Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
My refrigerator isn't cooling well. The freezer isn't freezing at the top only the bottom.
It didn't make any ice over night either.
  • KitchenAid Master
  • 2,180 Answers
If it's just cold at the bottom and warm up top it sounds like you have a bad evaporator fan motor in the freezer side,when you open the freezer door do you hear the fan blowing?if not bad fan motor,this happens when the fan motor is bad because heat rises and cold air sinks.part number : 2259385 and it's around 60 to 70 dollars
Posted on Nov 20, 2013
  • Sal DeAngelo Nov 21, 2013
    how did you make out with your fridge?
machinetech7
  • 1344 Answers
SOURCE: 15 month old Kitchenaid french door refrigerator - water pooling and freezing on the bottom of tthe freezer. Seems like the grids on back wall may be the culprit, as after ice is removed they seem to
more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. Over time it gradually builds and starts voer a larger area. Being you have a top mount refrigerator(freezer on top) there are air ways that connect the freezer to the fridege, which is how its cooled. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt
If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble.
Note that on your machine you should pull the machine away from the wall so you can get behind it and remove the lower panel. Locate the drain tube that runs from the freezer, usually a black or white tube, and at the end verify it there is a rubber piece that looks like a duck bill of you will. If it is there, grab said piece and remove it from the drain line. This is the cause of the water not draining out of the freezer
Posted on Jun 20, 2012
  • 93 Answers
SOURCE: my refrigerator won't stay cool but my freezer works fine
You have something wrong with the vent going from the freezer to the fridge. You probably have a defrost problem and ice is blocking the vent that goes from the freezer and comes out in the roof of the rerigerator compartment. Replace your defrost timer and bimetal.
Posted on Sep 11, 2009
  • 10 Answers
SOURCE: Kitchenaid KSRA25IL Freezer working Fine - Refrigerator not
I had a similar problem where the refrigerator side was not cooling well but I could feel very little air coming through the vent in the top left corner.I blew hot air from a blow driver into the vent for about 1 minute which melted ice that was hanging from the bottom of the vent cover.Cold air started blowing harder thru the vent and cured the problem.
Posted on Feb 16, 2009
rayname
  • 70 Answers
SOURCE: Freezer on the bottom model # PBF2555HEW Freezer works refrigerator not cooling at all
I replaced my evaporator fan behind panel in freezer this was not spinning had to remove ice maker and panel to access got parts list emailed from kitchen aid and picked up part at local appliance dealer
Posted on Jan 03, 2009
SOURCE: refrigerator side not cooling - freezer side icing up
I have repaired my Sears refrigerator/freezer many times since I bought it in 1971. Recently, the refrigerator freezer section started to ice up and the temperature in the freezer started to slowly rise to about 20 degrees F and would not go any lower.
This happened once before and it turned out to be a defective Defrost Timer.
This time the problem was a defective Bimetal (Temperature Switch) that shorted against a metal tube in the refrigerator.
I replaced the Bimetal and now the refrigerator is fine - no frost and it now goes down to 0 degrees F, as it should.
I have taken a series of photos of the problem and repair of my refrigerator plus a schematic diagram. Follow this link for all the photos.
http://www.esnips.com/web/RefrigeratorProblem
Also, make sure that you don't cover any holes or vents that are in the freezer section
Posted on Jul 02, 2008
Frigidaire Refrigerator FFTR1814LW bottom fridge not cooling properly 50 degrees. The top freezer is rock soild Thx
That is the classic symptoms of a defrost system failure. Suggest you look behind the rear panel on the inside of your freezer and see if it is iced up. If it is then it is a defrost problem which could be the defrost heater, defrost thermostat or defrost timer. If it isn't iced up, then check to make sure the fan is operating. If it isn't then it won't push cold air out of the freezer into the refrigerator section.
Sep 14, 2011 | Refrigerators
Gss25xsrd ss GE fridge gets warm on the top (both fridge and freezer side) and freezes at the bottom. Ice completely melts and veggies in the drawers freeze too.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 26, 2010 | Refrigerators
Amana, bottom freezer, freezer not freezing and then refrigerator not keeping cool.. help Started with the ice maker not making ice, the sound of trying to pull water but never any ice. Then the freezer,...
Hi
Firstly put off the refrigerator before the compressor burns off.
The problem is simple... the coling gas has leaked out.... put new coolong gas...BUT only after finding the place of leak... this will be needed to be fixed first.
Regards
Berry
Feb 07, 2010 | Amana ABB1927DE Bottom Freezer...
Bad defrost timer/ thermostat???
It definitely sounds like you have a bad defrost timer, that is the reason the coils are icing up on you. The next issue, which may or may not be related is the freezing of items in the refrigerator. Usually the cold air is transferred, through a vent with a damper, from the freezer and into the refrigerated section. The "thermostat" for this section is actually usually just a lever to adjust the position of the damper. That being said, usually when you have a problem such as you are having, it is either a stuck or broken damper (or damper component). Hope this helps
Nov 16, 2009 | Kenmore 21.9 cu. ft. Bottom Freezer...
Subzero freezer has frost/ice build up on the
Check the fan and readjust temperature control to higher. Thanks.
Oct 22, 2009 | Sub-Zero Bottom Freezer Refrigerator
Bottom of refrigerator will not cool...while the freezer over freeze and packed with ice
What you have is a defrost problem. Most likely the defrost heater has failed. Read more about it HERE
May 16, 2009 | Frigidaire Freezer GLRT183TD
Top of the freezer will freeze but bottom want
Could be same as problem I just fixed.
Remove back panel inside freezer and
1. check fan operation
2. check for ice/water at bottom of the hidden section. There should be a drain hole, which may be blocked by ice. Fix by turning off and pouring boiling water in there until blockage is fixed
See http://www.fixya.com/support/t1507330-ice_collects_in_bottom_freezer
Dec 26, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
160 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
