Question about DeLonghi Nespresso EN720.M Espresso Machine
DE LONGHI EN720MHOT WATER NOZZLE NOT WORKING - DeLonghi Nespresso EN720.M Espresso Machine
  • 6 Answers
SOURCE: De Longhi E4 error
Basuda! Sorry! Cheaper to get another one than to fix!
Posted on Nov 14, 2007
SOURCE: De Longhi DE220 De-Humidifier not collecting water
Hi there - you have to vacuum the filter several times. You can pull it out of the back left hand side of the unit. Vacuum it several times, and then start the unit on the lower fan setting, at a humidity level of around 60%. It will kick in after a bit, and then you can start adjusting the humidity level to where you would normally use it.
Sometimes - after you have vacuumed the filter, it still doesn't work. I used my fingers to pick lint off the filter, and ran a BIC safety razor over it as well, to try and get more out of the filter. You can also wash the filter in warm water, and leave it to dry over night. Don't put it back in until it's completely dry.
This will work! Cheers... E
Posted on Feb 08, 2009
  • 4736 Answers
SOURCE: DE' Longhi Dehumidifier - Model:
If you're saying the dehumidifier is not extracting moisture from the air?
There are 5 basic, yet solvable reason for this. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If yours is a manual unit, turn
the control knob to Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope this helped you to troubleshoot and solve the problem.
Posted on Jul 15, 2011
  • 181 Answers
SOURCE: how to fill with gas
You shouldn't be using R22 anymore as it is being phased out and is bad for the environment. If it is not working, you might want to call in a pro to do the job. They'll have to hook up the dehumidifier to a manifold to essentially **** all the R22 out, ensure that there are no leaks, and replace it with a R22 substitute. It's going to take a few hours, so be prepared to pay $$$. The alternative is to bring it to a municipal recycling center or whoever that will accept it and buy a new one. You can't just throw it away.
Posted on Aug 10, 2011
heatman101
  • 43501 Answers
SOURCE: De Longhi dehumidifier DD40P Not
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on Aug 13, 2011
De longhi coffee machine- coffee pours into the middle of machine, not through spout
the main feed line ( is probably disconected to the spout ... take of the top ( screws ) and look for the feeder line normally they just put a tie rap on the edge of it ... might of come apart so now its not going true the main line and get water all over the place ;)
May 11, 2017 | Coffee Makers & Espresso Machines
Tip
Air Conditioner User Manuals
Air Conditioners:
Pelonis units are manufactured by Midea Group. You will need to contact them for the manual they can be found at the following link:Download
or Via their contact page (depending on your country):Download
De' Longhi
De' Longhi PAC A120E Portable Air Conditioner Download
De' Longhi PAC C120E Portable Air Conditioner Download
De' Longhi PAC T110P Portable Air Conditioner Download
De' Longhi PAC WE125 Portable Air Conditioner Download
on Jun 08, 2011 | Heating & Cooling
I require an instruction manual for a de longhi microwave - MK9 2NW
I would return it to the store where purchased . get your money back and buy a different make from a different store
Mar 30, 2015 | In Microwave Ovens
Can the De Longhi dual range cooker be converted to kpg
That information will be in the installation and or instruction manual along with the relevant info required by the fitter
Jul 04, 2014 | Kitchen Ranges
Can the De Longhi dual range DF S903 be converted to lpg
Go to the web page and find out. Easy peasy.
De Longhi dehumidifier DD40P Not collecting water.
heatman101
Jul 27, 2011 | DeLonghi Dehumidifiers
Sep 12, 2008 | DeLonghi DE500 Dehumidifier
Lost screws for a De Longhi oil filled heater.
To whom it may concern
Yesterday, I communicated with one of your colleagues by the name of Ginko. He advised me to contact the factory in New South Wales, Australia by phone and e-mail.
I rang through and they weren't particularly helpful. They said call a service agent with the details of the product, I was supplied with a contact phone number. The service agent was unable to help me, they said they would call back and as yet they haven't.
I also had sent an e-mail to the the customer service reprentative for De Longhi, who responded the following day, and gave me a list of five outlets in Melbourne, which are able to order the part for me. I duly contacted the nearest supplier to myself, rang them and they said they will order the product (after taking down the product details and my home phone number) and will contact me when it arrives.
Thanks to Ginko for his time and help. I will wait to see the outcome of this. This is the most recent update to the situation.
Jul 20, 2008 | Heating & Cooling
De Longhi E4 error
Nov 06, 2007 | DeLonghi CF210 Portable Air Conditioner
DeLonghi Nespresso EN720.M Espresso Machine Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
