Question about Air Tools & Compressors
Abac redline 50ltr air 2.5hp compressor manual
3 Suggested Answers
  • 33 Answers
SOURCE: i have ABAC 270ltrs italian comprosser. after the comprosser reaches its full capacity air starts to leak from its switch. can u pls help me solve this promblem
Im guessing by the switch, you mean the pressure switch?
When the tank is full, there is a check valve, which closes to stop air from escaping through the pressure switch, this is normally located on the tank, from there, there should be a pipe going to the switch. Inside there is the check valve, when there is no pressure, check inside there, if it is dirty, clean it up and put it back in, or replace it, they don't cost that much
Posted on Aug 06, 2012
  • 17 Answers
In 80% of the cases this is the problem. I sulose that you use a lot this compressor so the one way valve gets worn out. The first stel is to pull out the smal hose when the unit stops and see if air escapes. If so then change the black piece in the photo. It will last for a small period of time. I recomend to change the piece in the photo.
This is a way to solve the problem if air escapes trough the small hose.7
Posted on Feb 10, 2016
Looking for manual for sanborn B51-A24-80V1 model
PDF]Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1
intrigante35hindu.strictlyyouth.org/rzsatzo_sanborn-black-max-5hp-air-...
Jul 16, 2015 - Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1 ... Black Max Portable Air Compressor - 5 gallon Item #: 81527 ' Model #: BS0880504 ...Compressor Manual: $4.95: Buy Now: B51-AT24-80V,B51-A24-80V1.
Aug 28, 2015 | Air Tools & Compressors
I have a craftsman air compressor model number 921.153101 that won't pump-up over 40 pounds
Its probably a oil less compressor so it could be the reed valves are bad or the piston rings are bad.
Feb 01, 2014 | Craftsman Air Tools & Compressors
I have ABAC 270ltrs italian comprosser. after the comprosser reaches its full capacity air starts to leak from its switch. can u pls help me solve this promblem
Aug 01, 2012 | Craftsman Air Tools & Compressors
Gauge goes between 3/4 and redline , back and forth .. give it some gas and heat goes cold and gauge get high to redline
Sounds more like air in the system, bleed the system and make sure the radiator cap is good. If it still does that then the system is taking air in and needs to be checked further.
Oct 19, 2011 | 1994 Jeep Wrangler
Ingrsoll rand air compressor repair manual
Most manuals are available from Ingersoll-Rand, I am not sure they sell a repair manual. however they do have owner and parts manual for the pumps that show breakdown of the pump and can be very handy for reference when working on one. Contact your nearest IR air center and ask for a copy of the manual, and most times they can provide you a copy for little or no cost.
Jan 08, 2010 | Ingersoll Rand Air Compressor Maintenance...
Vibration problems in 1kz te
Check calibration. Muffler supports from the front till the back, there should be proper clearance. Is your diesel fuel of proper cetane rating for the engine? Check your belt drive system, is there any part that is excessively draining engine power, power steering pump, air con compressor, alternator or generator? Do these preliminary steps and isolate.
Nov 29, 2009 | Toyota Pickup Cars & Trucks
Air Tools & Compressors Logo
133 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
