Question about Bissell ProHeat 2X Healthy Home Carpet Cleaner - -
Does not vacuum cleaning solution from carpet
Everything except the suction works. Tried the hand tool, also no suction.
  • 739 Answers
Check the impeller for debris build up and blockage in the airway
Posted on Nov 20, 2013
I have a 1/2 hp gould shallow well pump that takes a long time to reach pressure and shut off. Any advice to correct?Thank you, Kevin
Make sure you do not have any excess air in the line. More than likely there is an air (vacuum) leak on your suction line.
Nov 16, 2017 | Water Water Heaters
Kenmore Water Softeners Model 625388270 Serial 12756 - Water above the salt level. I have cleaned the venture nozzle. Did not help
On this model, the problem is usually the rotor and rotor seal. When they wear, they don't let the softener create a vacuum to pull the brine water from the tank. This is a fairly complex repair. I don't have a service manual for you. The parts are available from Sears. I know this is not much help, but I've worked on hundreds of these and this is the problem 98% of the time.
Aug 05, 2013 | Kenmore 420 Series Water Softener
I have a 50 gallon Richmond Power vent water heater. The burner would try to light but would not. I replaced the vacuum switch, but this did not solve the issue. The tygon tube that runs from the vacuum...
The accumulation of condensation in the vent piping is more than likly the problem. I am guessing the vent piping is either 3-inch or 2-inch. You need to splice in a "T" fitting reduced down to 3/4-inch with a 3/4-inch tubing attached and run this to a sutible drain. This will drain the condensation elimiating the accumulation in the vent assembly. Install this "T" fitting about 3-feet down stream from the vent motor.These supples and fittings can be found at a Home Depot or Lowes store.
Jan 27, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Does sears kenmore hot water heaters have external filters. pilot light wont stay lit
Not sure about this brand, but if you take a flashlight and look below your burner, you should be able to see the mesh screen if it has one. Or use a hand mirror under the water heater and look with a flashlight to see if it's there. If it's dirty, it will need to be cleaned to stop your pilot outages. If you do, you will need to shut it off and let it cool down before attempting to vacuum it out. Personally, I've found the best way to get to it is by removing the burner assembly, which you may want to hire your gas co to do, if you are not familiar with the appliance. Manufacturers recommend cleaning it every 6 months. Douglas
Jan 05, 2011 | Water Heaters
The pilot light goes out when i shut the acess panel door
Not sure how old the water heater is, but it's possible if it's one of the newer ones with the sealed burner, that the side vents are partially blocked, therefore not allowing enough air in through the sides to maintain the flame. Use a shop-vac or other strong suction vacuum to sweep along the side to clear any dust or debris from these areas to allow the air to flow more freely through the vent holes to maintain the flame.
Aug 18, 2010 | Rheem Water Heaters
My tankless remote digital controller won't go above 76 degrees F
76 is an error code. Look in the owners manual and it will tell you what the problem is.
May 31, 2010 | Rinnai Digital Remote Water Heater Control...
C4 13 error flashing on water heater, shuts off after a minute
1/ overheat stat 2/ fan 3/ microswitch 4/diaphrapm valve best of luck
Oct 06, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Heat loss
Sounds like a thermostat problem.
Apr 10, 2009 | Water Heaters
Bissell ProHeat 2X Healthy Home Carpet Cleaner - - Logo
62 people viewed this question
Top Bissell Water Heaters Experts
Paul Carew
yobo007
yobo007
SirEbrum
Are you a Bissell Water Heater Expert? Answer questions, earn points and help others
