Question about ASUS CUWE-RM (CUWERMSWA) Motherboard
Have no Display
My Board was working fine for 3 months, after same time i didn't use my pc, and when i wantz to start it powers on (red light on thE board), but don't have display and also my hd's doesn't start, i have demounted all and try to configured the processor manually but it won't help, also using different SIM: 133 or 100 doesn't help. My Processor is : 667/256/133 (written on) Please give advice. Thank you very much in advance.
You may refresh your bios
to do this remove your motherboards battery then conncet the +ve and -ve terminal of socket together
Posted on May 03, 2009
    Habit-Forming:
  • 188 Answers
1 st set all parts currectly on its place.. properly.... now try to start u r pc.. if it doesnot work. ur windw may be cuureped man ....re instollation may solve ur problem.. best regards.. & best of luck mail-add- sigma_shiva1@yahoo.co.in
Posted on Oct 10, 2007
Power button blinks red seven times on a 2007 Panasonic flatscreen VIERA.
I had the same problem with my Viera. if you disconnect the power and ribbon cable from the YSUS board (check youtube for how), the light led will blink 6 times, indicating the YSUS is bad. Check ebay for TNPA5175 board (about $115-160). The "pop" is one of the DG402RP chips burnout. These are about $4, but only available from China. If you can wait a month for delivery, you can solder the new one to replace the bad one. You may want to purchase several in case more are bad or it happens again.
Jan 15, 2013 | Panasonic VIERA Televison & Video
Nordic track 1500 treadmill with no display and there is only a red blinking light on the circuit board
1( tight the ribbon cable and clean it,
2) tight the plug from display board , and clean it.
3) tight the display board vs lower board and clean it unplugged the power
4) test the fuse and replace if necessary or c.breaker reset.
5( Finally adjust the REED SWITCH , clean it and tight the plug very well see the diagram attached.
6) see the block attached. finally the display board can be faulty.
God bless you
Sep 30, 2012 | Nordic Track NordicTrack Commercial 1500...
T.V. comes on for a few seconds, the green light at the bottom blinks 3 times and then the power goes off. I tried unplugging the t.v. overnight but that didn't help. the t.v. is exactly 3 yrs old...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck in solving the problem....
Jul 06, 2011 | Sylvania LC370SS8 Television
Had a power outage and believe a surge was sent through our dryer. Breaker is fine and have the correct voltage. The board lights up but no display in the estimated time remaining and will not start....
Ours did the exact same thing after a power outage. Our repair guy has been out 3 times, first he replaced the power board, then the motor and blower! He has to come back again with a moisture sensor now. Im begining to think he doesnt know what hes doing! By the time hes finished I will have replaced all the inside parts, Im afraid. Our dryer is only 16 months old. Did you ever get yours going? Any advice?
Jun 12, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
I have a hp a350 cpu.the problem is that the light of led has gone red,as before in working condition it was green. It can't start.the power to hardisk is also not coming.please tell a sollution.
As you say has become red and no power to the hard disk.
First check the power cable for any loose connections and check if it give power to the cpu and the fan placed on processor starts working as you start the power. If fan it starts and with in few seconds stops then your power supply/SMPS is weak or damage. So replace it for proper working of your computer. And if after power on all fines but red led on monitor and no power to hard disk Try to replace the hard disk power cables because they are not working because of it no operating system is detected and led of monitor is red. After replacing hard disk cables hard disk starts working and still no display or red led on monitor check the vga cable for loose connection or replace it.If you are using vga display from graphic card try to get display first from onboard vga slot.After it your problem will disappear and your pc run smooth and fine.
Aug 27, 2010 | HP Compaq d530 SFF PC Desktop
My t2200 emachine has power,the fan on the cpu works,the power supply works,the drive work,there is a red light on mother board but my display is black,display works fine with other pc. keyboard blinks...
Could be a RAM error. try cleaning the contacts of the memory module before re-inseirting it, or you can try and swap with another if its available
Apr 03, 2010 | eMachines T2200 PC Desktop
ViewSonic N3250w
The defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Turns OFF by itself.
Needs to be unplug to make it work.
Works for a few minutes then turns OFF.
I repair these power supplies, if you need further assistance jah2mil@hotmail.com
Aug 22, 2009 | ViewSonic N3250W Television
Jenn Air Range SVD48600W (Circa 1998?)
ja_question.gif Why are the oven indicator lights flashing? Answer: When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
Mar 17, 2008 | Jenn-Air SVE47100 Slide-In Electric...
ASUS CUWE-RM (CUWERMSWA) Motherboard Logo
66 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
