Question about Refrigerators
Whirlpool refrigerator mark 1 series
Trying to find the model number of it, but its not inside on the walls as they say it should be. Where else might one figure out the model?
  • Refrigerators Master
  • 842 Answers
The mark 1 unit had a plate over a sticker, open refer door, bottom right of the cabinet next to the hinge is where the plate was mounted in this unit.
Good Luck
Posted on Nov 20, 2013
  • 1218 Answers
SOURCE: I have Whirlpool Mark I series . Came with the
Good day,
That isthe compressor not starting. Remove the back cover and inspect the compressor.
There is a cover on the side of the compressor, that contains the starting components for the compressor.
They, include the overload, the start relay, and on some models a start/run capacitor.
These components can be taken to an appliance parts house. They are usually more than happy to tset them,
If any test bad, replace. If they test O.K.
Then your compressor has failed, and would require calling a qualified refrigerator tech.
My experience is ........
The Mark series of Whirlpool rarely had the compressor last 15 years.
Thank you for using FixYa
Posted on Jan 10, 2010
SOURCE: Water inside the refrigerator
is water in the bottom half of the refrgerator thanks
Posted on Oct 12, 2008
  • 236 Answers
SOURCE: whirlpool refrigerator leaks
the drain hole at the bottom rear is blocked. a pipe cleaner run down it should clear it out.
Posted on Apr 09, 2009
SOURCE: Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
Posted on May 13, 2009
SOURCE: where can i find schematic diagram of whirlpool refrigerators?
there's no cool air coming into the freezer or refrigerator sections. as soon as it starts there is a clicking sound and it stops. what's the problem? the fan works at the back. i've cleaned all the coils below. thanks
Posted on Nov 03, 2009
My Whirlpool Mark Series Model # EB19MK is not cooling or freezing. Compressor is working, fan is working. Does it have reset button?
No reset of that kind. Did you loose cooling gradually over several days? if yes, you may have a problem with the defrost system causing an excessive frost buildup in the freezer section. symptoms would be excessive frost on freezer back wall. Possibly a bad defrost heater. Replace defective part and manually defrost refrigerator before re-starting.
May 24, 2015 | Whirlpool Refrigerators
Whirlpool refrigerator/freezer not working
What is your model number? This model number will be very important in resolving the problem your refrigerator may be having.
Can you look at the rear wall of the freezer and see if frost is building like in this photo HERE If this is happening on the wall of freezer this is what it will look like behind the rear wall of the freezer HERE Here is a link to a post with the model number HERE Having the model number helps determine just what components may be defective and causing the refrigerator to warm up. Let me know what your model number is and what you see going on. If this is not happening this way tell me so I can advise you on resolving the problem. My contact me information can be found at the top of my website Thanks Sea Breeze
This could be another problem (like a defective fan) other than defrost so please explain how cold is each compartment freezer and fresh food section?
Apr 02, 2013 | Whirlpool Refrigerators
How to change temperature control on Whirlpool refriigerator?
There are many different models of Whirlpool Refrigerators and not all have the same temperature controls. Are you replacing the thermostat or a electronic digital controls? Look inside the door frame of the fresh food compartment on walls and door frame itself for the model number. JT3_5_2013_5_42_46_am.jpg
Mar 05, 2013 | Whirlpool Refrigerators
Where can I download a manual for Whirlpool AWM321
You could go to whirlpool.com and click ower center and download a maual for your washer,i tried that but it says the model number couldn't be matched
The following is from the whirlpool website and it shows where to find the model#
Please find the type of appliance you are interested in and click on the link to view the likely location of the model number plate on that appliance here is where the model# could be found
Type of Appliance Model Number Plate Location Range Inside oven drawer, on oven rim Wall Oven Inside oven drawer, on rim Cooktop On underside of unit Microwave Inside microwave, on rim Dishwasher Inside dishwasher, on rim Refrigerator Inside refrigerator, on wall Trash Compactor Inside, on rim Food Waste Disposer Attached to the unit Washer Beneath washer lid, on tub rim Dryer Inside dryer door, on rim.
Jul 29, 2011 | Washing Machines
Where is the model number?
For a Whirlpool refrigerator, look for the plaque with the model number inside the fridge on the wall. (Frequently on the right or left side near the top)
For a complete list of where to find the model number for Whirlpool appliances, see http://www.whirlpool.com/owners-center/owners-center-homepage.content.html . Click on the Where is my model number link http://www.whirlpool.com/webapp/wcs/stores/servlet/WHRPopUpContentDisplayView?catalogId=10561&langId=-1&storeID=10211&cid=owners-center_locate-model-number&KeepThis=true&TB_iframe=true&height=525&width=500&modal=false .
I hope this helps.
Jul 10, 2011 | Whirlpool GS5SHAXN Side by Side...
My evaporator fan has quit working. How do I replace it?
unplug the machine,remove all the food out of the freezer,if it has an ice maker,remove it and all the shelves,remove the back inside wall of the freezer to get at the evap fan motor,when you get it out put a mark on the front of the fan blade before you pop it off and put it on the new motor.part number is 2214986 and it's around 45 dollars,next time send the full model number off of the machine.
May 15, 2011 | Whirlpool ET1MHKXM Top Freezer...
What is the cubic feet measurement for a GE Model TBX18 refrigerator? Also, what is its width and height?
The capacity depends on the exact model number. The TBX18TABWW and similar models are 17.6 cu. ft. The refrigerator holds 13.6 cu. ft. and the freezer 4 cu. ft. This model is 64.25" tall, including the hinge, 28" wide, and 31.25" deep.
The GE S series, including
TBX18SIBRWW, are 18.2 cubic feet; the specs are 13.04 cu. ft. for the fridge and 5.13 for the freezer. Total height (including the hinge is) 64.75", 29.375" wide and 31.5" deep including the handle. (It takes up 58" with the door open.)
The J series has the same total capacity and dimensions as the S series.
Remember to leave 0.75" free on both sides and 1" at the back and top for air to circulate around the refrigerator.
You can find your exact models specs and manuals here: http://www.geappliances.com/service_and_support/literature/ . Enter the model number in the search box and click submit. Dimensions are provided in the Quick Specs for most refrigerators. The model number will be on a plaque in any of the following spots:
1) On the ceiling of the freezer near the front
2) By the temperature control
3) On the inside wall of the refrigerator near the crisper drawer on either side
4) Behind the crisper drawer
5) On the bottom front of the refrigerator
I hope this helps.
Mar 18, 2011 | Refrigerators
How do I change the filter?
Here's the link to printable user instructions:
http://www.whirlpoolappliances.ca/assets/zltVF596vquA4jOb-B2z_140ao-uI09F.pdf
If you need additional assistance, call the toll free number below. Whirlpool customer service requests you have the complete model number available before calling. This information can be located on the inside wall of the refrigerator.
1-800-253-1301 - In the U.S.A.
1-800-807-6777 - In Canada
Jun 03, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Good day,
Jan 10, 2010 | Refrigerators
Mark I Series fridge not freezing
Please list the complete model number found inside the refrigerator on on the door frame. With the model number I will be able to help you better. If your refrigerator is an older model then with what you described could possibly be a defrost timer gone bad. Let me know what you find, Thanks,Sea Breeze
Mar 23, 2009 | Refrigerators
Refrigerators Logo
182 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
