Question about Jenn-Air JMW8530C Electric Double Oven
How to replace lower relay board
I have replaced the board controlling clock, but lower oven wouldn't heat. Check hear sensor and it's ok. Have the replacement lower relay board in hand, but instructions that came with board say to disconnect and remove the board I just installed, then remove all cables/connectors, then lower relay board. Can I not just unscrew the lower relay board, disconnect/reconnect to new board all wires, then replace new board?
  • Cindy Smith
    Cindy Smith Nov 21, 2013
    I think my question is pretty straightforward. I want to replace lower relay board by unscrewing old, placing new, then disconnect from old/reconnect to new all cables. Is anything else required?
myob247
  • 1342 Answers
SOURCE: inserting ribbon connector into New electronic clock assembly
If it is a flat ribbon there will probably be a retainer clip that either lifts up or slides up and down to hold the ribbon.
Posted on Jun 15, 2008
docjohn174
  • 943 Answers
SOURCE: lighted clock and controls intermittently not working. Oven still heats
HI thanks for the question. its a common problem with the clocks. first it goes a little dimmer. then a little more till it goes so dim you cant even see the temperature that you have in the oven. the clock has to be replaced. or. buy a cheap oven thermometer. and hang on the middle rack, and adjust the temp setting to match the oven temp . save a lot of money this way. thanks. please rate my answer. thanks
Posted on Oct 09, 2008
sclarke7
  • 222 Answers
SOURCE: Jenn-air stove Model SCE30600B. Won't heat
check all the wiring at the main bus, and at the board connections could be a bad board
Posted on Oct 08, 2009
tbirdfan1
  • 3051 Answers
SOURCE: I need to replace baking element on model
Hello there:
By the way that you have described it this is right things that i have learned is be careful taking out the screws i have seen them strip out or break and dont tighten them too much once it is snug turn it 1/4 turn more
also clean the area that it connects to really well so it does not short out the new element and Please do not forgett to unplug the oven ok
hope this is very helpful for you
Best regards michael
Posted on Jun 06, 2010
fixyourboard
  • 310 Answers
SOURCE: I have a double oven. Model WW27430. The top
Looking at the schematic I see 2 possibilities:
1. I think the most likely cause is a failed "limit switch" aka "thermal fuse" aka "temperature cutout". For each oven there is a limit switch that feeds power to both elements. So the upper limit switch is probably tripped which would kill power to the upper bake and broil elements. The limit switch is usually located on the back wall of the oven cavity.
2. There are a relay board for each oven. Be sure you changed the right one.
Best Regards,
Bruce
www.fixyourboard.com
Posted on Jun 19, 2010
On a whirlpool double oven what does F2 error mean and canit be fixed
F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. If present, replace control board (clock). For SELF CLEAN models, check door lock operation. Check sensor, sensor harness, and the sensor harness connection at sensor and oven control. Also check for any causes of high resistance in the oven temperature sensor circuit. Remember: The oven control board (clock) measures resistance of sensor circuit, not actual oven temperature.
Nov 23, 2016 | Whirlpool Ovens
On a whirlpool double oven, what does F2 error mean
F1 - Control Board Failure - Replace control board (clock). F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. ... F3 - Open Oven Temperature Sensor Replace oven temperature sensor ( ). F4 - Shorted Oven Temperature Sensor ( - Replace oven temperature sensor
Oven heating up slowly
there should be 240 volts nominal at the two bake terminals if one side is deal as in a bad relay on the control panel the element wont heat or may get warm due to a voltage phase leak,check the oven sensor rod resistance at the control board by unplugging the 2 terminal plug off the panel you should get about 1100 ohms at room temperature
Nov 04, 2012 | Ovens
Kenmore Electric Double Oven Mod 9114832592992 got F2 code in middle of selfclean what do I need to fix?
Hi, i found three all same series... If it's occasional I'd leave it 'till was always on? Anyway .....
F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC)
OR....
F2 Oven temperature sensor shorted Replace oven temperature sensor
OR
F2 Temperature runaway detected (Bake/Broil: 600 - 700 F; Clean: 930 - 1000 degrees F). Sounds alarm and resets to non-cook mode. Check relay board for stuck contacts. Check oven temperature sensor for normal room temperature resistance (1085-1097 ohms at 75 degrees F). Check sensor wiring connectors for a loose or high resistance connection. Check electronic range control (also called clock or ERC) functions Replace relay board if necessary. Replace oven temperature sensor if other components check normal. If failure repeats, replace electronic range control (also called clock or ERC)
Oct 26, 2010 | Kenmore Ovens
Self-cleaning oven F2 error message
Well I found three all same series... If it's occasional I'd leave it 'till was always on? Anyway .....
OR....
OR
Feb 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Amana EvenAir Convection Plus AOCS 3040: The oven starts to heat up, never quite gets up to temp and then temp drops down. I had an appliance repair man out to look at it and he said that since no error...
Something else you can check while it's preheating: a few drops of cooking oil on the bottom of the oven will tell you if your lower element ("bake") is functioning at all. If it's working, you will get smoke during pre-heat (turn it off!!), if it's not - the problem *can be* in the relay board. Does your "Broil" function work ok.? if it does, then chances are your ERC (electronic range control - the main board that controls all functions) is fine, and the problem is now MOST likely in the relay board. The lower "Bake" element does most of the work in the oven - if the oil trick doesn't give you some smoke, let a tech know that the lower element is not functioning. That will help narrow down the troubleshooting scope.!
Dec 23, 2009 | Amana AOCS3040SS Electric Single Oven
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
Dec 18, 2009 | Ovens
F3 f4 f8 on a ge modeljtp15wdw2ww
GE Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both. F1 Stuck touch pad Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both. F2
During
BAKE Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature. F2
During
CLEAN Control senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature. F3
or
F4 Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Loss of relay drive circuit If this fault code cannot be cancelled, replace the oven control (also called clock or ERC). F8 Shorted meat probe Problem could be with the probe, the receptacle, or probe circuit. Check probe. Look for pinched wire. Look for condensation or contamination on probe receptacle. F9 Lock switch Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. FC Problem with door lock circuit such as pinched wires between control and door lock switches on motorized lock circuits Check wiring and test operation of switches. FD Shorted meat probe Problem could be with the probe, the receptacle, or probe circuit. Check probe. Look for pinched wire. Look for condensation or contamination on probe receptacle. Replace probe if all else checks out ok. FF Loss of door motor safety switch Replace the oven control (also called clock or ERC). FFF Control error, failed EEPROM Replace the oven control board (also called clock or ERC).
The main control operates a series of software commands, which control the various features and functions of the oven. Each function or operation has a numerical value assigned to it. The numerical values can be added up - this is called the check sum operation. Every time the system is powered up and after each clean cycle the system performs a check sum and compares the value to the value programmed into the software (stored in memory).
An EEPROM check sum error or FFF code occurs when the values differ. If this happens, replace the oven control board (also called clock or ERC).Here is a list of error codes and corrective action that should be taken. Mike
Nov 23, 2009 | GE JTP15 Electric Single Oven
Jenn-Air JMW8530C Electric Double Oven Logo
54 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
