Question about Dell Vostro 230 Safe space Tower w monitor Intel CoreTM 2 Duo E7500 wVT
Hard drive beeps
Beeps when upgrade the 1gb ram to 2gb ram. I'm using 2gb ddr3 1333mhz to upgrade, purchased from Dell.
    Novelist:
  • 177 Answers
Was your vostro 230 third generation? meaning, did it use DDR2 memory before or always had DDR3? They are not compatible. 2nd generation computers cannot use third gen parts. cpu, ram, most none of that type stuff. the motherboards are different and cannot change. if it was ddr2 memory you have to use ddr2, not ddr3, hope that helps.
Posted on Apr 21, 2014
SOURCE: Upgrading RAM in a Dell Dimension Dim 3000
buy kingston ram not used cheap bs ram
Posted on Mar 12, 2008
preachw996
  • 1179 Answers
SOURCE: replacing RAM in Dell Dimension 3000
Upgrading RAM will not affect your files. Just make sure you upgrade with compatible RAM & that you install it in pairs. So if you want 2 GB then you would want to be 2 x 1 GB RAM chips. Hope this helps & please remember to rate my answer. Thanks.
Posted on Feb 02, 2009
SOURCE: DELL OptiPlex GX150 Upgrading
Yes, $100.00 was too much for that system. I saw a refurbished Dell GX270 2.8Ghz 512MB 40GB HD CD/R/RW Windows XP Pro COA w/SP3 and all updated drivers installed for $114.00 + $5.24 shipping (amazon). Also see a Refurbished IBM ThinkCentre A50P(8193A3U) Intel Pentium 4 2.4GHz 512MB DDR 48x CD-ROM 40GB HD for $149.99 + 3 day free shipping (NewEgg). There are a lot of great reasonable sellers on Ebay but it's waters are getting more and more filled with Sharks as well (as well as many other sites, Just used Ebay as an example). I know this info doesn't help much now but hopefully in the future it can. You see a certain price on a system, do a full search on that same system and compare prices and shipping charges on what you find out there.
Posted on Feb 10, 2009
Gort007
  • 1187 Answers
SOURCE: i have a dell optiplex gx270, tried to upgrade my
That is the correct memory module (Non-ECC).
Remove all memory modules.
Insert the one Samsung PC3200 module and start up.
If it doesn't boot, then try a different slot.
If it works ok, then add-in your original mamory modules. If they are PC2700, then they may not work together.
Posted on Oct 12, 2009
zcomputerwiz
  • 92 Answers
SOURCE: Upgraded Studio XPS 435/9000 Ram - Now No Windows 7 Start
Check speed settings in BIOS, make sure that the sticks are the correct voltage for your motherboard. If the specs are correct, try a program like memtest86. This will tell you where the problem is, but it is up to you to find which stick that location is :) Might take some trial and error before you find the defective one!
Posted on Dec 16, 2009
Ram upgrade
no you have to use pc2700 for the pavilion ze2000. Max Memory 2gb (1gb x 2).
Aug 23, 2013 | HP Pavilion ze2000 Notebook
Repeatedly long beeps
If you upreage the RAM to 2Gb by inserting a 2nd 1Gb memory module then the 2nd RAM maybe faulty or incompatible.
If you insert a 2gb memory module to replace the 1Gb memory module then it maybe faulty or incompatible.
Try using the same make and RAM speed as the original RAM module.
Dec 29, 2012 | Biostar G31-M7 TE Motherboard
I have a Dell Dimension 2400. I want to upgrade from 512mb of memory to 1GB. The manual says I have two memory connectors. Do I get the 1GB, or two 512mb to upgrade? Thank you for your response.
Hello
Yes, you can upgrade your system upto 2GB RAM, buy another 512MB RAM DDR 333Mhz and install it to empty slot of RAM, it will upgrade the RAM to 1 GB.
Hope it will help, if so do rate the solution
Good Luck
Dec 15, 2010 | Dell Dimension 2400 PC Desktop
Can i upgraded my acer aspire one pro P531h-0Bk netbook
The first models of acer aspire one pro P531h-0Bk is not able to get more than 1gb RAM, but the revised model is able to get this. So you MUST consult with your IT dealer.
You can upgrade your Hard disk.
Sep 26, 2009 | Acer Aspire One PC Notebook
Upgrading My hp530 laptop
It is working.
Tested first with one new module with 2GB RAM, then with 2 modules, 2GB (new) + 1GB (original). Post and Windows are showing 3GB.
The HP 530 notebook is working OK.
Sep 12, 2009 | HP Compaq 6720s Notebook
New ram memory on dell dimension celeron trying to
You should check with the folks at Dell since whoever wrote their technical manuals for this machine can't do basic math. There are 2 memory slots and each can handle a maximum capacity of 512MB, yet they claim the maximum capacity for the machine is 2GB instead of 1GB. Using 512MB modules would probably work.
Jul 06, 2009 | Dell Computers & Internet
I would like to change my hard drive
If you are looking to save just a "small" bit of $ .. 2 - 1GB sticks should be cheaper .. but what is the current configuration . is it 1 - 1GB or 2 - 512MB or 4 - 256MB?
You have the option of IDE or SATA drive so either is an option .. You may want to get a drive copy utility and just "clone/ghost" your current to the new drive and then swap it to master and GO
Dec 26, 2008 | Dell Dimension 4600 PC Desktop
Question
First, you will not be able to upgrade the video card on your laptop, since video cards for laptops are specifically designed to fit onto the motherboard and the design of the laptops body.
Secondly, sound cards as well are also deisgined that way, some sound cards on laptops are built in to the mother board and higher end sound card for laptops are specifically designed to fit onto the motherboard and the laptop's body.
Hard Drives on the other hand can be upgraded to a higher capacity but you can't add an additional Hard Drive. I have checked the specs of your laptop has 80GB IDE. You can upgrade to 120GB IDE or higher if you like. Just make sure that you purchase a 2.5" HDD (5400RPM/7200RPM speeds).
Here are examples of Hard drivers that you need for upgrade. I checked newegg.com for available laptop hard drive. You can check other online stores or other computer shops near you if you as well.
links (Hard Drive) :
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136130
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148073
http://www.newegg.com/Product/Product.aspx?Item=N82E16822146200
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136114
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148130
**Since you have installed Windows Vista, I suggest that you upgrade the RAM (Memory) on the laptop for smooth performance for Windows Vista. The maximum memory on your laptop is 2GB DDR SDRAM. Buyin RAM for laptops are a little but tricky so you can just go to the link below for specific memory upgrade for your laptop (I suggest that you purchase 2 pcs of 1GB since your system can accomodate up to 2GB).
Link for RAM (Memory) :
http://www.edgetechcorp.com/memory/upgrade.asp?cid=29695
**If you decied to upgrade the Hard Drive, you can still use you old Hard Drive as an USB external Hard drive for storage purposes. You will just have to purchase a 2.5" External Hard Drive Enclosure. Click on the link below for the example of the product :
http://www.newegg.com/Product/Product.aspx?Item=N82E16817145136
http://www.newegg.com/Product/Product.aspx?Item=N82E16817145329
**If you can't click on the links, just copy the link and paste it to your's browser's address bar.
Oct 28, 2008 | Sony VAIO PCG-GRT360ZG Notebook
Memory upgrade for Dell Inspirion 4100 notebook
buy 1Gb -one ram, the rices for 512 and 1gb are more or less same now
Apr 21, 2008 | Computers & Internet
Dell Vostro 230 Safe space Tower w monitor Intel CoreTM 2 Duo E7500 wVT Logo
51 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
