Question about Infinuvo CleanMate QQ-2 LT Robotic Vacuum Cleaner with home base,
Cleanmate geeft error en number 80. - Infinuvo CleanMate QQ-2 LT Robotic Vacuum Cleaner with home base,
Error 5 roomba 500
This link is for the manual it doesn't tell you much about error numbers but at the bottom of page there is a customer care phone number.
http://www.robotshop.com/PDF/roomba-500-series-users-manual.pdf
Nov 14, 2012 | Vacuums
I have a 20yr old electrolux central vac that the motor just went bad. in wondering whether to replace motor or replace whole unit i have found an electrolux unit and a aerus unit. someone told me elect....
Motor to replace or rebuild:
Depending if your motor just started to get noisy, you can take it to a private vacuum repair shop and most rebuild for around $80 to $100.00. Usually they replace top/bottom bearing and the armature carbon brushes.
If it's loud and vibrating and probably sparking. Do not bother to rebuild, the armature is now probably damaged and not worth the new parts.
Replacing the motor is pretty basic and usually saves you about $150.00. They're pretty simple to release out of the unit and are pretty simple to remove and reinstall.
To find out your replacement motor number you will need to find the stamped model number on the motor itselt. It is a 6-8 digit number. That is the Ametek Motor Model number. Ametek is used in pretty well all central vacuum systems. Motors range from $99 to $239.00
www.ametekfsm.com/Product_Compare.aspx?MT=1&MST=1&FanStyle=Bypass&Discharge=Tangential
Dec 30, 2010 | Electrolux Centralux Vacuum
Where can i order a hoover bag and filter for a nilfisk gsd 80 hoover and how much will these items cost me
First try online using Craiglist, Ebay, or look for local store near you. If you want to save really good. Some goodwill, Salvation Army, Value Village Stores do have new or second hand vacuum bags. Just write what you need, the Model Number, or the Type A or B Vacuum bags. Usually Hoover bags are popular. Except some new ones and also High End Vacuum like Kirby, and Vacuum from TV Informercials.
Sep 07, 2010 | Vacuums
Stopped working
Well it could be the motor, if it is it would cost around $80 or so for a motor. May be better to buy new, thre are a number of good brands out there.
May 12, 2008 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
I NEED A MOTOR FOR MY HOOVER POWER NOZZLE MOD. NO. S5682 WHERE CAN I CHECK FOR PRICES?
Part number is 43177062 and will sell for around $80. You will have to just call around to your repair shops, or maybe find one on line.
Mar 29, 2008 | Hoover U5453-900 WindTunnel Supreme Bagged...
Infinuvo CleanMate QQ-2 LT Robotic Vacuum Cleaner with home base, Logo
Top Infinuvo Vacuums Experts
Are you an Infinuvo Vacuum Expert? Answer questions, earn points and help others
