First you need to remove the over flow plate, it's located right below the faucet and has two screws, then you need to hand snake the drain line from there.
May 30, 2012 | Kohler Forte Single-Control Remote Valve...
Faucet leaks
not much can be done to repair it
you can try a new unit and ask for a warranty refund on the one you have
Jul 14, 2017 | Kohler Plumbing
My Kohler bathtub hot water faucet 77809-AA needs to be repaired and I can't get it off. I took the cap off and took the screw out, but it won't budge from there
Dec 22, 2009 | Kohler Plumbing
Trying to find basket strainer for Kohler vast
all of kohlers baskets fit their sinks, even older model sinks.
do you have a special strainer, or sink?
have you contacted Kohler direct? or one of their distributors. a wholesale plumbing supply house (NOT lowes or home depot) in your area will be able to help you also
Oct 15, 2009 | Kohler Plumbing
Kitchen faucet
look under your sink there will be a big nut screw it up toward the counter top this will fix your problem also may want to look into getting a prv for your house this will lower your water pressur in your house
Mar 13, 2009 | Kohler Forte entertainment remote valve...
Leaking kohler faucet
Where the spout pivots on the main body, there are a couple of washers, you can replace these washers pretty easily by removing the handle and then the "cover" from the unit. The water has to be shut off before you do this. I would take this oppurtunity to replace all the washers.
Mar 08, 2009 | Kohler K-15176-PT-7 Coralais...
Plumbing Logo
313 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
