Question about Malibu Intermatic Inc. ML300RTW 300-Watt Power Pack with Timer and Ground S
TIMER IS NOT MOVING - Malibu Intermatic Inc. ML300RTW 300-Watt Power Pack with Timer and Ground S
My dryer timer is not moving and the isn't heating up
From the info. you gave it sounds like the timer motor is defective.
If the timer motor is not moving it stops the heating element from activating.
Oct 03, 2014 | Amana Dryers
White knight tumble dryer timer sticking at 80minutes and not moving to cool clothes
Have had the same problem with the timer sticking on the model and the same time interval, now don't trust it's safe to use at any setting over 60minutes
Jan 06, 2013 | Abbaka White Knight 44AW Electric Dryer
Won't run through cycles
If the timer is moving I'd just buy a new one.
If the timer is not moving, that's probably it. They are easy to find and easy to install.
Cheers.
Dec 12, 2011 | Washing Machines
Maytag Performa will not turn on. (4 Years old) There is power to it. You can hear a fainting clicking of the timer when you dial a setting
Have you tried moving the selection switch a hair at a time while in the ON position? The timer may be corroded -- if you can get to it it is easy to see the points and clean them with sandpaper or file. If so, the timer is moving but is not making a connection due to crud.
Dec 04, 2010 | Dryers
Machine is not moving through the cycles
It sounds like the motor in the timer is bad. This may require replacing the whole timer or just the timer motor in some cases. I hope this helps.
Mar 20, 2010 | Whirlpool Washing Machines
It takes longer to dry clothes than usual and the timer control is not moving or stays in one place
The timer is shot and the contacts are not moving so the heating element sensor will cut the heat off for saftey reasons which is equipt in dryers these days
Jan 24, 2010 | Dryers
Not drying clothes
The timer is the principal initiator of this unit. if it is not moving, this will confirm that there is a major issue that concerns the timer motor. This damaged timer mechanism should be replaced asap.
Jul 30, 2009 | Whirlpool WED6400S Electric Dryer
The Cycle selector Knob of 417.42052100 is not moving itself. Machine stays in the washing action without moving automatically to the next one
The timer motor is bad. I am assuming that you can move the timer by hand and access all cycles. Usually this means a whole new timer. You can try to order the motor seperately but it is usually not available alone. The new timer can cost around $100. Why don't you try a used appliance store and see if they will sell you one. The timer motor is fairly standard. The timer itself is not. Just buy a used timer and swap motors.
Jul 05, 2008 | Kenmore Washing Machines
Will not drain or spin
Unless you jarred the machine it's the timer. You can check this by bypassing the lid switch and seeing if it will cycle.
Dec 13, 2007 | Washing Machines
DRYER TIMER NOT MOVING
you need to replace a t-stat. the one with 4 terminals on it. i believe its the adjustable t-stat
Jan 23, 2007 | Maytag Atlantis MDG6400AW Gas Dryer
Malibu Intermatic Inc. ML300RTW  300-Watt Power Pack with Timer and Ground S Logo
48 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
Scott Jelt
Scott Jelt
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
