Question about T-Mobile MDA
My vario2.
I stupidly backed up all my files and i mean all my files to the storage card and now all i can access is my contacts which are on my front page,is there any way of reversing what i have done ? the guy in said to reload the application disk which didnt work as active sync wont respond.. can anyone help ?.
  • 173 Answers
Re: my vario2.
Solution i advise to u that
1. u can copy all contact by card to ur pda memory ...
just do it ....
 im sure u r prob will be solved...
best regards & best of luck..
Posted on Oct 12, 2007
  • 363 Answers
Re: my vario2.
Just want to get a couple of things clear. Is it possible to put the storage card on a PC to read it? When you did the backup did you erase the orignal files? Was it the application disk that didn't work or was it when you tried to get the contacts back that it didn't work? Could it be that the contacts were previously in a folder? Let me know plus any extra information you can think of an I'll try to help you resolve this.
Posted on Oct 09, 2007
0 characters
3 Points
How to format my phone
Remove the storage card from your device, insert your storage card to card reader and plug it in your PC, open my computer, right click on the storage card drive icon, select format.
This the best way to format card and if you want to format entire cell then you have to do it just manually deleting files and contacts.
i suppose, by formatting, you mean to reset the phone to the factory settings.. you can do it by start > settings > system > clear storage or else you can do it by pinning the reset hole with the help of the stylus
hope it helps
Feb 19, 2011 | HTC Touch P3450 Smartphone
Hello! I have a problem. My HTC Diamon 2 in Russian I need to change it from Russian to it possible? and can u help me please how to do it step by step, Thank U VERY MUCH
If you perform a hard reset, it should allow you to choose the language the phone displays. Just be sure to back up all your info/programs you have on the phone because it will go back to factory default when you do this!!!
Performing a hard reset
If a normal reset does not solve a system problem, you can perform a hard (full) reset. After a hard reset, the device is restored to its default settings—the way it was when you first purchased it and turned it on. You will lose any programs you installed, data you entered, and settings you customized on your device, and only Windows Mobile® software and other pre-installed programs will remain.
Warning! Your device will be set back to factory default settings. Make sure that any additional installed programs and/or user data have been backed up before you perform a hard reset.
Important If Encrypt files when placed on a storage card is enabled, backup all files from the storage card before using Clear Storage, hard reset, or updating the operating system. Otherwise you will no longer be able to access the encrypted files on the storage card. Use ActiveSync or Windows Mobile Device Center to transfer files between your storage card and computer. After the procedure, copy your files back to the storage card.
To perform a hard reset
With the device turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then briefly press the POWER button.
2. Continue pressing the VOLUME UP and VOLUME DOWN buttons until you see this message on the screen:
This operation will delete all your personal data, and reset all settings to the manufacturer default settings. Press VolUp to restore manufacturer defaults, or press other keys to cancel.
Release the VOLUME UP and VOLUME DOWN buttons.
4. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset.
Using Clear Storage
If you can access the device settings, you can use Clear Storage to reset your device back to factory default settings.
1. Tap Start > Settings, and then tap All Settings.
2. On the System tab, tap Clear Storage.
3. Enter "1234" and then tap Yes.
Dec 17, 2009 | HTC Touch Diamond Smartphone
I was given a blackberry pearl 8100 and am trying to import my pictures from my device. i was able to from my media card, but not from the device. how can i get these pics off my phone and onto my...
Most of the mobiles will prompt the user to select the mode of connection when connected to computer such as "Mass storage mode/data transfer mode" and "PC suite/modem mode". If you select the "Mass storage mode/data transfer mode", then only your mobile phone's memory card is connected to your system just like pen drive. so only the pictures present in momory card can be accessed. For transfering pictures from phone memory, try the following methods,
1. Go to your file manager in mobile phone, move the pictures from your phone memory to memory card.
2. Install proper PC suite for your mobile, connect to system in phone mode/modem mode/pc suite mode. Then using the PC suite file manager in your system, oyu can access files stored on to phone memory as well as memory card.
3. Connect a bluetooth dongle to your system, establish a bluetooth connection to your mobile. Threw bluetooth file manager from your system, you can browse the phone memory of your phone.
I hope any of the above tips may solve your problem.
Sep 09, 2009 | RIM BlackBerry Pearl 8100
My HTC P4350 is running low on free storage space
The system have used nearly the maximum internal memory available: Storage: Total 33.45 MB; In Use: 32.80 MB; Free: 0.66 MB Program.
If you already deleted or moved to memory card your files, that means that the space is taken by installed application/games, or by files left over by previously installed applications.
Save all your files on computer and do a complete reset of the HTC, restoring system to factory settings.
Aug 28, 2009 | HTC P4350 Smartphone
Phone hang and momery full
You transfer all the files stored in the device memory to storage card by using the file explorer or by connecting the same with the PC.
Sync all the data including the note calendar etc with the computer using the Windows mobile device center (you can download the same in the link ).
Click on the clear storage by navigating start>settings>system>clear storage and verify the same by 1234.
Caution all the software will be removed and it can be restored by means of the launch program in the computer start menu.
After the phone is restored to the original state sync the phone with the PC and use the launch program to restore the installed applications.
Make sure to install all the applications in the storage memory and the data too.
Jul 18, 2009 | O2 Xda Atom Exec Smartphone
Storage option is not there
just go to file explorer. click menu and u'll find storage card  option there. u can access files in storage card der. good luck...
Jun 12, 2009 | i-mate Smartflip Smartphone
Transfered memory to a storage card.
you could try a hard reset (It will delete everything like files/contacts etc thought)
Hard Reset
press and hold the left and right soft keys together and at the same time, use the stylus to press the RESET button at the bottom of your device. You will be presented with a menu saying 'press SEND to restore factory default, press END to exit', if you press SEND Your device will be set back to factory default settings.than Press "OK" to boot...
Mar 19, 2009 | Dopod D810 Smartphone
In My HTC P3400i the start menu containt application and setting are removed how to get them back.
Please provide solution.
Mar 19, 2009 | HTC S710 Smartphone
Mini SD card
Goto the Start Menu, then down to File Explorer. Hit the menu Softkey and scroll down till you see Storage Card. The other way is if you hit the Up softkey while in /My Documents (where file explorer defaults to), just scroll down and you should see Storage Card. It's easy to tell because it has a small pic of a MicroSD card on the folder. Hope this helps!
Mar 10, 2008 | T-Mobile Dash Smartphone
it wont play itunes music, u have to convert them back to wma files or atleast make them be able to play in wmp on ur comp..
Sep 12, 2007 | Samsung BlackJack
T-Mobile MDA Logo
Top T-Mobile PDAs Experts
Martin Murray
Are you a T-Mobile PDA Expert? Answer questions, earn points and help others
