Question about Honeywell HEPAClean 99.9% HEPA Air Purifier HHT-149
No power wont turn on
Wont turn on
Thera Pure. Why won't it turn on?
My THERAPURE wouldn't turn on either. I got it when my mom upgraded but could never get it to power on. I came here for help. I figured it out myself. The filter was put in upside down after it was cleaned. Odd that it even fit. I flipped it, plugged it in, and it turned right on! Good luck. Hope your fixes are all as easy as mine!
Jul 23, 2015 | Air Purifiers
My henry hoover wont work
check main cable & power switch, mAY BE FAULTY
Feb 12, 2015 | Hoover Numatic Nacecare Henry HVR200A...
Wont turn on
does the lights come on but the motor does not turn, if it is this it can be the starter for the motor inside next to the motor is a started solenoid this starts the motor to run. when they start to fail you get a buzzing sound or a humming, eventually it just fails. also the motors are prone to fail after time, and they don't do replacements for this part
Mar 30, 2014 | Air Purifiers
Kenmore humidifier model 15420 wont turn on.
If its like mine, one or both of the fans short out causing the fuse to blow in the controller. I was running with a replaced fuse and 1 fan while waiting for a replacement fan. The remaining fan also blows the fuse now. I think maybe there is a fan issue?
Feb 23, 2014 | Kenmore 14 Gallon Humidifier Model 15420
Emptied the hoover and now it wont switch on
The switch that is activated by the canister is your likely culprit based that it was working prior to emptying. Youtube has a quick video on this solution.
Jan 13, 2014 | Hoover Turbo Power Long Reach Pets Utp1605...
Fan wont turn
I have taken one apart. reassembled and the fan would not turn, although there was power to the motor and it wanted to turn.
Sorry this is long...only this is about taking the motor itself apart..and I have yet to find a replacement motor.
1. Tried a little WD 40...(only on iron motor Housing!) nothing.
2. Took apart inside of motor. some rust inside..
3. carefully rubbed clean with WD 40..
4. leaned off WD 40 with contact cleaner...
5. Then worked little bearing loose on back side.
-Kind of turned upon reassembly..
6. Found some silicone High temp lubricant and took motor inside part again.
7. a very thin coat of lubricant inside rotor.
-Re assembled yet again..began to turn at high speed, kept running..24 hrs..
- It .finally turned at silent mode. and continues to work
This may be ar beyond what you want to do, however if all else fails...what else can you do? buy another one?
Tips:
1. mark rotor holders with housing. (do not reverse.)
2. make sure you remove all lint, dust, etc inside.
3. the rotor bearing I had to work by hand again and again repeatedly syringing a little WD 40 at a time to until it turned easily.
Jun 04, 2012 | Oreck XL Professional Air Purifier
When I attempt to turn the unit on, the display flashes but wont stay on
The main circuit board is bad. The circuit board can be repaired with a one year warranty. Call (336) 499-2505 for more information.
May 23, 2012 | Ecoquest Fresh Air Air Purifier
No power
mine was having the same issue. its been broken for 2 years now. i jsut fixed it a few minutes ago. there is a button sensor behind the top filter. if its not pushed in all the way it wont turn on. my filter was in correctly, but the button doesnt appear to be depressed all the way. when fastening the back cover it locked in good, but was still slightly loose. those two things together means the sensor wasnt being triggered.
with your unit correctly assembled plug it in. while plugged in simply press the top of the back cover (where that sensor is) and the light should go green. i then taped it tight with a thin electrical tape as to not limit the airflow. it now powers on and works great.
hope that solves it for you
Mar 08, 2012 | Honeywell HHT-145 Air Purifier
Honeywell Enviracaire Elite 300 problem. Light is not on. Seems like no power to system. No snapping or noises. No obvious bent fins or broken wires
If it was wired to the return air it will have a flag switch to let it know the blower is on, sometimes the flag comes off and it wont operate, sometimes it is wired directly to the computer board on terminals EAC that stands for electronic air cleaner and the board turns the air cleaner on when the blower is running, if you have a meter you can check voltage in both places to see which one is the problem. let me know. thanks wally
Mar 11, 2011 | Honeywell Enviracaire Elite F300E-1019 Air...
My machine is 4-5 years old and it suddenly wont turn on. I switched outlets but it appears dead.
Open up the elecrical panel and see if you have any fuses form the incoming power if you do it might be blown
Aug 31, 2009 | Sun Pure SP-20 Air Purifier
Honeywell HEPAClean 99.9% HEPA Air Purifier HHT-149 Logo
Top Honeywell Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
