Question about Kenmore Ovens
Door open message - Kenmore Ovens
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
Door not close enough to contact
Posted on Nov 22, 2013
My Kenmore Elite oven door is locked and I am getting an F93 error message. I have had repairmen here 3 times already to fix the problem. Can you help?
The F93 - Maximum oven door lock time exceeded. First thing to try is holding the clear button down for 3-5 seconds sometimes this unlocks the door and then leaves the loc light still on in this case you would open the door and once again hold down the clear to make the loc light clear. If your unit doesnt have a clear button then you would hold the stop button for the same amount of time as described above. If this doesn't work try shutting off the power at your electrical breaker for 7 minutes this usually causes the control to reset in the unit. If you have any further questions or if this does not work to allow you to be able to open the door and clear the error code message me back for further diagnosis. Thanks
Rick
Sep 03, 2011 | Ovens
I get the error code FSE1, lock won't engage message for the bottom oven everytime I turn on the top or bottom unit. The message will not go away until I turn the top unit off. The bottom lock keeps...
F5 - E1 Self clean latch will not lock
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Note: Applies to all F5-E... codes.
Apr 19, 2011 | KitchenAid Architect KEBS208S Electric...
I set the upper oven to clean and it did clean but now the door won't open and the message reads too hot, door locked. How do I open the door?
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 17, 2010 | KitchenAid KEBC247 Electric Double Oven
It stopped running, shows door for message. no light when the door is open.
there is a fuse that causes this. check it. if door error apears for the micro
Feb 07, 2010 | Whirlpool GMC275PD Electric Double Oven
The lock switch is on and door is open-"dr" then "f9" message
Unplug the range and then have someone hold in the door/light button while plugging in the unit again. The locking mechanism should reset itself. Let me know if I can help further.
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
OVEN DOOR WILL NOT UNLOCK AND NO INDICATORS ARE FLASHING
Yes, one thing you can try is to use a thin piece of strong metal and try to slide the latch over to open the door. You may have to shake the door as you do this. I have seen this done with a credit card. Similar to opening a door that is locked. Let me know how that does. One last ditch effort is to put the oven in self clean mode and let it run it cycle and maybe it will send a message to open the doot at the completion of it's cycle.
Feb 13, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Open Door Message
are you positive the switches are good?those switches go back to a relay board,turn off the unit and trace the wires from the switches back to the board.lighty tap on the relays (they could be stuck closed prompting that message}.if that doesnt work the relay board may be bad and yes they are expensive but i think $1000 is on the high end.
Aug 13, 2007 | KitchenAid Architect Series KEMC308KSS...
Ovens Logo
Top Kenmore Ovens Experts
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
