Question about Paradyne Imarc 9126 Modem 9126-a2-201 Phone System
9126-A2-211-0AT can work as dsu and modem at a same time?
9126-A2-211-0AT can work as dsu and a modem at a same time?
DSU 6424 connection
Unfortunately if the problem started after a lightning storm the modem is almost certainly fried. I used to work at the UK's largest IT support call centre, we used to check the weather reports every morning because if there had been a lightning storm anywhere in the country we'd get a slew of calls from that region from people who could no longer connect to the web. Phone-lines collect a large static charge during a storm and are unprotected. I'd strongly suggest you contact the supplier regarding replacement.
Aug 21, 2007 | Datacom CMS 6424 (cms6424cs-dual) Modem
Download usb driver
LOOK UP THE NAME OF THE PHONE ON THE INTERNET OR CALL THE MAKER OF THE PHONE
Jan 29, 2014 | Paradyne Imarc 9126 Modem 9126-a2-201...
ViviCam 9126 - item will not turn on.
The camera maybe still under warranty (12 month warranty). You maybe able to get a warranty repair from the manufacturer.
May 22, 2013 | Cameras
I have a netbook with no cd drive so i can't install the 9126 software
You don't need to install anything.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what said first, you can use any photo cataloging program such as Picasa.
Jun 18, 2012 | Vivitar Cameras
I have a problem with a Mitel sx2000 PBX which seams to be causing our line supplier problems. They say it is showing slips on the line and we need to have the clock set to theres and not the internal...
Your DSU/CUS can set clocking/timing from the local central office (CO) or internal.
There are MANY external DSU/CSU in the market.
Example: Adtran and Lucent
Please reply with what type of T1 DSU/CSU is connected to your unit.
==== If your setup does not use an external DSU/CSU then look for setting for your internal T1 card.
Are all cards on the same rack?
Grounded?
Jan 05, 2011 | Mitel SX200 480 Port T1 Adaptor...
Can't hear when the call is on speaker.
Try two things. Ensure the system has set this phone up for handfree activation.
lastly, if you can not hear a dial tone through the handfree unit then you may have a bad speaker
Oct 10, 2008 | Comdial DSU II (DSUIISW05)
Speaker light stays on
press ICM button
Dial # 1
hould shut off light its the background music feture
and you must not have music on your system
Feb 19, 2008 | Comdial DSU II (DSUIISW05)
Wireless connection problem
Hello:
Ok...I am a bit confused. You must have a modem to connect to the internet...whether you are broadband (cable/DSL/wireless), Dial-up or T-1 or higher (TSU/DSU).
This is how it should run once you are sure you have the modem...
Modem....to router...pc to router. If you have no router...then plug ethernet cable from your modem to your NIC card on PC.
You will have to make sure your network card is working (check for flashing green light and one solid green. Then you can goto COntrol panel and run the wizard to connect to the internet...it should work.
What kind of router do you have? Also, what is the model number of your modem?
Let me know if I can help further.
Good luck my friend.
SeekPCRepair
Feb 09, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Paradyne Imarc 9126 Modem 9126-a2-201 Phone System Logo
95 people viewed this question
Top Paradyne Computers & Internet Experts
Olaso Nelson D
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
