Question about HP LaserJet 4200 Printer
I have a 60.2 printer error on my HP printer - HP LaserJet 4200 Printer
    New Friend:
  • 87 Answers
Try this link. http://h30499.www3.hp.com/t5/Black-and-White/Laserjet-4200-Error-60-2/td-p/3423676#.UovWlGthiSM
Posted on Nov 19, 2013
NVM reset for hp photosmart c4780
You can gain access to the service menu...refer to Cartridge Error Clear bypass procedure below (as guidance of how to get in):
For any severe cartridge error related message, on the HP C4600, C4700 or D110a printer models, I suggest you run the internal Tap 41 diagnostics test which will tell you the electrical health of the ink cartridge - in many cases the cartridge is internally electrically damaged and will need to be replaced. In addition, you can temporarily bypass an 'incompatible cartridge(s) or Missing/Not Detected error message by performing the Cartridge Error Bypass procedure...refer to two Youtube videos on how to do this:
HP Photosmart C4600 & C4700 Printers - Tap 41 Diagnostic Test: http://www.youtube.com/watch?v=ghxjLCn07Jo
HP Photosmart C4600 C4700 D110a Printers - HP 60 Cartridge Error Bypass: http://www.youtube.com/watch?v=rNVJmKPlLsg
Low Ink Warning and Other (i.e Incompatible Cartridge) Errors, HP 60 & HP 61 Ink Cartridges:
http://www.youtube.com/watch?v=5_suW3U6e08
Feb 28, 2013 | Cisco Photosmart C4780 Wireless AllInOne...
How can I align my HP Photosmart C4680 printer after replacing ink cartridge.
If the new (or refilled/reman/compatible) HP 60 (or 60XL) ink cartridge refuses to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance.
The types of 'more severe' cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", etc.), including blinking power/exclamation lights, typically indicate the internal micro-electronics of the HP #60-61 cartridge are electrically damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you always run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on C4600-C4700 models which use HP 60 cartridges. Refer to Inkjet411 youtube videos below:
HP 60, 60XL, 61, 61XL Ink Cartridge Refills - Solving Errors & Warnings: http://www.youtube.com/watch?v=BskAfa6NJSg
HP Photosmart C4600 & C4700 Printers - Diagnostics Tap 41 Test: http://www.youtube.com/watch?v=ghxjLCn07Jo
HP Deskjet F2400 F4400 and F4500 Printers - Diagnostics Tap 41 Test:
http://www.youtube.com/watch?v=m-OM09NvNqg
HP Deskjet 4200 Printers - Diagnostics Tap 41 Test:
http://www.youtube.com/watch?v=16uXSBwTan8
HP Deskjet D2500 & D2600 Printer -Tap 10 Diagnostic Test:
http://www.youtube.com/watch?v=RTFOBtdthAc
Mar 28, 2012 | Office Equipment & Supplies
C4680 print cartridge problem
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
May 06, 2011 | HP C4680 All-In-One Inkjet Printer
My HP Photosmart C4700 keeps saying the printer cartridge is in wrong. I have taken them both out and put them in and they are correct.
These types of severe cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", etc.) typically indicate the internal micro-electronics of the HP #60-61 cartridge are electrically damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you always run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on C4600-C4700 models which use HP 60 cartridges. Refer to Inkjet411 youtube videos below:
Sep 20, 2010 | HP PS C4780 All in One InkJet Printer
Hp Photosmart C4780 won't recognize new ink cartridges
Switch off the printer and switch on again,Unclip the cartridges one by one and clip back in again this sometimes cleans out the connector pins.This has happened to me.
Sep 02, 2010 | Cisco Photosmart C4780 Wireless AllInOne...
How do i bypass the ink cartridge error on the hp Deskjet F4480? It is saying ink cartridge not compatible but it is a genuine cartridge. And E is displayed on the screen and the light is flashing. How can...
These types of severe cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", etc.) typically indicate the internal micro-electronics of the HP #60-61 cartridge are electrically damaged - now, these errors can be bypassed on select printer models (temporarily). The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you always run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on C4600-C4700 models which use HP 60 cartridges. Refer to Inkjet411 youtube videos below:
May 20, 2010 | HP F4480 All-In-One Printer
What is a incompatible print cartridge? Its coming up with a warning exclamation mark and it wont print?
What is a incompatible print cartridge? The printer "Thinks" that the print cartridge, is NOT an original HP PhotoSmart one. Even print cartridge have chips.
Mar 28, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
HP LaserJet 4200 Printer Logo
75 people viewed this question
Seeker5211
Seeker5211
