Question about Horizon Fitness T101 Treadmill
Delayed and sputtering motor start
Tested motor with 12 v battery and is fine. Replaced motor control board. When pressing start, there is a 5 second delay before the motor starts. Then, the motor jerks and sputters for a few seconds and then runs normally.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
Replace board.
Posted on Dec 30, 2013
What does code F-21 show
If it's a bosch machine F21 is motor control board error you would first test the motor to see if that was where your fault was coming from and if the motor tested positive you would then look at your control board.
You can reset the error code by the follow steps.
Turn the appliance knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off
When your turn it back on it should have cleared the error code
Apr 12, 2016 | Washing Machines
Frigidare errow code e59 display
Hi Emily,
I see that you are receiving an E59 on your Frigidaire washer. E59 states that "No Tacho" Signal for 3 seconds. I would recommend giving the appliance a hard reset. You will do this by either unplugging it or switching the circuit breaker off that the washer is attached to. When you do this you will want to leave it off for 3-5 minutes. Once the 3-5 minutes has elapsed, bring power back to the washer and try to restart it. If you are still receiving an E59 error code, I would suggest contacting your local authorized technician to diagnose and see why you keep receiving this error code.
-Best Regards-
Jan 21, 2014 | Frigidaire Washing Machines
My dishwasher wont start. After pressing start the light(s) pressed blink but doesnt start. The delayed start is not selected
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then try to reset the dishwasher control by pressing the HEATED DRY button and hold it for 15 seconds, if its still not resolved then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 30, 2011 | Frigidaire Dishwashers
I have a frigidaire affinity dryer that will dry for a few minutes then turn off and say e68 wich means one of the buttons are stuck i took the panel of the front and checked the buttons and they all seem...
Run the service diagnostic mode to determine which button is stuck. Start by pressing and holding the Select and Cancel buttons simultaneously for 6 seconds to reset the control.
Rotate the cycle selector knob 5 turns counterclockwise to the second position from the bottom immediately after the buzzer sounds.
Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control enters the test mode and the buzzer will sound 3 times with all of the LEDs flashing.
Rotate the cycle selector knob 4 turns clockwise to the second position from the top and the dryer motor runs with the heating element off. The buttons can now be tested to determine which is stuck.
Press each button and all corresponding LEDs should light. If the LEDs corresponding to a certain button lights up without pressing the button or if the LEDs do not light up when the button is pressed, that button must be stuck or not making any contact when pressed.
Replace the control board if the stuck button cannot be unstuck or if there's no button that's apparently stuck but the fault code persists. Let us know if you need further advice.
Feb 01, 2011 | Frigidaire Dryers
Belt will not start up and move.
The single most cause of no motor output is failure of the DC motor control. Look for any test lights on the power boards beneath the motor hood. Use caution when removing the motor hood because you may still have electricity ( capacitors are charged) in the motor area even if the treadmill is unplugged.
If you have a multimeter, you can test to make sure you have DC output from the controller spades ( Drive Motor Connectors) by clipping on them and then pressing the start key you should have a DC voltage reading if not the controller board is defective.
The motor can be tested by using a simple DC cordless drill or lantern battery this will turn the motor if the motor is good the controller board will need replacement , if not their won't be any belt moment the problem is the motor then the motor will need to be replaced. ( if you don' t have a multi meter this method of testing simple and easy)
May 14, 2010 | Epic 425 Mx Treadmill EPTL88105 !
Err 57 - No response from machine just flashes Err 57 Checked the resistance on the motor and it appears fine showing 5 ohms at each connection. Replaced the motor control board as advised by the tech...
sorry for the delayed response, PC problems. Anyway, it could be 1 of 3 boards. the control board, interface board, or the control panel. Visually inspect them and see if anything looks blown. Most of the time it is the control board. However, without actually seeing it it is an educated guess.
Oct 05, 2009 | Frigidaire ATF6000ES Front Load Washer
How to set time with new control board?
You may set the clock on your Microwave per page 6 of the User Guide by following the steps below. We've included the link for the User Guide below.https://www.whirlpool.com/content/dam/global/documents/200105/owners-manual-8300610.pdf
This is a 12 hour clock and does not show a.m. or p.m. To Set: Before setting, make sure the oven, Timer and Timed Cooking are off. 1. Press CLOCK. 2. Press the HR or MIN "up" or "down" arrow pads to set the time of day. 3. Press CLOCK or START/ENTER. To Disable: The clock time can be disabled so that it does not show on the display. To disable, press and hold CLOCK for 5 seconds. To display the clock time again, press and hold CLOCK for 5 seconds and the time of day will show on the display. The clock time should not have to be reset.
Nov 03, 2017 | Whirlpool GMC305PD Electric Single Oven
Kenmore 90 Series Model 11060912990 Dryer won't start
check motor (you have 2.4 Kohm ) very high read
for motor must be lower.Check capacitor if hawe.
Feb 15, 2009 | Kenmore 62602 Electric Dryer
Horizon Fitness T101 Treadmill Logo
93 people viewed this question
Top Horizon Fitness Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
wtdash
Are you a Horizon Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
