Question about Vizio VBR220 Blu-Ray Player
Under the network section it does not say wireless anymore
Is there a wireless switch on my Gateway Desktop, and if so, where?
If your Gateway desktop has wireless it is probably automatically on without any need to turn it on. To turn it off you can disable the wireless network under the Network section of control panel....just "disable" the wireless network connection.
Jul 12, 2014 | Gateway SX285001 PC Desktop
Can you help me setting up a password for my wi-fi connection using netgear router
How do I secure my network?
Log into your router using the "How do I log into my router?" instructions earlier in this article.
  1. From the left-hand menu, select Wireless Settings from the Set Up section.
  2. In the Name (SSID) field, enter the network name you want to use.
  3. Under Security Options, select a security encryption level. NETGEAR recommends WPA-PSK + WPA2-PSK for the best protection.
  4. In the Passphrase field, enter your chosen network password.
  5. Click the Apply button to save your changes.
For more details, see Securing Your Network: WPA+WPA2 (Recommended).
How do I change or reset my wireless network password?
Log into your router using the "How do I log into my router?" instructions earlier in this article. From the left-hand menu, select Wireless Settings from the Set Up section. Enter a new wireless network password into the Passphrase field under your security selection and click the Apply button to save your changes.
Jun 05, 2011 | NetGear WGR614 Wireless Router
My dell inspiron mini laptop used to work wireless. It doesn't work anymore. In re-installed the wireless driver and it still doesn't work. Model is inspiron 910
In Device manager, under the network adaptor are you able to see wireless adaptor for your device. - see if it not marked as disable( Red Mark or Yellow Mark)
Also check in network connection wheather you Wireless connection is in Enable or Disable mode,
Note: Please dont forgot to rate me.
Apr 03, 2011 | Computers & Internet
My password doesnt work anymore
Are you looking for the wireless password or the password of the router?
If you want the password of the router, then try the default password of the router. If the default password doesn't work then you will need to reset the router and reconfigure the router.
If you are looking for the wireless network password, then you will need to open the set up page of the router. Is there any computer connected to the router ? If not then you will need to connect the computer to the router. Or any other computer which is able to go online using the router. Check the IP address on that computer. open the set up page of the router. Set up page of the router is the page where you will find all the settings of the router. under the wireless section you will find the wireless network password
Click here for more information about the routers and wireless network.
Nov 13, 2010 | Belkin (F5D5231-4) Router
My computer indicates that my wireless connection is working but I can't access the internet.
In Network Connections (may have to access it via the Control Panel, right click the wireless and select Properties. On the Wireless Network Connection Properties box, click the Wireless Networks tab. Under the preferred networks section select the name of the network you are having a problem accessing and choose Remove. Press OK. Windows will locate the available networks. You should see the name of the wireless network listed. Click it and click Connect. Provide the necessary network key and you should be connected now.
Aug 27, 2010 | Sony Computers & Internet
Unable to wirelessly connect anymore
Click on the network icon in the task bar. Show the networks available and right click on the wireless network if it shows up. Try the 'repair' network selection.
You can also 'remove' the wireless device and re-install it. If you use the command: "ipconfig /all" it will display all the connections and their settings. Normally windows will use the auto config 192.168.xx.xx series of IP addresses if it cannot find a DHCP server to issue it an address. That should show up in the ipconfig output in the wireless network device section.
If the ipconfig does not show the wireless device, try the uninstall/re-install tactic.
If this is a PC-card [PCMCIA] that you can physically remove, power down, remove the device, power back up. Power down again, install the card, power up. Windows might then 're-find' the device and reinstall all the necessary drivers.
tom
Jan 18, 2010 | Dell Inspiron 2200 Notebook
Netgear wireless router wgr614v7 not transmitting a signal anymore. everything seems fine but it's not pumping out the signal.
Dude try the following steps it will help,else let me know the exact problem
  1. Click Start > Connect To > Show all connections, and then double-click your wireless network.
  2. Click General > Properties.
  3. Click the Wireless Networks tab.
  4. Under Preferred Networks, click your home network and then click Properties.
  5. Click Authentication, then clear the Enable IEEE 802.1x authentication for this network check box. (If you cannot click the check box, then you are not using 802.1x authentication or wireless security.)
Dec 29, 2009 | NetGear WGR614 54Mbps Wireless Router...
No network adapter in my computer
· Right click Network Connections, select Properties. · Select Windows to configure my wireless network settings.
· Under the Preferred Networks sections, click on "Add."
· Enter the SSID for the desired wireless network.
· Enter the WEP or WPA key for the wireless network.
· Click OK.
http://www.supportdock.com/home-network-manager.html
Dec 16, 2009 | Intel Computers & Internet
Wi-fi connection
Looked at the specs on your laptop and you have the wireless card included. I assume you have a router set up already or you have access to another wireless network. Follow these steps to access it from your laptop:
1. Go to START
2. select MY COMPUTER
3. Once in the new window, click MY NETWORK PLACES under the "OTHER PLACES" section
4. select the VIEW NETWORK CONNECTIONS link under the NETWORK TASKS section
5. RIGHT CLICK on your wireless network connection and choose PROPERTIES
6. click the WIRELESS NETWORKS tab.
7. make sure the "USER WINDOWS TO CONFIGURE MY WIRELESS NETWORK SETTINGS" box is checked
8. Click OK and close the window
9. RIGHT CLICK on your wireless network connection (the name of it) and choose REPAIR
10. if windows detects the wireless connection, you should see a bubble near the task bar
11. in order to begin using the wireless connection, open your web browser then enter your username and password (if required)
Dec 01, 2008 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
I cannot connect to the internet using wifi
1. Go to START
Dec 01, 2008 | Computers & Internet
Vizio VBR220 Blu-Ray Player Logo
13 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
