Question about Dell Vostro 230 Safe space Tower w monitor Intel CoreTM 2 Duo E7500 wVT
Does 2gb 1333mhz ram uograde work on Vostro 230s. the origina 2gb ram was 1066mhz
    Habit-Forming:
    Scholar:
  • 68 Answers
UA is correct, that is the best way to find out for sure but you're new RAM will work just fine.
Posted on Nov 20, 2013
    Master:
  • 409 Answers
Go to http://www.crucial.com/ and run the memory analyisys tool. it will tell you what options are available to you.
Does Intel DH61BF motherboard supports 4GB 1600Mhz RAM ?
OK, I was looking for a solution, but hardly got anything that clarify if it's compatible or not. But what I did find out is that if you install a 1600MHz memory stick, this one will clock down to 1333MHz in order for the MB not to crash. Here is a C/P.
Part #: 2xCT102464BA160B • 16GB (2x 8GB Kit) • DDR3-1600 - 1600Mhz - PC3-12800 • CL11 • Dual Rank • Non-ECC • Unbuffered • 1.5V • 16-chip 512Mx8 • Lifetime Advance Replacement Warranty • This 1600 MHz module is programmed to clock down to 1333 / 1066MHz where the system requires it.
Mar 04, 2015 | Intel Computers & Internet
What are the compatible RAM modules?
It uses up to four DDR3 1066MHz SDRAM DIMMS
May 28, 2014 | Dell Mobile Precision M6400 Computer...
Hard drive beeps
was your vostro 230 third generation? meaning, did it use DDR2 memory before or always had DDR3? They are not compatible. 2nd generation computers cannot use third gen parts. cpu, ram, most none of that type stuff. the motherboards are different and cannot change. if it was ddr2 memory you have to use ddr2, not ddr3, hope that helps.
Nov 19, 2013 | Dell Vostro 230 Safe space Tower w monitor...
Hello is lg R490 processor upgradable to 3rd generation and since it is using ddr3 1066mhz can you replace it with 1333mhz
you can't upgrade the processor due to mainboard compatibility, however, you can still upgrade the RAM to 1333mhz
Nov 02, 2013 | LG Computers & Internet
Sony vgn-z520
Usually, it is not possible to upgrade the cpu on a laptop. In rare cases where it is possible the upgrade usually costs nearly as much as a new laptop.
However, you can significantly upgrade the laptop's performance by adding more memory and by replacing the old slow hard drive.
Your Sony VGN-Z250 is usually supplied with 3GB of RAM memory. You can replace the existing memory modules with a new kit consisting of 2 x 2GB modules (total 4GB). The type of memory you need is "SO-DIMM" (meaning laptop size) DDR3 - 1066MHz (you may use 1333MHz memory but it will only run at 1066MHz speed). I would suggest either G-Skill or Crucial brand memory. And you can replace the hard drive with an SSD. You'll be amazed at the boost this provides, seriously. I would suggest either Samsung 840 EVO or Sandisk Ultra for an SSD. Both offer super-fast performance compared to your old spinning hard drive, and both have very low power consumption so they run cool and give your laptop a few extra minutes of battery power. You can clone/copy your existing Windows setup onto the SSD using free Macrium Reflect software or free software from the SSD maker's website. Or, you can do a fresh install of Windows.
Mar 27, 2013 | Sony VGN-Z520N/B PC Notebook
I have a m4a78lt-m motherboard will kingston ddr3 1600 4gb khx1600c9d3b1k2/4gx memory work with 32bit os I am putting a system togather have purchased the mother board and memory now i am questing if it...
This motherboard uses DDR3-SDRAM, ECC and non-ECC, unbuffered, PC3-10600(1333mhz) or PC3-8500(1066mhz), dual channel architecture (two sticks at a time), and a max memory of 8Gs.
This are the specs for your ram: 4GB 1600MHz DDR3 Non-ECC
(Kit of 2) Intel XMP HyperX = DDR3-1600
Default = DDR3-1333 CL9-9-9-27
CL9-9-9 1.65V
1.5V
In other words, Yes! This should work just fine. The ram will just run at its default speed of 1333mhz.
Jan 28, 2011 | ASUS M4A78LTM LE Motherboard
I TRIED TO CHANGE SPD MEMORY RUNNING WITH AN OCZ 1333MHZ TO 1066MHZ AND THE BOARD DIDNT WAKE UP ANYMORE AND I CHANGED JUMPERS BIOS AND IT DIDNT WORK OUT, IT BEEPS CONTINUOSLY THREE TIMES
Hi lesterwild
Your problem may be a coincidence. sound errors related to hardware problems. check and do troubleshooting on your display card and ram, it will resolve your problem.
thanks®ards
Jan 11, 2011 | Intel Desktop Board DG41BI Essential...
Which laptop for 3d animation .use softwares maya,max ,video editing dell's config: Intel® Core™ i5-460M Processor (2.53GHz, 2Core/4Threads, turbo up to 2.8GHz, 3M cache) 1GB NVIDIA®...
dell\'s config: Intel® Core? i5-460M Processor (2.53GHz, 2Core/4Threads, turbo up to 2.8GHz, 3M cache) 1GB NVIDIA® GeForce® GT 420M graphics with Bluetooth (with WIDI) 4GB 1333MHz DDR3 SDRAM (1 x 4G) (operates at 1066MHZ for Core i5 processors) with increased RAM will work fine
Dec 16, 2010 | eMachines M6811 Notebook
Problems with memory upgrade to vostro 220 mt...2gb hynix wont work on its own ...got a piece 2gb hypertec wont work on its own either...why is it so finicky? going back to 1gb hynix which came with it all...
RAMs are not compatible...
if u have MSoffice 2007, there is tood there in that u can use that to check the RAMs comaptibility...go to
Start/All Programs/MS Office 2007/MS office Tools/MS office Diagnostics
Else u can downlaod a RAM checker from google
Dec 24, 2009 | Dell VOSTRO 220MT E8400/3.0G 2G WVB 160GB...
Can i replace RAM memory of a lower clock speed (1066mHz) with faster clock speed (1333mHz)
depends weather your motherboard supports the new clock speed. what is the make and model of your motherboard and i will check for you. james. james06_18@msn.com
Sep 27, 2009 | Apple iMac 20" Desktop
Dell Vostro 230 Safe space Tower w monitor Intel CoreTM 2 Duo E7500 wVT Logo
49 people viewed this question
Alun Cox
