Question about Samsung RS275AC Refrigerator
Water inside refrigerator
Inside of RS275ACWP refrigerator under vegetable tray ice is forming and leaking on floor. There is no hole for water to leak into a drip pan.n What can I do to fix this problem?
  • Samsung Master
  • 4,655 Answers
Because your model has an evaporator located inside the fresh food compartment it also will have a drain opening below that evaporator. This is a common problem with these dual evaporator models that have drain blockage caused by ice or gunk blocking the drain and causing water to flow below the crisper drawers. Sea Breeze
Posted on Nov 20, 2013
Sea Breeze
  • 4655 Answers
SOURCE: inside leak
Here is some information on one full page, contaqct me if I can help you better. Choose the part that fits your situation and apply that to resolve the leaking Thanks, Sea Breeze
appliancepartsse@yahoo.com
click below
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Posted on Aug 18, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Water leaking from inside the freezer
This is something that I want you to work with me on as the model you have is complex and I will help if you want. Sounds as if the defrost drain is blocked and we need to do some things to insure that another issue is not taking place. I will give all information if you feel comfortable with me assisting you. I need the age of your fridge and your response as soon as possible Thanks, Sea Breeze
Posted on May 24, 2010
heatman101
  • 43501 Answers
SOURCE: My side by side was
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 24, 2010
imufo2
  • 3773 Answers
SOURCE: my refrigerator is leaking water inside fridge and
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 11, 2011
imufo2
  • 3773 Answers
SOURCE: getting water under the vegetable trays sometimes
Leo Ponder
imufo2
Posted on Aug 12, 2011
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
Water in bottom of refrigerator has to be removed every couple of days or will come out onto the floor.
under the vegetable tray, a small drain hole is stopped up.Everytime you unit goes into defrost mode,the water is not draining to the defrost tray under unit
Sep 25, 2009 | GE Refrigerators
Refrigerator leaking water on floor under it!
The leak is most likely coming from the defrost tray below the evaporator coils. A piece of ice or something is preventing the water from draining to the pan below your refrigerator. Unplug and remove the back panel inside the freezer. Any blockage from that tray will cause the water to pool out into the freezer or fresh food section. Thanks, Sea Breeze
Jun 18, 2009 | Maytag MSD2656G Side by Side Refrigerator
Kenmore 54246400 water on floor - from inside bottom freezer
check the drain hole in the freezer. must likely it is plugged. use hotwater and towel and slowly melt the ice to open the hole. also check the hose that leads to the drain pan. ((back or the buttom of the freg.) it may also need cleaning. use a soft wire (electric wire with small piece of towel tapped to the front).
appricated if you can rate the answer
Oct 15, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer Defrosting
After a defrost cycle the ice around the evaporator melts, that water goes out and lands in a tray under the refrigerator. But sometimes the tube gets clogged and water spills inside the freezer and if enough water accumulates, it will make it to the floor. To fix this problem look for a small hole inside the refrigerator and open it up using a can of compressed air. Hope this helps
Aug 05, 2008 | Freezers
Water always inside refrigerator sometimes ice forms
LadyBlues, This is a top mount freezer. What's happening is that the drain in the freezer area is frozen over. When the unit goes into defrost, the water is running into the refrigerator area instead of going down the drain hole. You will have to remove the freezer bottom panel and then the freezer rear panel to unclog the drain hole. It will be under the evaporator in the drain tray. Use some nice hot water from the microwave and pour it into the tray until the water flows down the drain tube. This should clear up your problem. Catriver.
Jul 12, 2007 | Roper RT14DKX Top Freezer Refrigerator
Samsung RS275AC Refrigerator Logo
269 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
