Question about camfuze.com
Cameras in camfuze will not load without flash player 11.9
Camefuze.com requires flash player 11.9. but I have a non intel mac running flash player 11.1. how can I solve this problem?
I cant play you tube, cause IT SAYS blocked-plug-ins
its an issue with macromedia flashplayer right now. you will have to permit it to use the plugin until there is a fix out. or be without sites that uses flash player until the fix/update is out (day or two i would guess)
Dec 13, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Tip
Sony HDR-SR10E,Share Sony HDR-SR10E MTS to FLV for Mac Users Do you have some...
Do you have some short films shot with Sony HDR-SR10E AVCHD camcorder, and want to share them on your website? It will make your site more attractive with videos. While Apple compete with Adobe, the Flash support on Apple devices like iMac, MacBook Pro do not support exporting to Flash FLV/SWF now. You can not directly export FLV from the Apple QuickTime Player, iMovie or Final Cut Pro/Final Cut Express.
One solution is to upload videos to YouTube and embed YouTube videos on your site. If you do not want to embed YouTube videos, you can convert Sony HDR-SR10E MTS files to FLV with Mac Sony MTS converter, and put the FLV videos on web server with Flash player. Aunsoft MTS/M2TS Converter for Mac is the recommended Mac Sony HDR-SR10E MTS converter for you. It exports Flash videos with automatic deinterlacing function, which makes the FLV videos play without interlacing artifacts. It could also help you merge several Sony .mts video clips and export as one file.
Here is the step-by-step guide to convert Sony HDR-SR10 videos to Flash on Mac.
Step 1. Load Sony HDR-SR10E videos to Aunsoft MTS/M2TS Converter for Mac.
Run Aunsoft MTS/M2TS Converter for Mac as the Mac Sony HDR-SR10 converter, and click the "Add" button to load .mts files for conversion.
Step 2. Choose Flash FLV output format.
Click the "Format" option, and choose Flash Video > FLV-Flash Video Format(*.flv) as output format. You can also choose the profiles like FLV H.264(*.flv) or F4V(/f4v).
Tips:
With The above mentioned output, you shall use Flash player like JW player, Moyea PlayerBox player, or Flow player to play the Flash videos. If you want the video to play automatically, you may choose SWF-SWF Forma(*.flv) as output.
Step 3. Transcode Sony HDR-SR10 MTS to Flash.
Click the "Convert" button under the preview window, and the conversion from Sony MTS to Flash video FLV/SWF will start right away.
Wait for a while, and you can upload the Flash videos to your sever and embed them on your web page.
PS:
1. The "Merge into one file" on the main interface is to join/splice .mts files.
2. If you are using camcorders like Sony HDR-CX350, HDR-XR520, HDR-TG7, or Cyber-shot DSC-TX7, DSC-H5V, you can also use the Mac Sony MTS converter to export FLV files for web sharing. Aunsoft MTS/M2TS Converter for Mac also works with Canon HF S21, Canon HF100, Panasonic HDC-TM700 and other AVCHD camcorders.
on Jul 22, 2010 | Cameras
New to G4 - how do l install flash player as it keeps telling me not compatiable when l go to install?
depends on your OSX version - you need an older version of flash player for your system, (ver. 10.1.102.64 for Power PC G4)
check here:
Archived Flash Player versions
Most recent version of Flash Player supported Operating system Flash Player Download Center
  • Mac OS X 10.6+ (Intel processor)
Flash Player 10.1.102.64
  • Mac OS X 10.4+ (Power PC processor)
Flash Player 10.3.183.90
  • Mac OS X 10.5
Flash Player 9
  • Mac OS X 10.1-10.3
Flash Player 7
  • Mac Classic
  • (9 and earlier)
http://fpdownload.macromedia.com/get/flashplayer/installers/archive/fp_10.1.102.64_and_9.0.289.0_archive.zip Flash Player Help
Feb 11, 2014 | Computers & Internet
Moviestarplanet wont load the login on any of the ibook g4 can u help me slolc=ve this?
Movie Star Planet requires Flash version 11. Adobe discontinued support for PowerPC Macs with version 10.1.
Dec 26, 2013 | Apple iBook G4 Mac Notebook
Cannot get camfuze picture
get home page ok but clicking a cam gets you a blank area where the cam should be?...
start - control panel - flash player - advanced tab -
'delete all' button (browsing data and settings)
worked for me
Aug 16, 2013 | camfuze.com
Cannot load cams
worked for me
Aug 13, 2013 | camfuze.com
I cannot open youtube video
no only get the latest flash. you have to open it and run it or install it. sometimes people downloads files but do not install them. let me know.
Dec 14, 2012 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I can down the camfuze home page but when I open a cam the webcam doesn't come up with the page
home page was ok but clicking a cam gave a blank cam area... didn't even look like it was trying to connect...
windows 7 - start - control panel - flash player
advanced tab - delete all (browsing data and settings)
don't know what settings i had but cams work now
May 23, 2012 | camfuze.com
Can't connect to adobe.com
it probably was added on a non access list on the antivirus or on a blocking tool in the browser..My advice is to take a look in the firewall (under exceptions and click the case if it is not ticked ) ..than look in the antivirus options for blocked sites...and for the browser...just uninstall it ..and reinstall without preserving the settings ..This way you will unlock it ..
There is the possibility that you have it blocked cause it used to prompt you with the flash player ..and now its on the black list ..
Nov 29, 2011 | Apple MacBook Pro Laptop Computer with...
Loading video from Vixia F100 to Mac computer
Mac writes there own software from what I know so you have to rely on them....with imovie 08 version 7.1.4 or higher on an intel based mac ( not power pc g4 or g5 but INTEL) you can use itif you have 10.4.11 what's the processor?? and what version of imovie or final cut are you trying to use and make sure the card is in the camcorder not a card reader
Jan 06, 2009 | Canon VIXIA HF100 Flash Media Camcorder
camfuze.com Logo
147 people viewed this question
Top camfuze.com Computers & Internet Experts
David Payne
David Payne
Are you a camfuze.com Computer and Internet Expert? Answer questions, earn points and help others
