Question about AO Smith Pool & Spa
My motor tends to start and rotates couple of rounds before the breaker jumps
    Problem Solver:
  • 9 Answers
Sounds like a capacitor replacement is needed normally the motor gives a growling sound. The second possibility is the switch to disengage the starting winding is frozen and will not open when the motor rotation starts going.
Posted on Nov 20, 2013
I have a Maytag LDE9304ACM dryer. It suddently quit today. When I press the start button, the start button light "lights up", but there is not sound and no rotation. I can hear the timer. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 04, 2011 | Maytag Dryers
The dryer drum does not rotate. I have a Kenmore electric model number 110.62622101. It blows hot air but drum does not rotate
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
May 15, 2011 | Kenmore 62622 Electric Dryer
My dryer's electronic display lights but motor won't start. When start button is pushed, display flashes and a ticking sound is heard. I took dryer to neighbor's house, plugged it in and it worked fine....
heatman101
Nov 23, 2010 | Dryers
Dryer does not rotate, makes buzzes as if wanting to start rotation
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
heatman101
Sep 13, 2010 | Whirlpool Dryers
Too change rotation of a 5hp 230 volt
HAVE A LOOK INSIDE THE MOTOR CONNECTION BOX. SOMETIMES ON THE LID ARE INSTRUCTIONS OF HOW TO DO THIS. YOU DID NOT SAY IF THIS WAS A CAPACITOR START UNIT OR NOT. IF THERE IS A CAPACITOR ON THERE IT COULD BE NO GOOD WHICH WILL MAKE THE MOTOR GO WHERE IT WANTS. A GOOD CAPACITOR KICKS IT IN THE RIGHT DIRECTION ON SWITCH ON.
Jul 25, 2010 | Air Tools & Compressors
Sluggish on start and blows the breaker on compressor 17amp
replace the start capacitor on the motor body,it is located under a metal cover by loosening 2 screws,it is getting weak,also if you leave this breaker jumped,you will soon over heat the motor windings and ruin the motor
Apr 09, 2010 | Hitachi EC119SA Twin-Stack Air Compressor...
Craftsman table saw 1 1/2 hp trys to to start but motor appears to bind, will not rotate but a couple of inches. Can turn blade and belt by hand. Tried starting several times but starts to trip electical...
The 'start capacitor' has failed. It's under the little cover located on the side of the motor. Remove and go to a 'motor rewind or repair shop'. If you don't have a motor shop near by, go to grainger.com. The cap has a microfarad rating (uF) and a voltage rating, go by those two ratings to replace.
Sep 24, 2009 | Saws
The belt on the radome drive sprocket jumps off of
The belt pully on the motor has a set screw that tends to get loose causing the pully to change position on the shaft. Position the pully on the shaft (move up or down) for better alignment with the pully on the rotating array pully and tighten the set screw..
Feb 23, 2009 | Furuno 2.2kw 18" Radome
Plate does not rotate freely and make noice
There is no belt in your model - the turntable is motor driven. The problem is either the motor itself or the coupling that engages the glass tray.
The motor (GE part # WB26X10038) is a very common failure as the internal gears are plastic and tend to strip.
You can view the motor at this link...
www.microwaveglasstrays.com
Jul 10, 2008 | GE JVM1650 1000 Watts Microwave Oven
Pool & Spa Logo
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
