Question about Brother MFC-8480DN All-In-One Laser Printer
My brother mf8480dn scanner is scanning slow - Brother MFC-8480DN All-In-One Laser Printer
Scan to pdf
Hi there, have you downloaded the latest scanner software from Brother and then do the scan from within the software interface. When you press the scan button, do you get the option to scan to and then the format that you want the document scanned. Here is a link to the scanner software from Brother. Downloads MFC 8860DN Others Brother
Good luck and I hope this helps.
Jun 25, 2014 | Brother MFC-8860DN Printer
Scanning and copying are slow and have a dark background
you probably have a bad power supply weak capacitors do this
35 years experience here
Apr 11, 2014 | Brother IntelliFAX Office Equipment &...
Brother control center 4 won't open on my computer
This may help others with scanning issues:
I just bought a Brother MFCJ6510 printer/scanner and was nearly driven cracked trying to get the scanner to work as it was not talking to the PC, even though as a printer it was working fine. Realised eventually that it was just the Brother Control Centre 4 it wasn't talking to. After hours of re-installing software and updates, etc, nothing worked.
The solution: I went into Control Panel on my PC (I use Windows XP), to the Scanners and Cameras section, and in there the Brother Scanner was visible and could be used from there, Click on it to open the Windows Scanner and Camera Wizard and use that. Further, by right-clicking on it and going to properties I choose the software to start when it talks to the PC. I abandoned the Brother CC4 and set it up to start the Scanner and Camera Wizard if I choose 'Scan to Image' on the scanner control panel, and to open Photoshop if I 'Scan to File' on the scanner. Works fine either way, just make sure you choose the right dpi setting to suit your needs.
Hope this helps somebody else as frustrated as I was.
Apr 17, 2013 | Brother DCP Office Equipment & Supplies
Brother mfc-j6510dw will not scan
I just bought this and was nearly driven cracked trying to get the scanner to work as it was not talking to the PC, even though as a printer it was working fine. Realised eventually that it was just the Brother Control Centre 4 it wasn't talking to. After hours of re-installing software and updates, etc, nothing worked.
Aug 09, 2012 | Brother MFC J6510DW - Multifunction fax /...
Scanner scans slow
Check the resolution. An average resolution is 300 ppi. If you choose higher values (600 ,1200) it will take longer.,
Aug 02, 2012 | Brother MFC-8480DN All-In-One Laser...
Have MFC 5890CN Brother. How can I scan legal documents?
To scan legal documents you need to set the scanner to legal. GO to Start menu / all programs / brother / scanner utility and set the size to legal.
Thanks,
Pat
May 11, 2010 | Brother MFC-5890cn Color Flatbed...
Trying to scan 35mm slides
slide scan is not an option on that model. slide scanner is an option in some models of scanners. I have a HP one as most HP scanners have the setting built into the scan firmware that lowers and higher the light to get correct scan. brother model will not do this its just normal scan setting.
Feb 16, 2018 | Brother MFC 240C All-In-One InkJet Printer
Brother Scanner, scans the page but prints black and vertical
I called technical support for this issue previously with my brother mfc. It would only do this during color scanning. b&w scanning was just fine. The tech support put me through resetting the reference point of the scanner through a series of button pressing and closing and opening the paper feeder. I kept gettting the same lousy results. Then they determined that the scanner module needs replacing and I needed to take to the nearest service center.
Dec 23, 2008 | Brother MFC-8640D Printer
Scanning speed slowed...
did you change your scan resoulution? The quality of your scans will determine how slow it will pass through. another thing to check is weather it is scanning both sides, another option in your scanner properties.
Jun 27, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
Will not scan
This was on the Brother web site..
Title:
I cannot scan after installing the scanner driver using Windows®/ Mac OS® 8.x-9.x.
Description: Please follow the instructions below
Turn off your machine, disconnect and then reconnect the USB cable to your computer.
  1. Start "Device Selector" by double clicking "Device Selector.app" in //Library/Printers/Brother/Utilities/Device Selector folder, or by clicking " Model" on the upper-left corner of the Brother Control Center 2.0 and selecting "other".
  2. Select USB as the connection type. Your machine name will appear on the list. Select your machine and click OK
  3. Close the Device Selector
  4. Open your scanning application and test.
http://welcome.solutions.brother.com/BSC/public/eu/gb/en/faq/faq/000000/000700/000062/faq000762_000.html?reg=eu&c=gb&lang=en&prod=mfc5840cn_all&Cat=2
Guess it's a long shot.. Hope it helps.
Apr 29, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-8480DN All-In-One Laser Printer Logo
51 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
