Question about Whirlpool GS460 Gas Kitchen Range
Oven and broiler not working how do I fix it - Whirlpool GS460 Gas Kitchen Range
  • 26 Answers
Need more details.
Posted on Nov 20, 2013
My Gemini double oven needs to heated to 550 degrees before the broiler will ignite. I've been dealing with this for years. How can I fix this issue? Jim
This repair you had done was to repair and prevent the door to the upper oven from building with gas as the broiler was know to do. This was a safety issue for the time period UL required. You can select the low broiler to speed up you preheat time but there is no known fix to by-pass this mode. Sorry for the bad news, good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 06, 2016 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Model ew30gs65gsc. Why is broiler not igniting?
Electrolux Oven Broiler Not Working - Model E30DF74EPS ...
www.repairclinic.com/...Range-Stove-Oven/...-/Electrolux-Oven-broiler-...
Most Frequent Causes for Oven broiler not working. See All Range/Stove/Oven Parts for model E30DF74EPS. Cause 1 Temperature Control Thermostat.
Electrolux Oven Broiler Not Working - Model EW27EW65GS6
Electrolux oven broiler not working? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Oven Broiler Not Working - Repair Parts - RepairClinic.com
www.repairclinic.com/...Range-Stove-Oven/...---/Oven-broiler-not-worki...
Oven broiler not working? Use our DIY troubleshooting & videos. Then, get the partsyou need fast. Return any part for 365 days.
Gas Oven/Broiler not working/igniting - ApplianceBlog
Jan 13, 2016 | Electrolux Kitchen Ranges
GE Gas Oven and broiler not working
No, there is a "hot-point" ignition for each but they are both controlled by the ignition module, easy fix, follow the wires (2) from the Broiler ignition point.... they will lead you to the module. More then likely it's wire connection came apart.....
Mar 15, 2014 | GE Profile Spectra JGBP90 Gas Kitchen...
Broiler doesn't work: the upper coils do not light up in any sett
try and try to test the broiler..if it does not really work,look for someone who can fix it
Feb 08, 2010 | Euro-Pro EuroPro 6Slice Toaster Oven with...
GE JGBP90MEB oven not lighting. Broiler working
Igniter needed to be replaced. GE fixed it the same day.
Sep 18, 2009 | GE Ovens
Oven broiler and auto clean not working.
if the oven broiler isnt working self clean wont either check the broiler element to see if its burned out pretty easy to replace most of the times you can replace it from inside the oven be sure to turn the power off then remove the two retainers from inside and pull element out
Jan 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Heat elements in oven/broiler do not heat up
I would say to go and reset your curciut breaker first if this is a electric oven. needs 220 volts for both element to work
Jan 03, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
GSP31GER GE gas slide in oven dosent work
I think you missed a letter at the beginning of your model number. (it is maybe a JGSP31GER ?) I would first test the broil, and see if that works. (I would guess that it does) Most likely the oven ignitor (part number WB13K5058 ) needs to be replaced. It is located under the floor of the oven right next to the burner. It is a round electric coil thing about 4 inches long. If you want to confirm that this part is bad before replacing it, (and the broiler works) you can take the ignitor off the broiler and install it in place of the oven ignitor. They are the same part number. Of course now your broiler and self clean will not work unless you replace the broiler's ignitor. This is not too difficult, maybe a 3 on a scale of 1 - 10. Should be a Fix-Ya for your slide in range!
Jan 01, 2009 | Kitchen Ranges
Whirlpool GS460 Gas Kitchen Range Logo
47 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
