Question about Frigidaire Stove/Oven/Range Cooktop - 318079348
Frigidaire oven not working
Only one of the controls in the oven panel works
2 Suggested Answers
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: I have a Frigidaire Gallery Professional Series Stove and Oven unit. The oven temperature indicator light has been fading for years and is now barely visible. Everything else on the control panel (ti
    Hello arab125 - I understand that the timer and clock works fine, however from what you have described it sounds like the range could possibly have a wiring failure, faulty sensor, or an issue with the EOC. I would suggest contacting a professional to move forward accurately.
    Posted on Oct 11, 2012
    Oven Lock stuck open before start of self-cleaning cycle I get a code F9, a flashing lock light, a continous beep and a dr code on the panel when I try to set self-cleaning cycle again.
    Thank you for your inquiry, Lucie!
    From what you have described your Frigidaire oven lock is stuck open and you are receiving error codes "F9" and "DR". The "F9" error code stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
    Apr 30, 2015 | Frigidaire Stove/Oven/Range Black Glass...
    I have a frigidaire ples389dcc as soon as i plug it in it give me a pf code
    Good Morning Paul, thank you for your post!
    Based off what you have described your Frigidaire range, PLES389DCC, is providing you with an error code of "PF" and "F1" as soon as you turn it on. An error code of "PF" stands for power failure this could be a possible problem with your control panel or power cord.
    The error code "F1" stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. If you continue to have issues with the "F1" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. Hopefully this information has been helpful. -Matt
    Apr 10, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
    Where are the fuses on a fridgidare range,glass top,everything works except thesettings for my stove doesnt light up
    Thank you for your post, friend!
    Based off what you have described the settings on your Frigidaire range do not light up and you would like to know the location of fuses. There are no fuses within your range, if the control panel is not lighting up it could be a short within your panel and that may need to be replaced. I would recommend having a professional technician out to disassemble your range and replace any electrical components. This will protect you from any personal injury and future issues with your range. Hopefully this information is helpful. -Matt
    Mar 10, 2015 | Frigidaire Stove/Oven/Range Black Glass...
    Burners wont work any more
    Good Morning Fern mullen, I appreciate your post!
    Based off what you have described your burners are no longer working on your Frigidaire range. This could be an issue with your control panel or the switch. I would recommend performing a reset on your range and you can do that by disconnecting power from the range for at least ten minutes. If that does not help correct your issue I would suggest having a technician out to your home for a proper diagnosis and repair. Best of luck! -Matt
    Feb 28, 2015 | Frigidaire FGEF306TMF 30" Freestanding...
    The control panel displays LOC and the time. oven door opens but unable to reset any controls. is there a way to reset the controls??
    Look on the panel for a key that says lock or has a key on it and hold it for10 seconds to see if that clears our
    Sep 26, 2014 | General Electric CGS990SETSS GE Cafe 30""...
    Why won't our oven fan turn off? The oven has not been used and oven is cold.
    Hello friend, thank you for your inquiry!
    I understand that your fan is not turning off and the element reads "HE" on your Frigidaire range. It sounds like you could be having an issue within your control panel or wiring harness. It may not be communicating properly to your fan or element that it is shutting down. I would recommend having a technician come out to properly diagnose and repair your appliance. -Matt
    Sep 01, 2014 | Frigidaire Ffes3025lw 30 Smooth Top...
    Why would there be no heat from frigidair oven elements?
    Make sure the oven timer is set properly, if its turned off, the oven will not go on. Also check if the oven has separate fuse, it may have blown.
    Aug 24, 2014 | Frigidaire Stove/Oven/Range Black Glass...
    How to turn oven on on a Kelvinator Cookarama Oven (Older model)?
    You need to hold /push the oven control knob in quite firmly while you press the igniter. When it lights up keep holding for about ten seconds then gently release it.
    Jun 02, 2014 | Kelvinator Refrigerators
    I have an LG electronic range it is on recall for the burners going on spontaneously, they have yet to fix this for me. Now the oven set buttons for both the regular and convection over will show and
    Thats what is sounds like to me- or the keypad..... Anytime you have multiple malfunctions of of the control panel, it usually is one or the other. Hope this helps. Good luck, Dennis Wayne
    May 08, 2014 | LG Electronics Range. 30 in. SeCleaning...
    Frigidaire Stove/Oven/Range Cooktop - 318079348 Logo
    37 people viewed this question
    Top Frigidaire Cooktops Experts
    Oloyede Monsuru
    ray gallant
    Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
