Question about Lexmark T642 Laser Printer
"lost communication" error update firmware
How to fix the error code c0150
You will need a service engineer to fix this problem it will either need a new main board or a firmware update
0150. Engine PWB EEPROM error Detecting engine PWB EEPROM communication error.
Mar 12, 2015 | Kyocera "FS-3540MFP Copier, FS3540"
We have an error 49.283 come up on our HPLJ 9050n, how do i fix tis
A 49 error is usually caused by either a corrupt print file or file that the printer does not understand. In most cases updating the firmware will resolve these problems. First, unplug all usb and network cables attached to the printer and power it on. If it comes to ready that is a good sign. Make sure that there are no stale print jobs in the queue of any computer that prints to the printer. Plug the network or usb cable back in and see if the printer continues to stay on without a 49 error. If yes, then go to www.hp.com and download the current firmware for your printer. Most firmware updates for these units are available as an easyupdate utility. Run that utility from any computer that normally prints to the printer. Select that printer from the drop down menu in the utility. After the firmware has been updated the printer will restart and you are ready to go, with your 49 error a past memory.
Jul 09, 2014 | HP LaserJet P4015N Printer
What does it mean when my printer is always writing hp 49 Service Error?
is it new maybe you need to take it in for a service there are things we can't do they are only for techs
Jun 23, 2014 | HP Hewlett Packard TopShot LaserJet Pro...
Firmware is missing
Here's the support website the instructions, download and save the firmware to a folder or desktop.I didn't see a firmware update :http://homesupport.cisco.com/en-us/support/routers/WRT54GX
Dec 03, 2012 | Linksys Wireless-G WRT54GX Router
The copier is giving error code f07
F07 Communication error between boards (LGC and SYS boards)
Firmware is where I would start along with the wall power.
If this isnt work, replaced logic board and updated firmware. Machine will must works perfectly.
Hope this helps.
Oct 12, 2011 | Toshiba e-Studio 45 Black and White Copier
My 5250 printer cannot load paper properly. It loads unevenly and displays error messages 3424, 3618, or lately 3520. I tried to upload new firmware, but no new firmware is available.
Hi there.
The error 3520 requires a firmware upgrade. Please click on this link for the firmware update.
Installation Instructions:
  1. Verify that the KODAK All-in-One Printer Home Center Software is installed and can communicate with your printer.
  2. Download the firmware file to your computer.
  3. Double-click the *.exe file, then follow the on-screen instructions. Wait for "Update complete! You may now use your Kodak Printer." to appear on your computer.
  4. Click OK to complete the firmware installation.
If your using a Mac, please click on this link.
Let me know if you need further assistance.
Thank you!
Aug 10, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
My Dell printer 2330dn is showing an error of 900.57 Firmware - what does this mean? It will not print
clogatto,
This error identifies a problem with the printers "internal language". Many times the firmware is just outdated and needs to be updated.
Since this firmware is vital in the communication of components, outdated firmware will cause miscommunication such as error messages or weird symptoms.
I would recomend having a tech update the firmware since you really need to know what you are doing.
Apr 17, 2009 | Dell Office Equipment & Supplies
Error code on hp 2420
It's a communication or hardware error.
It's best if you update your firmware. Get the files from the link below...
HP 2420 Firmware Updates
Nov 20, 2008 | HP LaserJet 2420 Printer
My wii nintendo channel keep coming up as error code 261412 every time i load it. This code comes up after you send the info
Error codes within that range usually refer to a communication problem with Nintendo's network. :1: Make sure your Wii has an internet connection, you can test this using the shopping channel, internet channel or by sending a Wii-mail to a freand. ::2: Go in to the setting panel and run a firmware (system) update to ensure you have the latest firmware. :::3: Try again at a less busy time of day, 15:00 on a week day is usually quiet. If you still have problems after a firmware (system) update message back. Nick. :)
Nov 06, 2008 | Computers & Internet
We get a communications error when receiving a fax from the HP 1050 fax
You need to update the firmware
You can get from the link below
HP firmware
On the software download page, select your Windows version.
Locate and select the firmware update.
Follow the directions to download and install the update
Oct 28, 2008 | Office Equipment & Supplies
Lexmark T642 Laser Printer Logo
44 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
