Question about Bosch 11236VS Rotary Hammer
How to take knob off bosh 11236vs - Bosch 11236VS Rotary Hammer
    Champion:
  • 304 Answers
Turn lever to the right until it stops, then push the red button in with a screwdriver and at the same time turn the lever clockwise a bit more until it stops. Wiggle lever and it will come out.
Posted on Feb 03, 2014
Our bosh Maxx 7 varioperfect washing machine buttons are not working Amd showing f:21 error
F21 error on this model of Bosch washing machine pertains to a motor or a control board fault. This can be reset and to reset it turn the appliance knob to the off or reset position (12 o'clock), turn the knob to the 6 o'clock and then press and hold the spin button, then while holding that button turn the knob to 7 o'clock position, continue holding spin button for 15 seconds and then turn the knob to off. After a minute turn it back on, if the error code is still there then it means that the motor or brushes in the motor should be replaced, though it is always better to replace the motor assembly completely.
Nov 17, 2016 | Washing Machines
The blade on my jigsaw keeps flying out when i try to cut wood ive inspected the the place where the blade goes looks ok please help
There are diffrent blades for difrent makes ,Did you by the correct make e.g if its bosh by bosh blads .The slot might also be worn out if you used the wrong blade in it or the screw that holds it in is warn ,Hope this helps
Oct 01, 2014 | Saws
How to replace knob assembly on bosh 1 1/8 rotary hammer drill 11222 evs
Push the red button all the way in as far as it goes and turn the knob to the left (counter clockwise) past it's normal position. Then you can pull the knob out. When you replace it make sure that the pin part fits inside the slot of the shifting arm inside the tool.
Aug 07, 2012 | Bosch Drills
How to replace knob assembly on bosh 1 1/8 rotary hammer drill 11222evs
Here is a link to the parts diagram. It shows what position the knob needs to be in the remove it. You also have to push the button in further then normal. I just use a small screwdriver. Once you rotate it further past the last position you will be able to lightly pull up on it while slowly rotating and it will release. It has tabs molded into the plastic knob so it can only come out when they align with the housing it fits into.
Bosch 11222 diagram
I have taken my bosch rotary hammer apart for cleaning, now i can't put the switch spring to the knob switch
Alright, look at the picture. if (49) is missing the little tab on the opposite side shown, you will need a new shifter knob. Ideally, you would insert (83) into (49) and then push them into the knob until you hear and feel it click, that would mean that the tab has locked into the knob, and then with a pick you will set the shift fork opening in the hole to the northwestern corner of the hole. Then, making sure (46) is aimed through the shift fork wire opening, set the entire knob assembly down on the housing, push (49) all the way in until you feel the entire knob settle in further on the housing, and then rotate counter clockwise and press down at the same time. At this point the knob is installed. If (49) is damaged, I would suggest getting the knob assembly(32). The part number is 1-612-026-037 and costs about 9 dollars. It can be purchased online, or through your nearest bosch service center.
http://www.boschtools.com/Service/ServiceCenterLocator/Pages/default.aspx
I hope this helps.
Dec 04, 2010 | Bosch 11236VS Rotary Hammer
What is the error code f21 means on a bosh washing machine?
F21 relates to a motor or control board fault.
However, it is also caused by spikes in the mains and can be spurious.
To reset it.
Turn the appliance knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button.
Whilst holding it, turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds.
Release the button.
Turn the knob to off.
When your turn it back on it should have cleared the error code.
Nov 27, 2010 | Bosch Classixx WFO 2866 Front Load Washer
Switch problem, where can i get new one
www.toolpartsdirect.com
just make sure you have the correct model...i linked it to the bosch 11236vs
you can also get it directly from bosch
the part number your looking for is 2607200578
Sep 26, 2009 | Bosch 11236VS Rotary Hammer
Chuck came off of drill on a Bosch 11236VS hammer drill
Have you pulled the collar to release the pressure on the steel balls. Just pull the collar usually forward and slide on the shaft and then release and twist till it locks. Let me know if I can help further
Jan 07, 2009 | Bosch 11236VS Rotary Hammer
Bosh 4000 table saw , using dado blades.
no good solution for that problem. dado blades vibrate and cause the knob to turn. possibly a clamp on the knob to keep it in place.
tom
Nov 25, 2008 | Bosch 4000 - 07 Electric Table Saws
Bosch 11236VS Rotary Hammer Logo
180 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
Tim Venetis
Are you a Bosch Drill Expert? Answer questions, earn points and help others
