Question about Lenovo 7734N3U R61 T8100 1gb/160 Dvr 14w Wxp PC Notebook
Wireless switch how do i turn on wireless
How to turn on the wireless card on Sony pcg11211L
If your computer will not connect to a wireless Internet signal, one of the first things to check is whether your computer's wireless switch is turned on.
Many laptop computers have a switch located on the exterior of the computer that controls its ability to connect to wireless networks.
This switch can be accidentally turned off, preventing users from connecting to the Internet.
Determine if your computer's wireless connectivity has been disabled by viewing the network icon in the lower toolbar on your computer's desktop.
When there is a disruption in your computer's Internet connection, the icon will have a red X through it. For further information, go to the computer's Network and Sharing Center where you can troubleshoot connectivity issues and view available wireless networks.
If the computer isn't recognizing any wireless connections (and you're sure that there are wireless signals in your area), the likely problem is that the wireless switch is turned off.
Locate the wireless switch on your computer.
It may be located on either side of the laptop or along the back or front.
If you aren't sure whether your computer has a wireless switch, check the user guide that came with the unit.
Determine whether the switch is currently in the "On" or "Off" position.
The switch will be clearly labeled.
Push the switch in the direction of the "On" position to ensure that it is turned on.
If the switch was already turned on, see if there is a keyboard combination that will activate your laptop's wireless capability.
The key combination for your laptop will depend on your computer's manufacturer, but will generally involve a combination of the Function, Control or Alt and the F1 to F12 keys.
Check your user manual for your computer's key combination.
Troubleshoot problems finding wireless networks
http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-problems-finding-wireless-networks
Mar 23, 2014 | Sony Computers & Internet
I don't know how to turn on the wireless capability on myself?
What type of computer Desktop or Laptop & Make ???...
Aug 13, 2013 | Computers & Internet
How do I turn on my wireless connection
Jun 13, 2013 | Computers & Internet
I do not know my wireless pc
b> If your computer will not connect to a wireless Internet signal, one of the first things to check is whether your computer's wireless switch is turned on. Many laptop computers have a switch located on the exterior of the computer that controls its ability to connect to wireless networks. This switch can be accidentally turned off, preventing users from connecting to the Internet.
Determine if your computer's wireless connectivity has been disabled by viewing the network icon in the lower toolbar on your computer's desktop. When there is a disruption in your computer's Internet connection, the icon will have a red X through it. For further information, go to the computer's Network and Sharing Center where you can troubleshoot connectivity issues and view available wireless networks. If the computer isn't recognizing any wireless connections (and you're sure that there are wireless signals in your area), the likely problem is that the wireless switch is turned off. Locate the wireless switch on your computer. It may be located on either side of the laptop or along the back or front. If you aren't sure whether your computer has a wireless switch, check the user guide that came with the unit. Determine whether the switch is currently in the "On" or "Off" position. The switch will be clearly labeled. Push the switch in the direction of the "On" position to ensure that it is turned on. If the switch was already turned on, see if there is a keyboard combination that will activate your laptop's wireless capability. The key combination for your laptop will depend on your computer's manufacturer, but will generally involve a combination of the Function, Control or Alt and the F1 to F12 keys. Check your user manual for your computer's key combination. Troubleshoot problems finding wireless networks
Mar 14, 2013 | Toshiba NB505N500BL 1 GB Hard Drive
Where is the wireless radio switch
Maybe you don't have your wireless turned on. Look onboth sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can togglethe wireless on or off. Normally you would Press and Hold the FN functionkey located at the lower left of the keyboard, then hit the correct F1 thru F12key that toggles the wireless. The correct F1 thru F12 key to hit willhave the wireless signal icon )))) on it. Or it might have the icon of a towerwith the wireless signal icon )))). Normally the screen will displayWireless On or Wireless Off when you toggle the wireless.
Jun 05, 2012 | HP Computers & Internet
How can I switch my wireless LAN on?
Jun 05, 2012 | Sony Computers & Internet
My wireless internet switch will not turn on.
The power to the wireless network and bluetooth devices is controlled by a switch or button on most computers. It is possible to accidentally bump the button and turn off the wireless service. c02230159.jpg On most computers, there is an LED light that glows blue when the wireless device is turned on and enabled, and glows orange when off or disabled. Some newer models use different a different color scheme. To turn on and enable the wireless device, do the following:
  1. To turn on the wireless device, simply move the switch to the on position. On some computers, the switch is actually a touch point on the panel above the keyboard.
  2. To enable the wireless device, right-click the HP Wireless Assistant (disabled) icon c02228164.gif and select Open Wireless Assistant . Click Turn On . The HP Wireless Assistant (enabled) icon c02228163.gif will display.
Apr 17, 2011 | HP Computers & Internet
Cannot the wireless internet setup
Hi kschmerer,
I understand that you are not able to setup the Wireless Network Connection in your Computer.
To fix this issue, please make sure that the Physical Wireless Switch on the Computer is turned ON and then try connecting the Computer to the Wirelss Network.
You can locate the Physical Wireless Switch on the front side of the Computer. Please move the switch toward right side to turn it ON.
Once the Physical Wireless Switch is turned ON, please try setting up the Wireless Network Connection.
If you are not able to to connect to Wireless Network Connection after switching on the Physical Wireless LAN Switch, try using the Wireless Switch Setting Utility.
To enable the Wireless Network Connection using the Wireless Device Switch Utility, please double-click the Wireless Device Switch icon on the right corner of the Taskbar. Then in the open Wireless Device Switch window, please click to check the box next to Enable 2.4Ghz Wireless LAN.
This should fix the issue.
Please post back if you have any questions or require further assistance.
Thanks for using FixYa.
Dec 07, 2010 | Sony VAIO VGN-AR150G Notebook
Wireless radio switch
Page 13 will show you the radio switch. It is the 4th button.
Wireless switch Turns the wireless feature on or off, but
does not create a wireless connection.
✎ A wireless network must be set up in
order to establish a wireless
connection.
http://h10032.www1.hp.com/ctg/Manual/c01035586.pdf
Dec 25, 2007 | HP Pavilion dv9000z Notebook
Wireless switch cannot turn on the intel 2200 agb wireless adapter for my laptop
*Assuming that the computer is a windows XP Operated.
Click on start => run => Services = Ok.
On the services window => check the status of the wireless zero Configuration => try switching it 'on' or switch it off and then switch it 'on'. If that does not resolve the issue then it could be hardware failure.
Dec 14, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Lenovo 7734N3U R61 T8100 1gb/160 Dvr 14w Wxp PC Notebook Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
