Question about Mr. Heater MHU45NG
Mr. heater model mhu45 combustion air blower will not start. len on circ uit board blinkiing s times. cleaned flu ahd vent exshaut.
Checked pressure switch and is closed prior to trying to start, still get pressure open led signsl and no cab startup.
  • 138 Answers
On your heater, does it tell you a fault code for the number of blinks?
If you have cycled the power to the unit already, the fault code should have cleared. If the fault code cleared and then came back, sounds like either a issue the blower motor being shot, or a relay in between the ignition controller and or the ignition control is bad, not making the heater do anything.
Posted on Nov 20, 2013
  • 1 more comment
  • robert browning
    robert browning Nov 21, 2013
    t hanks for the feedback. either could be the cause.mr. heater thinks the control board is shot and are sending me a new one via waranty.
  • robert browning
    Add a Commenti
  • robert browning
    i will let you know.
3 Suggested Answers
hotuna
  • 288 Answers
SOURCE: MHU 75 Model Mr. Heater
The roll out switch is a small disc shaped part about the size of a nickle. There may be more than one. anyway there is a button shaped like a small peg in the center if it, push it in and it should stay in. You may need to re examine the limit switch, because this is what it sounds like. they are rated for a set temperature, so your application may need a higher temp. A simple way to check parts like these is to by-pass them by taking the wires off the part and connecting them together. If this solves the problem, that it. My only concern is that this is a new installation, and maybe its not venting adequately or its burning up all the usable air in the room. That's why most of these parts are on the equipment.
Posted on Dec 24, 2007
  • 1015 Answers
SOURCE: I have a Big Maxx
You may very well be right because if the induced draft motor won't come on then the heatin cycle stops there. It makes me wonder about the board because of it doing the same thing even if it's not calling for heat. Thanks.
Posted on May 13, 2011
Replaced switch assy for turn signsl but still won't cancel. 1997 f150
under the wheel there is a small plastic collar with two pins
these pins go up into the steering wheel and activate the action to put the switch in the center position
If the wheel was off check that that collar is installed correct;ly
Feb 19, 2016 | 1997-2000 FORD F150 EXT. CAB 3DR
Code E04 comes up after it cly see ing light up
blower failure. either the blower isn't producing enough pressure, or the air proving switch is faulty, or you have a blockage within the vent or air switch tubing, or if the blower isn't coming on you have a failed relay within the circ board
May 25, 2014 | Pentair Minimax NT Heater
My smart water pilot is on but it is not heating the water tank
GE is Rheem.
Models change frequently.
Copy following link for troubleshoot resources by type of gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Newer water heaters require frequent air intake cleaning.
To do this with Rheem requires removal of combustion parts, and then air compressor to blow out screen.
It is probably time to have a plumber give water heater a catch-up on recommended maintained, such as checking gas pressure, bleeding gas line, checking vent draft, clean combustion parts, clean air intake, check if gas control is working correctly.
Sep 03, 2012 | General Electric GE SmartWater Household...
Is the reed valve part of the pressure switch
relief valve should only open in a over pressure condition. If it is opening prior to reaching pressure ....replace it.
May 21, 2012 | Air Tools & Compressors
I have a goodman furnace GMP100-4 REV B..about a year ago it was not working. The fan would start but it would not ignite. We found out we need a new ignitor and it was a good quick easy fix. Now a ye
Any light flashin on the control board? If not then look for a small fuse blown on the board. See lights a flashing count them flashes
A sampling of various failure codes on a furnace:
Read one LED flash that stays on continuously to mean your furnace has no signal coming from the thermostat and will not operate. Turn the power off and check the thermostat for improper settings or connections.
Interpret one LED flash that blinks on and off to mean your furnace has locked out because it could not ignite after three tries, and must be reset. Interrupt power to your furnace for 20 seconds or lower the thermostat so your furnace does not try to heat, then reset the thermostat to the previous setting. After one hour of lockout, your furnace will automatically reset itself and try to operate as usual.
Decipher two LED flashes to mean the draft blower is not working, or your furnace has a short in the pressure switch circuit. Turn off the furnace power and repair a short or replace the pressure switch.
Read three LED flashes to mean your furnace has an open pressure switch circuit or it has an induced draft blower operating. Check the pressure switch hose of your furnace for blocks or an improper connection. Also, look for blockages in the flue, and tighten any loose wiring.
Translate four LED flashes to mean your furnace has a primary limit circuit open, possibly from loose wiring or blocked filters. Check and clean filters, tighten wiring and check the flue for blockages.
Interpret five LED flashes to mean your furnace senses a flame without a call for heat. This could be from a gas valve closing slowly or a burner flame lingering.
Read seven LED flashes as a warning of a low flame sense microamp signal. This could happen with a coated flame sensor or a lazy flame from poor gas pressure. Turn off the power and adjust the gas pressure according to the information on the rating plate.
See eight LED flashes as meaning an igniter circuit problem due to a bad igniter or an igniter connected improperly. Replace the bad igniter or check the ground wiring, making necessary corrections.
Decipher nine LED flashes to mean the high-stage pressure switch circuit will not close during a high-stage-induced draft blower operation. Your furnace may have a pinched or blocked pressure switch hose, a blocked flue or loose wiring.
Read continuous flashing on the LED to mean your furnace has a reversed polarity of 115 volts. Turn off the power and correct the wiring polarity after reviewing the wiring diagram.
Nov 29, 2011 | Goodman Heating & Cooling
I have goodman GMP series furance the furnance and gas comes on and fires up then goes out flame sensor is good what else could be wrong
Improper ground from control to burner.
Incorrect electrical wiring, check polarity.
Tubing partially clogged between inducer and proving switch.
Oct 18, 2011 | Goodman GMS90703BXA Heater
Richmond water heater goes into lockout condition, ignition failure and I have to turn the blower switch off then on to get the water heater to work. Its getting to be a everyday thing. Also would like to...
Start-point is to inspect and clean burner parts and combustion chamber, clean air intake, bleed air out of gas line, test gas pressure, test electronic gas control valve, check for venting issues.
As general rule, gas water heater manuals recommend professional service once a year that would cover most items listed above.
To see images, and for more reading and resources, look at your product manual and open following link:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Richmond/Rheem sells power vent blower assembly that cost about $300.
Your product manual shows part numbers.
http://www.monstermarketplace.com/heating-supplies/rheem-sp12562-blower-assembly-powervent-2
Replacement gas control valve costs $300
Aug 16, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
I have a 50 gallon rheem direct vent natural gas heater. The pilot light goes out on an infrequent but aggravating basis. I replaced the thermocouple one time and it got better for about a year but has...
Open following links for pilot light help:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/images/Negative-pressure.jpg
http://waterheatertimer.org/pdf/Bosch_Ventilating_tight_houses.pdf
Since pilot light goes out and can be re-lit, problem is probably not thermocouple, gas control valve, or air in gas line. But these things can factor in as contributing factors.
Problem is likely one of following or combination of following including dirty burner parts, tight house, incorrect vent lengths, negative pressure caused by other venting appliances, condensation dripping down into combustion area, and inadequate oxygen supply due to hot or closed-off room or attic location.
Gas water heaters draw air from surrounding area. If water heater is located inside house, then air has to enter home through cracks and when doors and windows are opened. Other gas appliances and vent fans also draw air from same indoor area. When other vent fans turn on, air can be drawn down the water heater vent and blow out pilot light.
Inspect combustion chamber to make sure there is no condensate water dripping down from incorrect vent that is putting out flame. If combustion chamber is dry, then close doors and windows. Turn on all vent fans and gas appliances that vent outdoors, and see if water heater pilot goes out.
Consult with plumber or product manual about proper horizontal and vertical lengths of vent pipe for your model. Have plumber clean combustion parts and inspect vent termination and check gas pressure and bleed gas line.
Add louver opening to outdoors so air can enter room where water heater is located.
Aug 05, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a Big Maxx heater that about 4 months old,and it started to act up, when I checked the circuit board I have three flashes. I removed and checked the pressure switch and that checks out fine, I get...
May 13, 2011 | Mr. Heater Natural Gas Garage Heater -...
Suddenly not working im not sure if there even is a pilot to be lit
Goodman have troubleshooting idiot lights on the board. Look for flashes and count em.
The flash explanations are printed on the backside of the blower cover on most models.
Feb 03, 2011 | Goodman Heating & Cooling
Mr. Heater MHU45NG Logo
273 people viewed this question
Top Mr. Heater Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
