Question about Craftsman Garden
Craftsman gas chainsaw will not start
Changed spark plug, cleaned air filter, fresh gas still will not start
    New Friend:
  • 22 Answers
Back to the basics-- Make sure there you have Compression, Spark and Fuel. If you have the three basic necessities and still not able to start than we can be 98 percent sure your problem is in the carb.
Remove Carb, with proper eye protection, spray several blasts of Carb cleaner in every hole, inlet and outlet several times. Be sure to open / close throttle while doing so.
Before evaporation of cleaner takes place, use compressed air and blow out while following the path application of the cleaning solvent.
Some people say to remove carb, disassemble and soak over-night--I don't ever have time to do that-- Do you? Probably not. This should work out just fine.
Re Assemble
Posted on Apr 28, 2014
2 Suggested Answers
dan5268
  • 542 Answers
SOURCE: My craftsman push mower won't start, I changed the spark plug, I need to download the owners manual for help. The model @ is 917.373981
Here is the manual for your Craftsman
Posted on Apr 11, 2012
Craftsman gas chainsaw won't start
Spray a little starting fluid in the carb. If it still won't fire look at the ignition parts.
Nov 19, 2013 | Craftsman Garden
16.5HP Honda engine wont run
An engine needs fuel air and spark to run. Is the air filter clean. Use a "spark checker" to see if you have spark. They are not expensive and available at stores that sell lawn mower parts. Is the spark plug clean? If it is not clean it with a wire brush.Squirt some starting fluid into the carb. If it fires your gas has gone bad or it is not getting gas. If it has sat a while gas does go bad so drain the fule tank and out in fresh gas.
Sep 05, 2013 | Craftsman Lawn Tractor Operators Manual...
Sears Craftsman mower 17hp Briggs & Stratton engine. Replaced starter, spark plug and fuel filter. Will not turn over unless jump started. When running has no power.
Charge battery to 12.8 volts or higher. 13.2 best. Below 12.8 volts replace battery. USE FRESH GAS ONLY. Always use Stabile in gas. Ensure oil is full. 30w. Clean or replace air filter.
Aug 03, 2013 | Craftsman Garden
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
Craftsman chainsaw has no power
I would first check your muffler and screen in muffler to make sure it's not partially plugged. Personally I think it sounds like a fuel delivery problem,I would make sure you change your Fuel filter and check your lines for being cracked and or collapsing from ethonal in gas these days. then I would put fresh gas in it and see if it helps.you also need to clean carb and then readjusr carb after cleaning carb
Jan 02, 2012 | Garden
14" Mac Cat gas engine won't start. Changed spark
Check tank fuel filter. safe way, put hose on end of filter blow through hose, fuel should come out of filter easily.
Sep 04, 2011 | McCulloch Garden
Craftsman hand held gas leaf blower will not start. I have put in fresh gas, changed spark plugs, cleaned the gas filter, tested for spart and it does spark, changed the air filter but all this and still...
If it has a spark then try spraying some starter fluid on the air filter. If it attempts to run then the carburator is stopped up. If it doesn't then you most likely have low compression. Remove the spark plug and screw in a compression tester and pull the starter a few times. It has to have no less than 70 psi to fire and run. 90+ would be even better. If it is 50 and below try pouring a little oil in the spark plug hole and repeat the test. If it improves a little then you have a scored cylinder or piston or stuck or broken piston rings. Let me know what you learn and I'd be glad to walk you through some more.
Nov 04, 2010 | Craftsman Garden
No fire craftsman chainsaw
magneto tested for spark with no positive result.
Aug 24, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Poulan 3500 wont start
Try putting in fresh gas. Change spark plug. Clean out air filter.. Check choke for proper operation. Make sure it is getting spark and fuel.. Hope that helps dont know what you have done to the saw.
Jul 06, 2009 | Garden
Garden Logo
61 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
