Question about Federal Signal Legend Lightbar
One light stays on constantly
One light in the front stays on constantly and i need to know how to correct the issue.
Yamaha xt 125 rear brake light not working
Hi, Anonymous before diagnosing any brake light issue always check the bulb and fuse first for integrity a brake light staying on is usually caused by the front brake light switch, which is mechanical, not disengaging. On early models moving the throttle control housing closer to the front brake master cylinder is the main fix. On late models, the switch gets tweaked and needs to be realigned. A brake light that does not come on when the brake lever is applied can be caused by a faulty switch or no continuity in the wiring at the switch. The rear brake light switch is hydraulic and it is extremely rare to malfunction in a closed circuit condition causing the brake light to stay on. Usually, rear brake light switch issues are caused by no brake pedal free play or a sticky rear master cylinder piston. A brake light that does not come on when the rear brake pedal is depressed can be caused by a faulty switch, air contamination in the brake line, or no continuity in the wiring at the switch. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
https://yamahaclub.com/forums/topic/27490-yamaha-xt-125-x-brakelight-switch-help
http://www.rhinoforums.net/audio-lighting-electrical/70342-brake-constant-lights-do-not-work-but-brakes-light-work.html
Yamaha xt 125 service manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xt-owners-manuals
Aug 26, 2012 | 2006 Yamaha XT 125 R
Burner light stays on
This is caused by a faulty sensor that is located between the burner element and the top. To replace the faulty part you will need to uninstall the cooktop and remove the glass top. The sensor is a rod a little smaller than a pencil that you will see right on top of that burner.
If you choose not to replace the sensor it will not cause any issues other than you will have to live with that light constantly on and you will know when the top is hot for that element.
Jun 19, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Control locked light stays on after load is finished.
The Control Lock is a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, or by leaning against the control panel and usually is not an indication of a washer malfunction.
If this is a Whirlpool Duet, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue (such as an operator console problem or main control board issue). If you need further assistance, please let me know. I hope this corrects the problem for you.
Mar 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
4 wheel drive light wont go off.
some time if you drive in reverse a couple feetit will go off if your sure you have it back in 2 wheel drive or if your is like mine it will be off next time you drive it
Jan 05, 2010 | 1997 Dodge Ram 1500 Club Cab
Washer does not go on control locked light stays
You may have inadvertently locked the control panel. Before assuming you have a malfunction, read the following: The Control Lock is actually a safety feature that allows the consumer to lock the control panel to prevent small children from manipulating the controls. It can inadvertently be set following a power outage, or by leaning against the control panel. The following link explains how to turn the feature on/off:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
These instructions are printed on the front panel of the appliance and in the owner's manual. If this does not correct your problem, then you may have a more serious problem than a simple operator control issue. If you need further assistance, please let me know. I hope this corrects the problem for you.
Dec 29, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Disc can eject and be inserted but display does not light up, none of the buttons do anything. tried a different deck and it does the same thing the display dosen't work and no music plays. i am thinking...
It sounds like they messed up your installation. You can confirm their work by verifying that each wire was attached properly.
2005 Pontiac Sunfire Car Radio Wiring Diagram Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: Pink
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Click on this link for a PDF of the installation instructions of the radio (If you don't have the installation guide that came with the radio).
Illumination is the grey wire from the car to the orange with white stripe from the radio.
I suspect that the yellow wire from the car is not connected properly. When the orange wire (constant power from the car) is attached, but not the yellow wire you can insert and eject cds, but it will not turn on. Constant power is used for maintaining the clock and preset radio stations.
If everything looks correct, I would take your car back to the installer and have them correct the issue.
Dec 21, 2009 | Sony CDX-GT400 CD Player
Buckle The light on my CD burner stays on
uninstall Your cd burner and reinstall it. It is a software issue.
Jun 30, 2009 | HP Computers & Internet
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Lights on pots and pans blink constantly
try disconnecting power for a bit. try the cord under the sink. if its hard wired (no cord) you can try the breaker.
may reset itself.
otherwise, you have a logic board issue.
consult the manual first for explanation of blinking lights etc.
then call the mfg for further info and if needed, schedule an approved repair person.
good luck
mark
Dec 21, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Federal Signal Legend Lightbar Logo
530 people viewed this question
Top Federal Signal Water Sport Experts
Tom Chichester
Bill Boyd
Are you a Federal Signal Water Sport Expert? Answer questions, earn points and help others
