Question about Whirlpool Ovens
Whirlpool part 8203557
Is there a substitute part? The typical appliance repair companies list this as "N/L/A" which is "no longer available". Does this mean the oven is junk?
    Prodigy:
    An expert who has answered 500 questions.
  • Whirlpool Expert
  • 650 Answers
There are a couple companies that rebuild these boards. I have had good success with corecentric solutions. It took them about a week turnaround after I sent them my old board. a google search should take you to their website.
Posted on Nov 20, 2013
How do I remove the cirucit board on Whirlpool double oven Model RBD305PDS14?
Looks like you have the stainless steel model. It's not too difficult. Once you get behind the oven and can see the control board, it will be held to the back of the keypad with about 4 - 8 screws. Typically it is surrounded by a black plastic shroud. Make sure you take a picture of how everything is plugged in so that you can plug the repaired or replacement board back in. If you are sending your board to a company for repair we suggest you send the shroud with it, and even the keypad as well so they can test it.
Nov 21, 2015 | Whirlpool RBD305PD Electric Double Oven
Whirlpool double wall oven RBD275 won't hold temperature
Try this: Check your thermal coupler, it should be reading approximately 1080 ohms of resistance at room temperature. If your connection is bad or the coupler is bad this could quickly cause a temperature issue. However if you have replaced this component and still have the same issue it's likely your ERC is bad. You can have this repaired for $99.99 through The Repair Shack. Your control board part is 8301917 which is no longer made. Here is a link to have this part repaired Repair Service For Whirlpool Oven Range Control Board 8301917.
If you would rather replace the board you can use substitute part number W10438751. The cost from The Repair Shack is $325 with free shipping. You may be able to find cheaper elsewhere but we have the part available.
Nov 21, 2015 | Whirlpool 24" Double Electric Built-In...
MODEL FGF355CGBF Door lock activates when check food in oven not allowing to continue to cook. occasionally stays locked
Hello Richard;
My name is Peter. I am a retired field service appliance technician.
You have an old unit. Some parts such as the door switch are no longer available.
You door lock should only engage when you are in the self cleaning mode. So you have a communications problem between the door lock and you control panel.
25601831-imv3tze4snahc4os1l3biiwf-2-0.jpg Latch Motor Substitution: 5304449471 Cost $180.00
25601831-imv3tze4snahc4os1l3biiwf-2-5.jpg Substitution: 316131600R Cost: $130.00
You may to replace one or both of these components.
Based on the cost of the parts and my service call experience you are looking at a $500.00 -$600.00 service call.
It's time for a new unit. Go into the internet and search; :Sears Outlet Store". This is a scratch and dent store where you can save several hundred dollars on a new unit with a one year warrantee.
Mar 23, 2015 | Frigidaire Ovens
Dacor Oven model # CPS127 - part # 13158B - discontinued. How to find
More than likely your not going to be able to find a part once its been discontinued, especially if its been that way for a while, but there is an alternative though. There are companies that specialize in rebuilding control boards, etc that have been discontinued and are no longer available. I would contact a company like appliance parts depot or another major distributor because they will have the numbers you'll need to contact those companies, but remember, whatever the cost of the part was is nothing compared to the cost they charge to remake the part.
Jun 21, 2012 | Dacor Ovens
Looking for used whirlpool oven swith for bake/broil knob. no longer available and no suitable replacement either. molel #RB220PXV-0, serial #F94703608 and part #AP3024240
This parts website says they have one in stock http://www.apwagner.com/index.php?main_page=product_info&products_id=1905659
try calling them and see if that is so
that part number you gave was a internal partnumber from i believe appliance parts pros or someone like that THE OEM WHIRLPOOL PART NUMBER IS 310866
GENE
Sep 08, 2011 | Whirlpool Ovens
I need to replace the outer black glass oven door panel on our Kenmore stove, has broken and the part is no longer available. Size of panel is approxiamtely 20" X 30", needs to be tempered. I can have...
If anyone can locate this part I would bet on appliance parts pros:
1-877-477-7278 http://www.appliancepartspros.com/part_details.aspx?part_id=2035287
This door glass was originally made by GE.
You can also try the repair clinic:
800-269-2609
http://www.repairclinic.com/Appliance-Parts?s=t-WB57K5121-%3d%3d
These 2 sources will probably be your best bet. I know it says they are not stocked.
As I said GE made this door originially. You can call their parts line at :
Parts:
Call: 800-626-2002 Start with the call to GE parts first using your WB57K5121 part number. Fingers crossed but as a service tech this is exactly what I would do if I were faced with your situation. Wish you the best and would appreciate any feedback on your search results. Thanks for choosing FixYa. Kelly
Aug 19, 2010 | Ovens
I'm looking for a Jenn Air wall oven W136 schematic, is there one available?
Jenn-Air is now a division of Whirlpool so you might want to check with their closest service company and ask if there is a wiring diagram pasted inside a panel of the unit. This is common practice on many appliances.
May 17, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Hi I have a Tappan oven model TGF357CCSF. The clock display andtemperature display is working but it is very dim. I have been told the I need a control panel 316028350 which is no longer available is this...
Hey - That part is available thru AppliancePartsPros online listing is clock/timer.  Part # AP2125110     $203.75   These timers are old-timers anymore. Can be hard to find, and at 200 bucks, make ya think twice. Gas model is probably worth it though.  Either way- it's an electronic clock that has had 120v running through it for 20 yrs or so. Time to replace for sure. Let me know if this info helps-  have more if needed-  Thanks--Ed
Mar 16, 2010 | Ovens
Ovens Logo
42 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
