Question about Miller Welding Tools
Miller 652 delta weld reading a EEE error code
4 Suggested Answers
luis_david
  • 407 Answers
SOURCE: Miller Delta Weld 450 Manual
Hi:
Follow the link for the owner's manual.
http://www.millerwelds.com/service/locate_om.php
Posted on Jun 09, 2011
SOURCE: Miller deltaweld 452 power source is reading EEE
Replace the digital meter board, its function is to also control the voltage to the unit and read the amps.
Posted on Dec 12, 2011
  • 1212 Answers
SOURCE: 1993 KD15 series miller delta weld 300 can it be
Theoretically yes, but it would be a great deal of work and would draw a little over 6 times the current it did when on three phase power.
It would entail replacing the fan motors, connecting the 6 windings of the 3 phase primary in phase and in parallel. Plus adding a 115 circuit " tapping off half of the 220 single phase" incoming power for some aspects.
The control board would also need modifications as well. because it uses 3 current sense transformers and you would need to rework that circuit to compensate.
The short answer if you were wanting to set one up for home use- just invest in a "Sidekick" They did have a 240 volt single phase version, and if you consider the time invested to change something over that could trip the 200 amp service breaker, if you value your time- the money for a Sidekick would be well worth it.
If you want proof- open up the primary side of the Deltaweld and look at all of those connections you have before you- you would not be using 1/3 of them, and you would need to take the time to make sure the 6 windings were in phase otherise the transformer burns out- it may burn out anyway because the current draw increase beacause all the low impedance windings are now in parallel on a nominally lower voltage- just the potential of fire from that arrangement makes the money spent for a Sidekick to be considered "cheap insurance."
Posted on Mar 30, 2012
Miller 350p wire feeds but dont weld
Remove any paint or rust and make sure your ground clamp has a firm grip on whatever your welding or welding on and a nice clean surface
check all welding leads
Nov 24, 2015 | Miller Welding Tools
Have a Miller Dynasty 300 that won't tig weld, displays HELP 12 code. Suggestions??
Some welders have a resistor that is obvious and accessible but to give an error code it is likely something else inside. You'll have to look at the circuit board for a component that is burned. If you are lucky you will find a fuse.
Nov 21, 2013 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
Serial number miller AEAD 200LE JF 885778
Check this out:
http://www.ebay.com/itm/MILLER-AEAD-200LE-CONSTANT-CURRENT-AC-DC-ARC-WELDING-GENERATOR-GAS-POWERED-/310368057796?pt=BI_Welders&hash=item484360b9c4
Jan 13, 2012 | Miller Welding Tools
Miller deltaweld 452 power source is reading EEE code in the voltage slot ???
Jun 15, 2011 | Miller Electric Mfg Co 903394 Deltaweld...
Need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
Dec 27, 2008 | Miller matic 140 Mig Welding Package W/As...
Welding Tools Logo
204 people viewed this question
Top Miller Welding Tools Experts
John Trevino
wadingriver
wadingriver
Jose Velazquez
Jose Velazquez
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
