Question about Whirlpool Gold GW399LXU Gas Range
Whirlpool oven How do I fix my whirlpool oven and broiler
  • 26 Answers
Need more details
Posted on Nov 20, 2013
4 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: baking element not working
If you have already replaced the bake element (which would have been MY first logical choice) and it still does not work, the problem is more likely with the Electronic Clock Control. The control has two separate circuits that will select and turn on either the bake of the broil elements. It is usually a defective relay that causes the particular mode of choice to stop working. The part number for the ECC is 1166040 and costs about $128. It's not a cheap fix, but it would cost you much more if you had a service man fix it for you. Unless...of course, you still have a warranty. Most manufacturers cover all parts from defects for the 1st year. Some parts are covered longer than the initial warranty, however. It may be worth you while to double check your purchase date and appliance paperwork. This repair is not difficult and can be accomplished by the average do-it-yourselfer. If you decide you want to repair the appliance on your own, let me know and I can give you step-by-step instructions on how to do it.
PS Double check the wiring from the ECC to the bake element as well. You could have a broken wire causing the same symptoms too. Also, don't be alarmed by the failure of the ECC. Although they are generally reliable for quite a number of years, they have been known to fail during electrical storms and/or power surges. Something else you may consider: check your home owner's insurance policy to see if it covers the loss of appliances in the event of such incidents. I hope you find this information helpful.
Posted on Jan 24, 2008
  • 1314 Answers
SOURCE: Whirlpool oven
if you get down to the control panel first try plug and unplugging all the connectors as resistance can cause this in the connectors next take the Mylar ribbon off the control and clean it softly with a pencil eraser as the touch pad malfunction can cause now if you have an ohm meter you can ohm the oven probe it should be 1200 ohms at 70 degrees room tempture if all this fails to fix it then replace the controls bd ive seen too many techs too quick to replace a 200.00 control board just because the eoc spouts out an error code
Posted on Jan 30, 2008
TheMobilian
  • 8220 Answers
SOURCE: Whirlpool Super Capacity 465 the oven/broiler does not come on.
More than likely a bad ignitor
Here is how to tell If the ignitor is glowing it should be VERY bright, if it is dim orange it is weak and bad.
Posted on Jan 08, 2009
Whirlpool Gold Series stove. When turning on the oven to pre-heat, the broiler came on and we got a fault saying FAULT - PRESS ENTER TO RETRY.
Appears the burner is faulty, check connection at burner receptical first then check with meter for opens. Here is the Whirlpool link for parts repair manual etc. https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.whirlpool.com/services/replacement-parts.html&ved=0ahUKEwiCvdH97rDTAhVk7IMKHX4gAtMQFghZMAA&usg=AFQjCNEsdfUwvP3qyVcDj7qJikAtiHTfUQ
Apr 18, 2017 | Whirlpool Kitchen Ranges
My whirlpool electric LGEF3045KFC oven will only heat to 191 degrees and the broiler does not work
I would suspect the broiler element has burnt out . calling a repair man , might be the quickest fix .
Oct 12, 2015 | Whirlpool Kitchen Ranges
Whirlpool sf315pepw1 oven and broiler not working, changed ignitor, still nothing.
i have same oven bad main gas valve 150 dollar fix sorry for same bad luck
Dec 07, 2014 | Whirlpool Kitchen Ranges
Whirlpool electric range oven broiler not working
Hello. This is a common failure for this range. Replace part number
9762215, price varies but about $100 average.
Apr 07, 2014 | Kitchen Ranges
Whirlpool gas oven Model sb160peeb5 Broiler lights but the oven does not.
Sounds like you need a glow coil ignitor. The broiler and the oven have seperate ignitors. You can pick up one from First Source parts house.
Jul 16, 2011 | Whirlpool Ovens
Oven won't heat
The only reason I know the answer to your question is because I am having the same problem. Our appliance quit working after we used the cleaning option. Both the bake and broiler quit at the same time. Our local repair man said that the problem is caused from a malfunctioning thermostat, which is about a $300 fix.
May 18, 2009 | Whirlpool RBS245PD Electric Single Oven
Oven broiler and auto clean not working.
if the oven broiler isnt working self clean wont either check the broiler element to see if its burned out pretty easy to replace most of the times you can replace it from inside the oven be sure to turn the power off then remove the two retainers from inside and pull element out
Jan 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool SF315PEPW1 oven/broiler won't work
whirlpool range/over the broiler works the oven does not warm up. what is the solution.
Oct 24, 2008 | Frigidaire FEB24S2AB Single Oven
Whirlpool Gold GW399LXU Gas Range Logo
98 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
