Question about Honeywell HHT-145 Air Purifier
HonywellHHT-145 sat for a couple months now there is no power
Hoover wind tunnel can the dirt cup be washed it smells horrible and I am moving to new house and dont want to stink up the house with this vacuum I hate to go out and biuy a new one as this one is on
yes you can wash the dirt container in worm soapy water,rinse off and make sure it's absolutely dry before you use it again.this link is for the manual if you need it. good luk in your new home.***
http://hoover.com/file/570/
Sep 21, 2012 | Hoover WindTunnel Rewind T-Series UH70120...
No power
mine was having the same issue. its been broken for 2 years now. i jsut fixed it a few minutes ago. there is a button sensor behind the top filter. if its not pushed in all the way it wont turn on. my filter was in correctly, but the button doesnt appear to be depressed all the way. when fastening the back cover it locked in good, but was still slightly loose. those two things together means the sensor wasnt being triggered.
with your unit correctly assembled plug it in. while plugged in simply press the top of the back cover (where that sensor is) and the light should go green. i then taped it tight with a thin electrical tape as to not limit the airflow. it now powers on and works great.
hope that solves it for you
Mar 08, 2012 | Honeywell HHT-145 Air Purifier
Gentlemen: The LCD display on top of the purifier indicated that the filters were dirty. We removed the 2 filters, vacuumed both sides and reinserted them. We are still getting an indication that the...
According to what I found, if the filter is not reinstalled just right, it won't trigger the filter being back inplace switch.Also, try unplugging the unit for 30 minutes and then plug it back in. That may reset the switch. If tall else fails, call Honeywell Customer Service at 877- 841-2840.
Hope this helps to solve the problem, JR.
Mar 07, 2011 | Honeywell HHT-145 Air Purifier
Replace air filter warning light to reset?
1. Plug unit into outlet. 2. Press power ON/OFF switch to the ON position. 3. Allow unit to start running at low speed. 4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink. 5. Release both the UP and DOWN arrow buttons. 6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
Sep 30, 2010 | Filter Queen Defender Air Purifier
After cleaning and replacing filters, won't turn on
I have had the same problem. The way I fix mine (it only runs for a couple days staight) is to switch the two filters (or maybe you just need to remove completely?) making sure they are in tight. Replace the cover and it should work!
Sep 06, 2008 | Honeywell HHT-145 Air Purifier
Fan Noise
Your fan motor probably needs additional maintenance, in the way of lubrication.
After removing the unit from power, access the Fan blade and spin with finger. If there is any resistance to note then the spindle running through 2 bearing surfaces needs lubrication.
See the other question/answer to fan removal - motor lube.
If you have any sort of humidity to contend with and have a FreshAir model F1 or earlier different type, they seem to have some corrosion problems after a period of a couple years.
It is just a function of the machine/job that necessitates such maintenance.
Jan 12, 2008 | Ecoquest Fresh Air Air Purifier
Cleaning the fresh air purifier
You have cleaned the purifier. Now on the front there is a reset button next to the power button push that to reset cleaning cycle.
Oct 10, 2007 | Ecoquest Fresh Air Air Purifier
Honeywell HHT-145 Air Purifier Logo
64 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Billy Mac
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
