Question about Zebra Symbol MC3190G Handheld Mobile Computer
Risk eletric shock dry location revenda em recife.pe
Dryer smelling like eletrical burning and not working properly
if dont have warranty to be on safe side i junk it. usally to risk to fix thoes things
Dec 29, 2012 | Maytag Dryers
Dryer stop working then start shocking you when touch
The first thing you need to do is turn the breaker off to the dryer , that way you don't risk shock trying to unplug it. The next step is to locate where the wire is arcing over, I would start at where the plug comes into the dryer and move on from there. Thats a very dangerous situation, be careful and good luck
May 27, 2012 | Whirlpool Dryers
Less than 2 years old; fan still runs, but no water being removed. Pan is totally dry. Ideas? Anything I can fix on my own?
The compressor relay's purpose is to start the compressor. A faulty relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the dehumidifier. The relay is located in the terminal box which is located at the side of the compressor.
Before testing a compressor relay, unplug the dehumidifier to avoid an electrical shock hazard. Also, if the compressor uses a capacitor, it must be discharged first to avoid the risk of electrical shock.
The compressor relay can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip.
Jul 10, 2011 | Haier 45-Pint Dehumidifier
My dishwasher model number dmr77lhb is showing error code le and there are no apparent external water leaks how can I rest
I fixed mine by pulling out the unit then flipping over to access the white tray that covers the bottom of the unit. Remove this then dry it out...there's a sensor in there that triggers the LE code. It could be a leak but in most cases it's just built up condensation. EE1/HE/HE1
  • The EE and HE codes refer to temperature errors. The EE1 designation refers to a thermistor issue, and the HE codes refer to heater problems. These are all functional errors that require a certified service technician, but disconnecting the circuit breaker in the meantime can prevent the problem from growing worse.
  • 4E/4E1
  • The 4E codes indicate a problem with the water supply. If you see the 4E code, make sure the water supply line is correctly attached and open and not frozen or clogged. If you get a 4E1 code, check the temperature of the incoming water supply and ensure that it is below 176 degrees. If either of these issues persist despite your best efforts, contact a repair center.
  • 5E
  • The 5E code means there is a problem with the drain. Make sure the drain hose and openings are not clogged or obstructed. If they are not, and the code remains, disconnect the circuit breaker to reduce the risk of electric shock and contact a service center.
  • oE/9E
  • The oE and 9E codes refer to issues with the water level. The oE code means that the dishwasher is filling too much, and the 9E code means it is not filling enough. Disconnect the circuit breaker for safety and contact a repair center.
  • LE
  • The LE code indicates a leak. To keep from voiding your warranty, do not attempt to diagnose and repair the leak yourself. Close the water supply valve and disconnect the circuit breaker to avoid electric shock and contact a repair technician.
  • 6E2/PE
  • The 6E2 and PE codes both indicate functional errors that must be repaired by a professional. The 6E2 code indicates a pressed key error, and the PE code refers to a problem with the half-load function. Disconnect the circuit breaker in either case and contact a repair service.
  • Jan 10, 2011 | Samsung DMR77LHS Tall Tub Dishwasher
    Tenho 1 fogão DCS-RG364GD à
    i cant help but here it is translated to english.
    I have 1 fogã£o DCS-RG364GD the 10 years and am needing 2 springs of the door of the Ref oven: 211344-30" Door Hinge Nuova Star and 2 lame person - Ref: 211346-Receptacle Nuova Star another one peã§a: 210828-Spark Module - amount 1 My son this ¡ in London, as faã§o to buy these peã§as wool ¡ I wait an Obliged return Isabel dabelgastronomia@ uol.com.br
    Feb 23, 2010 | Kitchen Ranges
    Have a new nordyne heat pump installed and em heat will not come on.
    The EM heat is your electric heat element, it probably need to be wired in at the thermostat or air handler, you need a volt/ ohm meter to be sure and a basic knowledge of eletricity, if you don't do not touch it, let a service tech. do it for you, better safe than sorry.
    Jan 31, 2010 | Heating & Cooling
    Distributor timing set
    hmm ok
    this will risk serious eletric shock..
    start the vehicle
    slowly turn the distributor left or right until you get the neat ideling tone and little to no vibration. If you turn it one way the car speeds up
    the other way it slows down.. Find a place that you are comfortable with.
    BTW some vehicles have the original settings marked, look for a colord(usually red) mark on the distributor and engine just line up these two.
    Jul 20, 2008 | 1995 Ford Windstar
    Display green,red
    It should be dry solder joints on the CRT board,the picture tube base is normally dry solder.
    Opening the monitor could be tricky as there are two plastic locks which hold the top end of back cover.
    Samir
    Mar 09, 2008 | LG Studioworks E700B 17" CRT Monitor
    Connecting to a computer
    Are you asking how to connect the Brother PE-400D sewing machine?  You have "how to connect the '4000D' to a computer and what risk if any".  Which machine are you asking about - these are two different sewing machines.  If you are inquiring about the Brother PE 400-D, then your answer is... this machine is NOT capable of being connected to a computer.  However, if you wish to purchase or download embroidery designs from the internet, you may look into purchasing the Brother PE Basic. This allows you to download embroidery designs from the internet to your computer hard drive and then load them on to a Brother memory card.  The Brother memory card can then be slipped into the proper slot for the memory card on the sewing machine.  You will need to purchase embroider designs that are in the PES format for you Brother machine to read it.  Hope this helps!
    Oct 31, 2007 | Brother Disney PE-400D Computerized Sewing...
    Zebra Symbol MC3190G Handheld Mobile Computer Logo
    Top Zebra Computers & Internet Experts
    Mike
    Lawrence Oravetz
    Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
