Question about PowerBase Car Audio & Video
Powerbase 855053 carbon brushes - PowerBase Car Audio & Video
3 Suggested Answers
headstrong56
  • 493 Answers
SOURCE: How do I replace the carbon brushes in PowerBase Router 873980
like most power tools if you remove the housing you can see where the old brushes are. They are usually spring loaded and held in place with a screw. be careful removing the old ones and replace the new ones in the opposite fashion of removal
Posted on Jul 13, 2012
  • 35 Answers
SOURCE: Motor carbon brushes
hi try potts in derby babbington lane ,very help full
Posted on Apr 09, 2013
Need brushes for a 111409-01 branch wizard
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
May 03, 2014 | Remington Electric Chain Saw
Brushes angle grinder
First try a good hardware store. Take out a brush and take it with you to match it up.
Apr 28, 2014 | Saws
Trouble starting
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Apr 19, 2014 | Remington Electric Chain Saw
Extremely weak motor model 108526-01 remington
Feb 12, 2014 | Remington Garden
Are brushes available for remington 106890-02
Nov 06, 2013 | Remington Electric Chain Saw
Apr 08, 2013 | Sanyo Vacuums
New blades for powerbase planer
'Guest' is looking for help with a Powerbase planer - giving him instructions for Makita and DeWalt is hardly likely to help!
I too have a Powerbase and need to find the manual - anyone?
Aug 05, 2012 | Tools & Hardware - Others
Jul 13, 2012 | Washing Machines
Coleman Powermate Powerbase 4000 -no AC Need Field test procedur
Check the voltage sent to the field when running. It will probably be around 12 volts. You can try connecting a lantern battery BRIEFLY to the field to re-magnetize the field. Try bothe polarites.
Some have had a bad rectifier and one had a bad transformer that generaates the low voltage from the generated output. He had a broken wire from the winding to the wire from the transformer. He was able to reconnect the failed solder joint.
Apr 16, 2010 | Coleman Powermate Premium Plus 6250W...
Engine runs but no power aat outlet????
Start with brushes and rings. Make sure your rings are clean and the your brushes have a good length. Flash the fields with 12V battery. Apply positive to the brush nearest the bearing and negative to the back brush, while genset is running. Use rubber gloves when doing this and keep hands away from rotating parts. You should see the voltage climb when you flash the fields. This would mean that you need a voltage regulator. If voltage does not climb, then you will need a new genset.
May 15, 2009 | Coleman Electrical Supplies
Car Audio & Video Logo
108 people viewed this question
Top PowerBase Car Audio & Video Experts
xxxxxx xxx
Are you a PowerBase Car Audio and Video Expert? Answer questions, earn points and help others
