Question about Motorola Mobility H350 Wireless Headset
Plantronics hw251 headset
How do i adjust volume on plantronics hw251 headset?
Sound level is inconsistant in headset. Unable to adjust volume with "rocker" buttons.
The Plantronics 510s system includes the 500A base and the Voyager 510 Bluetooth headset. Number "one" on the lower back of the 500A base is the loudest setting for your listening volume, I would also check to make sure that the compatibility setting on the left side of the 500A base is set to "one", so the number one should be lined up in the 3 o'clock position (which would also be lined up with the ridged area to the right). Number one compatibility setting is the most common setting for most phones. You can also try using the headset with a cell phone to see if the volume adjusts or not, if it still doesn't work properly, maybe the headset is just wearing out. Here is the link for the replacement headset:
http://www.headsetsdirect.com/84321-01-510-replacement-headset.html
Good luck from Headsets Direct - 800-914-7996.
Aug 24, 2011 | Plantronics Voyager 500A Headset
Wife complains of echoing when listening to me on headset. Love the headset cause I'm hearing impaired.
Plantronics Voyager 510 echoing:
If the Plantronics Voyager 510 headset is being used with the base on a regular telephone, you can adjust the microphone volume on the bottom of the base unit.
If the Voyager 510 headset is being used with just a cell phone... unfortunately there aren't many adjustments. You may want to un-pair and delete the headset from the cell phone totally, and then re-pair it to the phone just to make sure that it has a strong link or connection.
Also just as a side note about Bluetooth headsets and cell phones. Typically the simpler the cell phone, the better the Bluetooth connection and quality.
Aug 03, 2011 | Plantronics 510 Voyager Headset - PLN-510...
We are using the Plantronics CS55 wireless headsets. The users are complaining that the '3-beep' incoming call alert tones are too loud. We have tried to adjust this tone level by manipulating...
Lowering the ring volume on the phone only decreases the sensitivity of the lifter, which generates the signal to the headset. The signal volume between the two is preset and cannot be adjusted.
Good luck from Headsets Direct!
Jul 20, 2011 | Plantronics CS55 Wireless Headset
I can hear callers but they cannot hear me. Mute is not engaged,
Please see the link below for the User's Guide.
• Headset is muted. Long press (3 sec.) the volume down button on headset to unmute the microphone. See page 16.
• Improper positioning of voice tube. Try various other positions.
• Voice tube may be clogged. Remove voice tube and test to see if callers can hear you without it. If they can, then replace the clogged voice tube. See page 18.
• Speaking volume is too low. Increase the speaking volume by
adjusting the speaking volume minor adjust buttons on the base unit as described on page 16. If the volume is still too low, select another speaking volume major adjust setting as described on page 16.
• Incorrect configuration dial setting for your phone. Try other
phone configuration dial settings on the base unit. Ensure the
selected number is in line with the position indicator. See page 14.
Plantronics CS70 User's Guide
Jul 18, 2011 | Plantronics CS70 Wireless Headset
Apparently the volume of my plantronics 925 bluetooth is very low. is there a way to adjust that volume? Thank you.
Yes, there is a way to adjust the volume on your Discovery 925 headset. See page iv to locate volume control button and page 8 for the instructions in this link for the Plantronics Discovery 925 User's Guide.
Jul 01, 2011 | Plantronics Discovery 925 Bluetooth...
I have a CS361 plantronics wireless headset and I get alot of echoing when I get calls in and out, and when I call my coworker
Reduce speaking volume by changing the speaking volume
major adjust switch setting. See page 15 in the User's Guide (link below).
• Point microphone towards your chin.
• Listening volume too high on phone. If your phone has a handset
volume control, lower this until the distortion disappears.
• If the distortion is still present, lower the listening volume adjust
button on the headset. If the distortion persists, select another
listening volume major adjust switch setting. See page 14 in User's Guide.
• Base is too close to computer or phone. See page 9 in User's Guide for
proper positioning.
For further help, this is the link for the Plantronics Wireless Headset User's Guide.
Apr 19, 2011 | Plantronics CS55 Wireless Headset
Just purchased the quantico phone trying to pair it with my plantronic 510 headset but need help
Press and hold both the Speak Volume Adjust Buttons on the base unit until
the indicator in the Call Control Button starts to flash.
Press and hold the headset Listen Volume Adjust + Button and headset Call
Control Button until the Status Indicator flashes red and blue.
Pairing completion is indicated when the Call Control Button indicator
illuminates solidly, and the Status Indicator flashes
Here is link to manual if you need it:
http://www.plantronics.com/us/media/media-resources/literature/user_guides/voyager510_ug_gb.pdf?WT.dl=20
Good luck
Apr 16, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics CS55. When using the wireless headset
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Jul 10, 2009 | Plantronics CS55/HL10 Wireless Office...
Top button on Plantronics 232 Bluetooth headset
Its for volume. you hold it down and adjust the volume.
Jul 05, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics GN9120 microphone is too quiet for listener
I've had this same probelm and after much pressing of buttons eventualy fixed it by reading the manual... :s
Last page page of Quick Set-Up Guide under "Transmit volume adjustment":
1.) Make call to another phone user to assist.
2.) Press + and - on the headset at the same time.
3.) Adjust volume by pressing either - and +.
4.) Confirm volume with helper.
5.) Wait for 10secs and the settings will store.
May 08, 2008 | GN Netcom GN 9120 Professional Headset
Motorola Mobility H350 Wireless Headset Logo
19 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
