Question about Brother Disney PE-400D Computerized Sewing Machine
Needle sways while stitiching creating uneven lines.
The shank and pressure foot are fine but the needle shank has so much sway that the minute I hit a bit of extra mtl, say in the corner when top stitching, then the needle sways way out and makes a terrible stitch out of line. It didn't seem this loose in the store. Is this a problem or just a bad design I'm stuck with. So sloppy in general you can't even line up the mtl with the foot because the needle sways about so much. Hate it for that but love it for all the rest.
  • 3 Answers
Two things come to mind. First, if your bobbin and upper thread tension are too tight, they may be pulling the needle out of line. More likely though, is you do not have the correct needle for the weight of fabric you're using. For example, a heavy jean type denim will require a thicker needle than a thin sheet type of cotton. Your sewing store can help you select the correct one.
Posted on Nov 19, 2013
SOURCE: brother CS-6000i
I have the same problem but I believe the answer is to purchase a new shuttle which is the part the bobbin sits in and is most likely scratched or damaged. The quote I got was 40-50 dollars
Posted on Nov 18, 2007
SOURCE: Uneven thread tension in same line of stitches
can u showe me a visial on how to thread
Posted on Aug 02, 2008
bibleman01
  • 334 Answers
SOURCE: Brother CS-8150 Won't Work in Reverse
Look at the feed dogs under the foot see if they are raised high enough to pull the material through.
Posted on Dec 05, 2008
  • 66 Answers
SOURCE: I was given a brother
Hey RM check the bobbin area and see if the hook area has any thead cought in it you might have to remove the bobbin case to see it
Posted on Jan 30, 2009
RickE1
  • 202 Answers
SOURCE: Tension problems
Possibly you have the bobbin in upside down and its turning the wrong way. Read manual. If you have done everything the manual says then it must be a mechanical issue such as the small thread take up spring or maybe the tensioner discs are dirty. Timing slightly off or there is a burr on the hook that catches the thread. Have a tech look at it.
Posted on Feb 11, 2009
When I sew silk or fine fabric the thread breaks and the fabric bunches up, what am I doing wrong, I first had the A foot and changed to B, changed the needle and still the problem persists
Check to be sure you are using needles and thread that are compatible with the fabric. Generally, finer threads will work better on fine fabrics along with a smaller needle. Be sure to change needles frequently as dull, bent, or nicked needles will cause very frustrating issues.
All About Needles
Remove the thread completely from the machine. RAISE the presser foot and rethread from the beginning, making sure the thread path is correct.
Some machines have a presser foot pressure adjustment (consult the owner's manual). Adjusting the pressure that the presser foot applies to the fabric & feed dogs is helpful when sewing especially fine or heavy fabric. Also, when sewing fine fabrics, loosening the tension could be beneficial.
Changing presser feet may also help, ie try using a straight stitch foot vs a presser foot for zig-zag stitching.
Something else you can try is finding a presser foot with a teflon finish or a roller foot that will glide or roll with the fabric through the machine. Even if you can't find a brand name presser foot for your particular machine, an adapter shank can probably be found that would allow you to use snap-on feet of all different designs and uses. Provides a lot of choices for presser feet for less than purchasing a brand-name presser foot. There are snap-on kits available on eBay and other auction sites.
Some machines also can take a straight-stitch needle plate--usually an additional accessory that can be purchased. The hole where the needle penetrates the needle plate to access the bobbin thread is actually a small round hole. With a zig-zag needle plate, the hole the needle penetrates is a wide rectangular hole that can allow fine fabrics to be pulled down through the hole. Zig-zag capable machines usually have a zig-zag needle plate as standard.
Feb 22, 2016 | Sewing Machines
My machine is a Husqvarna Prism 980, and I'd like to know if it's a high shank or low shank.
Take a Measure
With the presser foot in the down position, measure from the Needle plate of the machine to the center of the thumb screw of the ankle of the machine (the part that the presser foot snaps on to).
Low Shank - measures ½"
High Shank - measures 1"
Most consumer machines are low shank. There is probably not a walking foot that is made for this machine but there may be some third party suppliers that have a walking foot that will work. Stitchery Sewing Machine Attachments Needle and Thread
Apr 10, 2015 | Husqvarna Sewing Machines
Needle hitting pressor foot
Presser foot not correctly mounted, or needle bent, or needle bar loose or bent are the most likely.
Mar 18, 2014 | Kenmore Sewing Machines
Does the Stitch in the Ditch foot have slot for the needle, the one have has a central hole, I need to be able to move the needle positinn slightly to the right. many thanks. Yvonne Kneubuhler ...
I always stitch in the ditch with my regular clear plastic pressure foot so I can see where I am stitching and keep the stitches falling into the seam gap (the ditch).
Sewingpartsonline.com have a "stitch in the Ditch" foot and it looks like it has a wide slot. It seems to have a nice metal rudder to line up in the seam line and that looks central so you'd still be stitching right in the middle of the foot I'd say if you used this one.
link is http://www.sewingpartsonline.com/stitch-in-ditch-foot-low-shank-p60706.aspx
But you'd need to get the correct foot for your machine, that one is a low shank so it may well fit if your machine is a low shank type.
Sep 21, 2011 | Sewing Machines
Needle breaks because it hits the area around the bobbin.
Here are a few things to check. You may have checked some of these already but it may be worth checking again.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but check your manual), make sure that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot
Make sure it’s attached securely.
* Change your pressure foot
Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins
A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew
You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate
Make sure it's securely in position.
* Change your needle plate
If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics, switch to a needle plate with a wider hole.
* Check the position of your needle
Sewing machines with zigzag capability allow you to adjust the position of your needle – right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 30, 2009 | Sewing Machines
I have broken 2 needles and now the new needle (foot) will not move up and down. i have double checked all settings and nothing has helped. any suggestions
Here are several solutions for you to try.
* Your broken needle may have been too thin for your fabric. Make sure your replacement needle
is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric. When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot to make sure it’s attached securely.
* Change your pressure foot. Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins. A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate to make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle, right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 23, 2009 | Bernina Artista 180
Keep breaking needles
Here are some solutions to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Check your needle plate and make sure it's securely in position.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
Hope this helps.
Sep 20, 2009 | Singer 132QRFB Mechanical Sewing Machine
When i use my janome overlocker the needle is hitting the lower looper, and therefore breaking. This is happening with both needles. I have taken the covers off and the needles are hitting the metal. Is it...
Here are a few things to try.
* When you insert anew needle, make sure it’s positioned correctly. Usually with the flat side
away from the bobbin, but consult your manual. Make sure that it goes all the way into the holder, and that the screw is securely tightened.
your needle.
pressure foot.
I hope one of these solutions help you.
Sep 14, 2009 | Sewing Machines
My PE 100 keeps breaking needles, they are striking something during use.
    Here are some things to try.
    * Your broken needles may have been too thin for your fabric. Make sure your replacement needle
    If this doesn’t seem to be the problem
    I hope this helps.
Sep 11, 2009 | Brother Sewing Machines
Attaching walking foot
you probably purchased the incorrect walking foot for your specific machine. check and make sure if you have a high shank or a low shank....the way to determine if you have a low-shank is to measure the screw from the plate and look at the distance if it is 5/8 then you have a low, any higher about 1in. then you have a high shank, so you would purchase a foot depending on your shank.
Mar 20, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother Disney PE-400D Computerized Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
