Question about Canon imageFORMULA DR-C130 Document Scanner
Error this device cannot be locked -4630
When pop error occurs the scanner and computer have to be restarted to clear the error.
3 Suggested Answers
SOURCE: I keep getting the error: The device could not be
Uninstall the driver and reinstall the driver. Make sure your driver supports the Operating System you are using.
Posted on Jan 13, 2011
mohanchennai
  • 490 Answers
SOURCE: Installed driver twice for Canon DR-2050c. Still
Pls run checkdisc/scandisk on your Comp. Your OS may be corrupted. Just to verify try scanning by connecting to a formatted newly loaded OS Computer.
S. Mohan
Posted on Sep 10, 2009
How do I fix TWAIN error? How do I fix Scan Gear error message cannot communicate with scanner?
you need to make sure that your printer is supported by TWIN , you can do that online.
Oct 21, 2015 | HP LaserJet Office Equipment & Supplies
How do you get rid of the Canon DR-7550C -4630 error "The device could not be locked"?
It's usually a software conflict.
If you have multiple scanning programs, the one of them may have it locked. Especially if you have a scanning program that runs as a service.
Jun 13, 2014 | Canon imageFORMULA DR-7550C - Document...
Download driver fow u.a.u 4500
Question
canon DR-2010C scanner which gives error after some times.my system is vista.the error is "The device could not be locked. Check to see that another application isn't using the device -4630".
Answer :- change USB cable which is connect with scanner to PC or laptop definitely it will resolve.
By:- shyam shyam.lal@teamcomputers.com 9210845186
Aug 02, 2013 | DigitalPersona UareU 4500 Fingerprint...
I have canon DR-2010C scanner which gives error after some times.my system is vista.the error is "The device could not be locked. Check to see that another application isn't using the device...
Question
Sep 13, 2011 | Canon DR-2050C Path-Through Scanner
The error message "an error
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
the drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot
hope this helps
Jan 28, 2011 | Panasonic Computers & Internet
Unable to obtain authentication input/output error has occured. error while loading applet module is not registered
unable to obtain authentication input/output error has occured.
Nov 19, 2010 | DigitalPersona U.are.U 4000 Fingerprint...
Problem installing broadcom netxtreme gigabit NIC in windows server 2003 R2 standard, the driver doesn't load, error code 38
Determine Correct Driver Click Here
1: Uninstall any unwanted programs.... (make sure/Try to Clear your Hard Drive more than 50% as free)
2: Update virus software
3:Restart Computer IN Safe Mode
4: Run Virus Scan
5: Restart in Safe Mode
6: Uninstall Existing Driver Software From Device manager
7: Restart computer in normal mode
8: Start>Run> type %temp% and hit run.
9: Delete all files in this folder....
10:Restart Computer
11: DEFRAG
13: Restart COmp.
14:Install Driver
>Troubleshooting for Error 38
The error message for this error appears as: "Windows cannot load the device driver for this hardware because a previous instance of the device driver is still in memory."
This error occurs when a previously loaded driver is preventing the new driver from loading. To fix this error follow these instructions.
  • Reboot Your PC
  • Open the Device Manager and in the device Properties box, select the General tab.
  • Properties Uninstall(Right Click Mouse) / Disable(In Property)
  • Restart PC
  • reinstall /enable
  • Once you have followed the instructions throughly, reboot your PC
Hope this make you Better Conclusion....Thanks for Using FixYa.....
Apr 21, 2010 | Computers & Internet
S. Mohan
Sep 09, 2009 | Canon DR-2580C Path-Through Scanner
Installation
An error occurred when you set the transportation lock to the lock.gif locked position. To clear the error message on the LCD panel, set the transportation lock to the unlock.gif unlocked position, and then turn on the product again or press the fontx1.gif B&W Start or fontx1.gif Color Start button to restart the scanning job.
You can find the transportation lock on the left hand side of scanner when you lift/tilt ADF up. Hope this helps...
Apr 05, 2008 | Epson ACULASER CX11NF All-In-One Printer
Canon imageFORMULA DR-C130 Document Scanner Logo
364 people viewed this question
old marine
old marine
