I have a Magnavox 42mf230 that when you turn it on, the blue light comes on and I can hear things power up but the screen is black and no sound. I've taken the back off and the fuses check out and no capacitors are bulging it appear bad, what could be causing this issue?
  • 115 Answers
Try in put signal from av source
Posted on Nov 19, 2013
  • Chad Peppin Nov 20, 2013
    I'm able to get sound when hooked up to my DVD player and the screen is still black.
5 Suggested Answers
SOURCE: Syntax Olevia 30" LCD - blue screen, then black screen, sound is on
you have a broken inverter board. I have a LT30HV, and it had the same problem. The inverter board supplies power to the backlight. Swap it out with a good one, and you're back in business.
To test, take a bright flashlight and point it at the screen just an inch or so off the surface. If you can see your picture, then you have a blown inverter.
it may not be worth fixing it. Wait for a good sale on a new one. My inverter cost about 150, and it was a remanufactured part. Not as good as the original part as it flickers just a tad. I had to take the entire TV apart, with pieces literally everywhere. My cats loved it.
Posted on Nov 15, 2008
  • 230 Answers
SOURCE: No longer turns on
It's well worth replacing the capacitors, but this problem can be caused by a short on the power supply (Which is what the caps do). Most shorts that arise in power supplies are result of a shot transistor or diode and of course the electro caps. Check these while your changing the caps.
Good luck with it.
Posted on May 25, 2009
jhinsincity
  • 616 Answers
SOURCE: Digistar PH-4210D Black Screen
Plasma tvs do not have "back lights" LCDs do. you probably have a bad driver board along with the upper or lower buffer board or maybe both, best to have a tv shop look at it.
Posted on Aug 30, 2009
micromatikal
  • 2777 Answers
SOURCE: I have a viewsonic N3235W
Sounds like a failed or at least failing power supply / power board inside the TV. Unfortunately this is a very difficult repair, and unless you are an electrician I would not recommend attempting it. You can test the voltage output from the power supply if you wish... that will show if it is indeed the culprit which I think it is. If you don't want to mess with that you will want to contact a local TV repair person in your area if you are sure this is out of warranty, more on that in a bit here. This is actually the most common problem with this type of TV, I see it every day, it just happens - sometimes with new TVs and sometimes it takes many years for it to happen.
If you think it may still be under warranty please contact the manufacturer to file an RMA. If you happened to purchase the TV with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the TV.
If you want to attempt the repair yourself please let me know and I will get you the part number and a place you can purchase it from for what you need.
So sorry that I don't have better news but it is definitely a power issue internally. Please reply to my answer here with any questions or comments and I can help you for sure...
Thanks
Tim
Posted on Nov 06, 2010
Magnavox 37MF23ID, would not turn on. Power button only blinks (green light). We have switched power cords and nothing happens. No picture, no sound.
if the power light comes on but the screen stays black, then your TV might be on the wrong input Channel. for example: you switch inputs when you play games or watch dvds vs. watching regular tv. Try to change the input
Dec 27, 2014 | Magnavox Televison & Video
Hp pavilion ze1210 intermittently boots up or will not turn on at all.
ok it's a laptop., old.
let me guess 2003 made, square 4:5 screen
XP removed, (smart idea) Linux installed.
I guess the screen is 100% dead, not one pixel ever glows, right?
no text, ,no BIOS screens on demand, (esc key pressed, power on)
1: step 1 is always remove the main big battery. run now?
2: try external VGA screen yet, to see if the old internal screen is dead? see that VGA jack on the rear, and the hot function key that turns it on, bingo.?
(use a flash light to see if screen internal has data but the
CCFL back lamp is dead.?)
4: if bios is dead and both screens fail,what is next.?
19vdc from the power pack must reach the guts (MOBO)
if not all HP lap tops die. use a voltmeter or get a spare power pack
many power packs this old are now bad. 14 years old,
the can be good, bad, or weak. weak is bad.
5: sparks is a bad thing, in all cases, when heard it needs service.
BSOD:
http://pcdied.com/#black-screens
May 04, 2017 | HP Pavilion ze1210 Notebook
My Magnavox TV give sound but no picture. When I turn it on the light in the bottom right hand screen goes green, then flashes to yellow and goes back to green. The screen does not change it is constantly...
You need to replace your backlight inverter.
Check that all voltages are coming from the power supply as they should. The power supply will be stamped with the correct amounts, and you just read with the multimeter to confirm.
After those check out ok, you will need to replace the inverter to "light" your screen again.
You can hear sound because the tv is ON, but the inverter isn't lighting the screen!
Hope this helps, please rate!
May 11, 2011 | Televison & Video
Ps3 80 gig
Try getting a new AV Option, well actually first startup your PS3, startup your controller, and hit the center PS3 button, because those 2 options are only in the Main PS3 Option, which is accesed and closed through hitting the middle button on your controller. Hope this helped.
Jul 11, 2008 | Sony Playstation 3 (PS3) Console
Black screen no sound
What is the model or chassel number it be a few thing H.O.T Resistor Caps etc..most likely horizontal output transistor.
Nov 12, 2007 | Televison & Video
TV Comes On But No Picture
check for bad solder connections on the pc board and a posible leaky cap
Dec 06, 2006 | Philips Magnavox 20MS233S 20" TV
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
