Question about NEC DTR-8D-1 Phone DTR-8D-1BK 780039
Trying to get headset to work - no hset listed in LCD
Would a t8 micro bluetooth device work on a ps3?
Dear,
There is a list of (most) compatible bluetooth devices on Wikipedia (here) that work with a PS3 and since your device is not listed, I wont hope on a positive result. Sorry. But no-one stops you from trying !
Sincerly
Jan 05, 2011 | Blueant T8 micro Wireless Headset
I purchased the Jabra BT2035 Bluetooth Headset from a long time.... The first time I tried to connect, it connected easily with the passkey or passcode - 0000. One time, I accidentally deleted the...
you need to intorduce again the jabra blutooth to your device. deleting jabra from the list make it forget the connection.
set your jabra to find mode by pressing the poer button for more than 5 seconds wait to blink, and find it using your device. it will again ask for a passcode and it will connect afterward.
Nov 10, 2010 | Jabra BT2050 Bluetooth Headset
Can someone tell me step by step, where is the microphone located on the Hanspree 20" flat panel LCD monitor? I can't find any info in the manual on this. I go on to Skype and my speakers work but not the...
Hannspree says they don't offer a 19" LCD with a built-in microphone. If there is one, I can't suggest you use it as noone would be able to understand you well.Their built-in speakers,also, are notorious for low power and poor, tinny sound. the addition of a USB or audio card compatible type headset is recommended for most voice applications, including Skype. Tigerdirect.com, overstock.com or walmart.com all have inexpensive headsets and stand alone mikes. Hope this helps some:)
Aug 20, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
How can i cannnect bluetooth headset with htc p3400i
1. Power on both your Bluetooth headset and your phone, and place them close together on a table.
2. Go into the "Settings" menu on your phone and make sure you have Bluetooth powered on.
3. In the settings menu, select "Discover New Devices." Your phone will now search for Bluetooth devices located around it and find your headset.
4. Select your headset from the list of devices that might show up, as your phone will list all Bluetooth compatible devices around it.
5. Enter in the pairing code that was included with your headset (printed on the headset manual or on the device itself) into your phone when prompted. You may find the pairing code on a sticker attached to the headset, or written in the instruction book for your headset.
6. Exit out of the settings menu and try using your new headset. If the headset does not work, go through the steps again to make sure you entered the code correctly.
Oct 21, 2009 | HP Lands Phones
Clearchat Stereo Headset's mic not working.
go to device manager and check for enumeration under the sound,video and game controllers. if the headset is listed it should work. if not or there is an unknown device. try on another pc. if the same happens call logitech.
Jun 01, 2009 | Logitech ClearChat Stereo Headset Headset
Headphone socket won't work
ur connection are wrong i thin
please chek ur owners manual for right ones
May 18, 2008 | Hitachi 37LD6600 37 in. LCD Television
Nokia N95 MADE IN CHINA
hye ina sy sham.i pun pnh pkai hset tu.ok je.tp klau ina nk beli hset tu pd harga rm600 rasanye terlalu mahal.klau ina nak saya leh cari.harganya skitar rm450 je.ina leh email kat sy. sham02777@yahoo.com.
Apr 16, 2008 | Nokia N95 Cellular Phone
Headset problem with Uniden 1558
Determine if this is a VOX problem or a headset problem.
Turn off the VOX. Does the headset work for normal transmit and receive?
Remove the headsets. Do the radios work normally on speaker?
Plug one headset in And test with the (other) radio in speaker mode. Does it work? Now turn on VOX in this mode (yes it will work this way). Does vox work (put you mouth right on the mic)
If so swap headsets and try the other.
If one Hset works but not the other its the headset. If neither works its likely the radio ..but before you decide try the same headset experiment on the other radio. Find out which of the 4 devices the problem follows.
Happy New year
Dec 24, 2007 | Uniden GMR-1558 / 2CK 2-Way Radio
Logitech headset usb A-0356A
Ok, here is what might help, goto control panel, sound and audio devices,then audio. click the pop down list and see if it is there, that is how i got my plug and play to work on my 250....
Nov 13, 2007 | Logitech 250 Headset
Screen light is not working
I no expert, but did you try to put the phone in a ziplock bag of uncooked rice for a day to draw out the moisture from the phone?
Nov 27, 2006 | Nokia 6600
NEC DTR-8D-1 Phone DTR-8D-1BK 780039 Logo
14 people viewed this question
Top NEC Radio Communications Experts
Mister Danger
David Payne
David Payne
Are you a NEC Radio Communication Expert? Answer questions, earn points and help others
