Question about Paradyne Imarc 9126 Modem 9126-a2-201 Phone System
9126-A2 can work as csu and a modem at a same time?
Download usb driver
LOOK UP THE NAME OF THE PHONE ON THE INTERNET OR CALL THE MAKER OF THE PHONE
Jan 29, 2014 | Paradyne Imarc 9126 Modem 9126-a2-201...
ViviCam 9126 - item will not turn on.
The camera maybe still under warranty (12 month warranty). You maybe able to get a warranty repair from the manufacturer.
May 22, 2013 | Cameras
I have a problem with a Mitel sx2000 PBX which seams to be causing our line supplier problems. They say it is showing slips on the line and we need to have the clock set to theres and not the internal...
Your DSU/CUS can set clocking/timing from the local central office (CO) or internal.
There are MANY external DSU/CSU in the market.
Example: Adtran and Lucent
Please reply with what type of T1 DSU/CSU is connected to your unit.
==== If your setup does not use an external DSU/CSU then look for setting for your internal T1 card.
Are all cards on the same rack?
Grounded?
Jan 05, 2011 | Mitel SX200 480 Port T1 Adaptor...
Hey
check if your computer is getting a valid address from your modem. if so, try to ping the modem's address and check if you'll have replies. if it'll reply, try to disable any antivirus software and firewall installed on the computer or try to use another browser. if not, check i the computer is properly connected to the modem, try to use another port or another known working cable. also try to use another computer for isolation.
hope this'll help you with your concern.
May 29, 2008 | Paradyne (6211-A2-200) Router
CSU won't boot up
Problem is on its way to being solved. We called our vendor who contacted Intertel. Intertel is looking into problem. They have seen it before and are going to exchange the unit under warranty. Thanks for your response. Scott.
May 12, 2008 | Inter-Tel ECX 1000 Telephone
Need to install a modem on a Quick Eagle 4200T CSU
C-NOS:
Basically the modem has to dial in first to give you connection, One end goes to the Phone wall socket and the other end to your computer.
-Now in your case I am sure that your router is a DSL router meaning have no capability of dialing on command from the external modem.
-Nowadays VOIP built in routers are much more capable of dialing numbers directly.
-Old dialing modems should be connected directly from computer to the wall jack (phone lines).
Hope that helped!
Dec 10, 2007 | Computers & Internet
Trying to set up pptp on a Paradyne 6381
I have modems 6381-A2-200, sw ver.03.00.10. This model does not support pptp-connection.
Dec 06, 2007 | Paradyne 6381 ADSL2+/ReachDSL Router...
Please help
There is the manual.... www.zhone.com/support/manuals/docs/62/6210-A2-GB23-00.pdf And here are the drivers, ya may have to join for free... but it is handy for later things? anyway ..... members.driverguide.com/driver/detail.php?driverid=279217 www.modem-drivers.com/companies/792.htm
Aug 31, 2007 | Paradyne (6211-A2-200) Router
Paradyne Imarc 9126 Modem 9126-a2-201 Phone System Logo
62 people viewed this question
Top Paradyne Computers & Internet Experts
Michael Galve
Michael Galve
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
