Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Cannot connect Youtube on iphone
welworth on Oct 08, 2007
I have a unlocked version of iphone i have been able to use safari and other features over EDGE network but when i try to connect to Youtube it says "cannot connect to Youtube"
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
Posted by shailess on Nov 22, 2008
hi i cant open the youtube though i have wifi network in my phone.why???
Same Problem
Feb 25, 2009
-   click the tv(youtube) on main menu,and it says
"cannot connect to youtube"-   Guest
Jan 24, 2009
-   i have the same problem i can access safari but when i search on youtube it says "cannot connect to youtube"-   bryar_kurd87
Dec 24, 2008
-   cannot connect to u tube
-   daddy-eddie
Dec 24, 2008
-   if i connect to youtube,the windows say internet explorer cannot display.-   gary_reyes29
Dec 06, 2008
-   MY IPHONE cannot connect to youtube idon't now whati can do -   Guest
Best Solution
posted on Apr 07, 2008
Helpful)
tigeronfire
Rank: Apprentice
Rating: 91%, 39 votes
I FINALLY GOT YOUTUBE WORKING on 1.1.4...
Step 1: backup your settings and files on itunes
Step 2: restore iphone to default( this will erase everything)
Step 3: try Youtube before Jailbreak to make sure its working
Step 4: ***important*** run ziphone for JAILBREAK only!
YouTUBE remains working. when I tried to DO-IT-ALL youtube never worked afterwards.
Step 5: Sync iphone to get your settings, contacts, emails back
Was this helpful?
Yes
No
Solution #2
posted on Mar 18, 2008
Helpful)
yeanfei
Rank: Apprentice
Rating: 92%, 2 votes
mine 1.1.2 firmware failed to run youtube after put those 3 files in my iphone....and i try solution 1 same failed....what should i do? ty
Comments:
Mar 18, 2008
- mine 1.1.2 firmware iphone after using ziphone unlocked and jailbroke everythin work except youtube,i try all da solution also cant, 1st it said ou must first connect~enable youtube then i try replacing 3 files in my iphone,it seems like better than previously but youtube cant work also and its pop up cannot connect to youtube. try every solution i knew still cant work,i am tired with that, anyone got any idea to fix this problem? thkz.... ^_^'
Was this helpful?
Yes
No
Solution #3
posted on Mar 17, 2008
Helpful)
pjb666
Rank: Apprentice
Rating: 92%, 16 votes
Was this helpful?
Yes
No
Solution #4
posted on Apr 01, 2008
Helpful)
bulldog156
Rank: Apprentice
Rating: 91%, 12 votes
I tried every fix on every site! After trying them all I finally found one that worked. Thanks to RYU ^^b Solution #5. I am using 1.1.3.
First, get this http://soundsgood.cocolog-nifty.com/blog/files/youtube.zip
after you extract this file, you will get three files. then put them in the /var/root/Library/Lockdown/ with WinSCP or some tools.
And reboot your iPhone, then Youtube should be worked.
Was this helpful?
Yes
No
Solution #5
posted on Feb 13, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
the right steps are go to installer and:
1. add i.unlock.no source
2. install youtube activation under Unlock tools
3. restart the iphone
4. uninstall youtube activation
5. restart the iphone
6. install youtube activation
7. restart the iphone
8. test the youtube app. It will work now
it worked with me
Carlos
Solution #6
posted on Nov 04, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
→'Best Solution'
You dont know anything man, if the youtube says 'you must first connect~enable youtube,' then there is a way to fix it perfectly.
English is not my first language, so I think its hard to understand but GOOD LUCK.
RYU ^^b
Solution #7
posted on Dec 05, 2007
Helpful)
pedrogaris
Rank: Apprentice
Rating: 89%, 17 votes
Iphone says that I must first connect to iTunes with and internet connection to enable YouTube. I have an unlock iphone, someone knows what to do? The answer of the 3 files before i try it but it is not clear where to put them... cheers!
Was this helpful?
Yes
No
Solution #8
posted on Dec 25, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
THANKKKKKKKKKKKKSSSSSSSSS
DUDDDDDDDDDDEEEEEEEEEEE !!!
MUCHISIMAS GRACIAS !!! :)
Solution #9
posted on Mar 04, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Here is something crazy, I got so annoyed with not having you tube or email even after attempting the fix, that I decided to re-lock my phone with Ziphone. Well at the end it crashed, and my phone was a $400 paper weight. I then unlocked it again(after placing the correct files in the directory(prior to the re-locking process), and suddenly everything works, and I am using 1.1.3
Solution #10
posted on Oct 28, 2007
Somewhat Helpful)
pcsupport
Rank: Guide
Rating: 77%, 29 votes
The youtube problem exists because there is no wifi connection. You need to goto settings than click on wifi
Was this helpful?
Yes
No
Solution #11
posted on Mar 09, 2008
Somewhat Helpful)
bottswana5
Rank: Apprentice
Rating: 70%, 1 votes
Heres how i fixed it:
Ok, so after attempting everything and it all failing, i decided to reinstall, then unlocked using ZiPhone, a full featured iPhone unlocker. This program fixed the problem =) hope this helps
ZiPhone Downloads
Mac Edition = http://downloadziphone.org/mac
Windows = http://downloadziphone.org/win
For windows, you need .Net v2 download it here = http://www.microsoft.com/downloads/details.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5&displaylang=en
Was this helpful?
Yes
No
Solution #12
posted on Nov 05, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Gues:
OMG!!! THANK U VERY MUCH I LUV U!!!
Solution #13
posted on May 13, 2009
Not Rated)
enepoh
Rank: Master
Rating: 80%, 19 votes
Problem with Apple iPhone? Most of the iPhone problem is Unlocking problem.
If you want to unlock your iPhone now you must Click Here.
If you have any other problem with your iPhone you can try the site by Click Here. May the site can help you.
Was this helpful?
Yes
No
Solution #14
posted on Apr 27, 2009
Not Rated)
eillm
Rank: Master
Rating: 76%, 28 votes
FIND YOUR SOLUTION FROM APLLE.
HERE IS YOUR SOLUTION
www.apple.com/iphone/prob237ji32/solution
Was this helpful?
Yes
No
Solution #15
posted on Nov 08, 2008
Not Rated)
mahigir3162
Rank: Apprentice
Rating: 0%, 0 votes
Was this helpful?
Yes
No
Solution #16
posted on Jun 13, 2008
Not Rated)
HOODGEEK
Rank: Apprentice
Rating: 100%, 1 votes
I TRIED ALL OF THE CANNOT CONNECT TO YOU TUBE FIXES, & I THINK WHEN I DOWNLOADED THE ZIPHONE3.0 & IT CAME WITH THE TWEAKS 1.1.4
A) INSTALL IT
B)RESTART
C)TRY YOU TUBE.. IF IT DOESNT WORK
D)UNINSTALL IT & REPEAT A THRU D....
ALOT OF PPL SAY THINGS WORKED FOR THEM THAT DIDN'T WORK FOR ME.. BUT THE ONLY LINK TO ME GETTING YOU TUBE WAS USING THE TWEAKS FOR 1.1.4
I TRIED I.UNLOCK.NO - YOU TUBE ACTIVATION & IT DIDN'T WORK FOR ME
I TRIED WINSCP & FILE SWAPPING IN THE LOCKDOWN FOLDER.. DIDN'T WORK FOR ME
I JUST GOT THE PHONE TODAY & IM UP & RUNNING
ZIPHONE 3.0 HAS ALL TEH FIXES BUUILT IN!!
GOOD LUCK ... & GOD BLESS
Was this helpful?
Yes
No
Solution #17
posted on Apr 27, 2008
Not Rated)
ilans
Rank: Apprentice
Rating: 0%, 0 votes
For it works only if the iPhone is connected to the computer directly - not WiFi
Was this helpful?
Yes
No
Solution #18
posted on Mar 14, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Make sure your time and date are set correctly before applying other fixes, the certificates generated need to be for the right date or you won't get access.
Related Problems
bluetooth to other mobiles
It was in a case and worked for an hour after being dropped,...
I am going nutts considering its a new phone, but the screen...
Can you Help with these PDA problems?
SCREEN MAGNIFIED BY ITSELF
Solve
the home screen magnified by itself, now i can't enter the unlock code because the screen is so... (More)
home screen magnified so large can't...
Solve
my home screen magnified so large all by itself, I cant enter the unlock code and the phone won't... (More)
downloaded a theme restarted iphone...
Solve
downloaded the bloodelf theme on the installer thing. its the 1st iphone now the damn thing keeps... (More)
i reset my iphone and now it is on...
Solve
i reset my iphone and now it is on black screen with apple
41 Other Users Have The Same Problem - Continued
Comment by namesness, posted on Nov 23, 2008
i have upgraded 2.1 firmware on unlocked iphone. everything works ( safari, weather, email) but just recently my youtube stop functioning, it says " cannot connect to youtube" someone plz help!!!! namesness@aol.com
Comment by danb1992, posted on Nov 18, 2008
well it just does nothing and says cannot connect to you tube
Comment by Guest, posted on Nov 12, 2008
i can
Comment by Guest, posted on Nov 08, 2008
you tube can not connect iphone
Comment by Guest, posted on Sep 03, 2008
Comment by Guest, posted on Aug 15, 2008
Comment by iizzzzii, posted on Aug 12, 2008
i can connect the wifi but every time i try to go youtube or safari it says cannot connect
Comment by gmack66, posted on Jul 24, 2008
I have fw 1.1.4 I use T-Mobile. When I use WI Fi It says cannot conect to youtube.
Comment by Guest, posted on Jul 07, 2008
cannot conect to youtube on jailbroken iphone.
Comment by ilovegadgets, posted on Jun 21, 2008
cannot connect to u tube with version 1.1.3 unlocked
Comment by darmic, posted on Jun 15, 2008
cannot connect iphone to you tube
Comment by Guest, posted on Jun 11, 2008
my youtube does not work
Comment by Guest, posted on May 31, 2008
Comment by freddysc, posted on May 27, 2008
I try everything but my youtube wont connect on my iphone, but my email works.
Comment by cef149, posted on May 19, 2008
I have the locked to O2 UK version 1.1.4 and I got the same problems after I jailbreak with ZiPhone. The only thing I did was removing the Sim Card and replaced it back and the YouTube was there waiting. No fuzz, no hassles. No need of those bloody technical directory download install whatever. Thanks anyway for this website just to know I wasn't the only who suffered with this glitch.
Cef from Belfast UK
Comment by Guest, posted on May 08, 2008
yes the same thing is happening
Comment by akajoker, posted on May 04, 2008
i have the same problem plz some one help
Comment by invaderzim, posted on May 02, 2008
Comment by Guest, posted on Apr 22, 2008
Yea, "cannot connect to youtube" and can't access my Yahoo.. :(
Comment by Guest, posted on Apr 17, 2008
I jailbreak my iphone, and the edge network is working perfectly, but i can't connect to youtube, i re receive a message "connect to youtube"
Comment by nomanumer, posted on Apr 15, 2008
you must first connect to itunes with an internet connection to enable youtube
Comment by Guest, posted on Apr 03, 2008
how to enable YouTube on iphone
Comment by InDiAnGeNiuS, posted on Mar 01, 2008
i havent taken any steps but every time i try to get to youtube it says cannot connect!!!
Comment by supajazz, posted on Feb 26, 2008
i can use safari but error comes up when tryna use youtube
Comment by Dawgee, posted on Feb 24, 2008
I have version 1.1.3 unlocked but You Tube says "cannot connect to You Tube," any help?
Comment by donwon68, posted on Feb 21, 2008
i have an unlocked iphone cannot connect to interne. tried to use safari cannot connect or get to my tmobile service. please help
Comment by Guest, posted on Jan 07, 2008
im having the same problem over edge or wifi
Comment by Raf071, posted on Jan 06, 2008
I have just bought a iphone it works fine but when i go to you tube this message pops up "can not connect to youTube" would some one know how to solve this problem please
Comment by Guest, posted on Dec 28, 2007
i have the same problm
Comment by ramz8, posted on Dec 23, 2007
i have a unlocked iphone and i can connect to safari using wifi.but when i try to connect to youtube.it just comes up,cannot connect to youtube.
i do have a full signal and a updated iphone.
Comment by Guest, posted on Dec 16, 2007
i have installed many features on iphone ad shows small icons on the main screen , the screen dosent scroll, iam unable to see all the applications
Comment by Guest, posted on Dec 04, 2007
I am already connected to wifi. And I really don't get the downloading files somwone suggested. Plus mine is unlocked as it isn't out in Asia yet.e
Comment by vip333, posted on Nov 24, 2007
i have same prob to!
Comment by Guest, posted on Nov 06, 2007
Comment by Guest, posted on Nov 04, 2007
cant connect to youtube with iphone. It says: you must first connect to Itunes with an internet connection to enable youtube....
Comment by Sharonf, posted on Nov 03, 2007
I just bought a new unlocked iphone and I can't connect to anything :-(.
I can use it as a phone and send texts but I want to do more than that.
I can't add photos oor music, connect to wifi, or safari.
Help!!!!!
Sponsored Links
Describe your PDA problem:
Top PDA Experts
Rank: Guru Guru
Solutions: 702
Experience: Certified Master ASE Car and Truck Mechanic Certified AC mechanic Cert. AWS welder cert. Electrician
Ask Me
Find more PDA Experts
Top Computers & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(601) 918-0222
I will connect to your Computer and repair the...
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
