Question about Octane Fitness Octane Q47 Elliptical Trainer
OCTANE ELLIPTICAL HAS A SQUEAK - Octane Fitness Octane Q47 Elliptical Trainer
Our Octane elliptical is showing a brake cable error and looking for suggestions. Thanks!
It could be that the brake is faulty or just the cable has been pulled out. It could also mean the motor is faulty. You will need to have a tech look at this.
877-805-1030
Book An appointment
Mar 01, 2016 | Exercise & Fitness
Octane elliptical brake cable
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 01, 2016 | Octane Fitness Q47ci Elliptical Trainer
How can trun on the octane fitness q37e
There is no on/off switch, if that is what you are asking. If it is plugged in, it should be turned on.
Mar 22, 2014 | Octane Fitness Q37c Elliptical Trainer
Need manual
Front right side - it may be hard to find - easier if you tilt it up a bit.
Dec 12, 2013 | Octane Fitness Octane xRide xR6 Seated...
Octane fitness q47ci shows a "break error"
Hello, I have this problem now. Did you get an answer?
Thanks!
skr125@gmail.com
Sep 18, 2013 | Octane Fitness Q47ci Elliptical
Error 20 on Q47 Octane Eliptical
Sounds like it needs to be fixed. It will need a new left motor and cord most likely, less likely a lower board.
Apr 14, 2013 | Octane Fitness Octane Q47 Elliptical...
My Nordictrack E9.0 Elliptical machine has a loud squeek
I have found a possible source for your squeak. I have the same elliptical and had an annoying squeak in the front end of the machine. The squeak could be coming from the roller arm flex bracket and/or the pedal arm flex bracket. These brackets are secured to the front of the roller arms and the pedal arms with a single bolt. Tightening these bolts may help get rid of the squeak. If you don't have your manual, you can download the manual at the nordictrack website. The manual will have an exploded drawing of the elliptical. The roller arm bracket and the pedal arm bracket are numbered 135 and 136 and you will see which bolt I am talking about. I have had numerous issues with my elliptical but after changing some parts under warranty, it is working like new. Good luck.
Mar 19, 2013 | Exercise & Fitness
My elliptical trainer is starting to squeak. What should I do?
Don't worry; this is a common problem in elliptical trainers. Over time, parts of the machine may start to squeak. I am going to attach a how-to guide that will explain what to do when this happens.
http://www.livestrong.com/article/269134-how-to-stop-an-elliptical-from-squeaking/
Aug 02, 2012 | Exercise & Fitness
Is it better to get an elliptical machine with ball bearings or bushings?
Elliptical machines with bearings at the pivot points will ultimately be more reliable and durable than those with bushings. Bushings will squeak and over time they will break down. You should look for a machine with sealed ball bearings. They are protected from dirt and do not require lubrication.
The ZE5 elliptical has developed a loud annoying repetitive squeak. Any suggestions to get rid of that?
You could try lubricating the moving parts. Sometimes the bearings and the connecting parts can become dry. If lubing does not work, it may simply be time to replace a bearing or bushing.
Silicone Spray Lube by SPORTSMITH 9 Oz SPORTSMITH net
Jul 15, 2012 | Precor EFX 546i Elliptical Version 4
Octane Fitness Octane Q47 Elliptical Trainer Logo
187 people viewed this question
Top Octane Fitness Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Octane Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
