Question about Whirlpool Gold GW399LXU Gas Range
Whirlpool oven or broiler won't work - Whirlpool Gold GW399LXU Gas Range
TheMobilian
  • 8220 Answers
SOURCE: Whirlpool Super Capacity 465 the oven/broiler does not come on.
More than likely a bad ignitor
Here is how to tell If the ignitor is glowing it should be VERY bright, if it is dim orange it is weak and bad.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 08, 2009
heatman101
  • 43501 Answers
SOURCE: My whirlpool model # sf360bee oven won't light.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on Jul 24, 2010
  • 24 Answers
SOURCE: whirlpool accubake sf367lxsq top burners work oven
You need to check for continuity between the bake relay output terminals and the broil relay output terminals. If the bake/broil function is supposed to be on and there is no continuity, your board must be replaced/repaired. The company I work for, ApplianceTimers.com can repair your failed board. If there is continuity, you have a shorted external wire(s) or element.
Posted on Mar 18, 2011
  • 2006 Answers
SOURCE: WFG381LVS-broiler and over won't light
Gas valve PART NUMBER: 9761959
$108.58
In stock
Qty: pd_0022_664_9761959?op_sharpen=1&qlt=100
Posted on Jul 05, 2011
  • 186 Answers
SOURCE: Whirlpool oven won't light
check the bulb in the oven
or oven light wsitch look more to the bulb
Posted on Aug 02, 2012
Whirlpool Gold Series stove. When turning on the oven to pre-heat, the broiler came on and we got a fault saying FAULT - PRESS ENTER TO RETRY.
Appears the burner is faulty, check connection at burner receptical first then check with meter for opens. Here is the Whirlpool link for parts repair manual etc. https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.whirlpool.com/services/replacement-parts.html&ved=0ahUKEwiCvdH97rDTAhVk7IMKHX4gAtMQFghZMAA&usg=AFQjCNEsdfUwvP3qyVcDj7qJikAtiHTfUQ
Apr 18, 2017 | Whirlpool Kitchen Ranges
Whirlpool electric range oven broiler not working
Hello. This is a common failure for this range. Replace part number
9762215, price varies but about $100 average.
Apr 07, 2014 | Kitchen Ranges
Oven won't come on
Test the temperature sensor in the oven to make sure it ohm's out between 1060-1100 ohms. Here is the sensor to order in case it is bad.
Nov 30, 2012 | Whirlpool Electric Range
Aug 01, 2012 | Whirlpool Kitchen Ranges
Whirlpool Range model RF386PXGQ2 broiler won't shut off
Hi.
If the element does not turn off, possible faults are:
Shorted temperature probe.
Test temperature probe reading impedance. If impedance is zero or lower than 0.500 Ohms, the the probe is shorted. A good probe reads about 1KOhms.
Contact at element. A contact in element wiring harness may cause the element to stay on. Do continuity test between ground and element and on wiring harness.
Defective control module.
If problem is none of the above, then it is the oven electronic control(ERC). The ERC can be tested reading voltages.
Testing must be done by a trained technician.
Dec 13, 2011 | Whirlpool RBS305PD Electric Single Oven
My broiler won't work on my 2006 whirlpool range model werp3101sq serial number RT110117. The manual does not indicate where the fuses are making it difficult to troubleshoot. A direct call to the...
The igniter is the first thing that goes bad on the broilers or the oven you need the igniter, it is the part next to the burner is towards the back and it lights up first it glows that's the part that's bad which is the igniter
Dec 02, 2017 | Whirlpool Kitchen Ranges
Oven broiler and auto clean not working.
if the oven broiler isnt working self clean wont either check the broiler element to see if its burned out pretty easy to replace most of the times you can replace it from inside the oven be sure to turn the power off then remove the two retainers from inside and pull element out
Jan 29, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool SF315PEPW1 oven/broiler won't work
whirlpool range/over the broiler works the oven does not warm up. what is the solution.
Oct 24, 2008 | Frigidaire FEB24S2AB Single Oven
Whirlpool Gold GW399LXU Gas Range Logo
43 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
