Question about Dishwashers
Kenmore elite dishwasher
After a power surge I lost my kenmore elite dishwasher...Tried the circuit breaker, replaced the thermal fuse...what can I try from here?
  • Dishwashers Master
  • 2,113 Answers
If you had a fault in your neutral wire the voltage may have raised to near 220 volts and fried the circuitboard. Replave the circuitboard or replace the thermistor on it. Double check the voltage and the connections where it is wired under the dishwasher.
Posted on Nov 19, 2013
4 Suggested Answers
catriver
  • 878 Answers
SOURCE: Dishwasher tripping the circuit breaker
Andy, leave the breaker off and remove the toe panel (bottom panel) from the dishwasher. Remove the cover of the junction box where the cord connection or wiring is made. Look at the wire caps and see if they are not burnt. Sometimes these connections become loose and arch, tripping the breaker. If so, cut the wires, strip a new end and reconnect. Catriver...post back.
Posted on Aug 21, 2006
SOURCE: Kenmore Elite Dishwasher Model# 665.15912001
Yeah, I have a similar problem. I tried to go into a suggested diagnostic run, but that didn't yield anything. I tried pushing the Sani-Rinse and Air Dry buttons back and forth a number of times. Didn't help.
At first I thought the lock-on had accidently been engaged, but disengaging the "child lock" doesn't help. The lock-on light comes back on and sometimes blinks rapidly. I"ve counted around 7 rapid blinks at times and 3 rapid blinks at other times--in case that makes a difference. The control panel doesn't work--in other words, the dishwasher does not start, even when I can successfully get other lights to come on. I don't want to spend >$100. for a new control panel if that is not really the problem.
Posted on Apr 10, 2008
reg501
  • 413 Answers
SOURCE: Kenmore Dishwasher, no power
There will be a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the plastic housing.
Posted on Jun 22, 2008
No power on the kenmore 17795791
Hello there and welcome to fixya
If you have checked the circuit breaker and tried to reset it whish i highly recommend then the next thing to check is the thermal fuse with a ohm meter
the thermal fuse is connected to the control board and you can test the thermal fuse AP4423189 with a multi-meter AP3873826. Here is a link on how to use a multi-meter. Hope this helps. http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4810-how-check-continuity-ohmmeter.html
Read more: http://www.appliancepartspros.com/Appliance-Parts/whirlpool-thermal-fuse-item-number-ap4423189.aspx?pn_=W10258275#ixzz1jq2iSX2T
Jan 18, 2012 | Kenmore Dishwashers
No power or signs of power
check the power going to the machined,
check the fuse or circuit breaker.
check selector switch or pushbutton switch.
Jun 04, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
No power suddenly on the control panel... kenmore elite model 665-1374/665-1384 Worked one day and not the next. Breaker is on, no blockage at water line... connections all tight. It's only 14 months old!
Kenmore dishwashers should be recalled!! Their poorly designed computer circuit boards are all malfunctioning around 15 months. Look on the inside top of your door. Do you see a instructions? There should be some about your Heat Dry button and holding it down for 4 seconds to reset your computer board. Read and try it first. It's like rebooting a computer.
Dec 30, 2009 | Kenmore Dishwashers
Kenmore elite , no heat
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 27, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer
Hi!
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Do rate the solution as FIxya if you find this solution helpful.
Thanks
Rylee
Mar 15, 2009 | Kenmore Dryers
Kenmore Elite HE3 front load dryer no power
Yes. Remove the kickplate and check the continuity of the thermal fuse located on the blower housing.
Feb 23, 2009 | Kenmore Dryers
Kenmore Elite dryer
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Hope this may help;
Rgards,
VOTIT
DON'T FORGET TO RATE;
Aug 25, 2008 | Kenmore 63942 Dryer
Dishwashers Logo
73 people viewed this question
Top Dishwashers Experts
