Question about Lexmark T640 Laser Printer
Send failed(): lost communication
Firmware update
Thank you for attention,my printer has version bellow ,V.xx.xx.99(v2.01.01.01) how can i update freely with third party firmware?
Dear
The firmware is locked. The firmware is embedded with SL.No. of the printer. Try search in the internate who take money and provide the suitable firmware for the respective printer. They may need few data of the printer viz. s/n,CRUM etc. and send the firmware file on email.
however genFIX v1.33 may be searched and downloaded.
Note- FIRMWARE UPDATE MAY CAUSE PERMANENT FAIL OF THE MACHINE IF ANY THING GOES WRONG. CARE MUST BE TAKEN FOR UNINTERRUPTED POWER SUPPLY.
Thanks.
Feb 02, 2015 | Samsung Sas SCX4623F...
Firmware update
If you are updating this on the internet it could very easily be you OS is too new or too old for the communication to happen. Contact Marantz or go to their website and look for a patch to make this happen.
Mar 18, 2014 | Marantz M-CR603
Artista 165 embroidery unit will not communicate with my sewing machine.
Did it ever work ? Have you had the firmware updated in the machine - if-so, the V4.04 firmware will not communicate with a V3 embroidery unit and you'll have to get them updated to the same version. Failing that, I'm afraid one of them has a fault on the serial interface. Note also that a 165 sewing machine will not work with a 180/185 embroidery unit because the earlier unit has a 2MB memory internally, whereas the later unit has a plug-in 4MB memory.
Feb 09, 2012 | Bernina Artista 180
Elonex eb500 won't turn on
My guess is that firmware update failed on Win7. Try the same thing on WinXP. More information available at:
http://www1.elonex.com/support/products/ebook/500eb-firmware.shtm
Nov 22, 2011 | Computers & Internet
Insignia firm ware updates have rendered my new BlueRay/DVD useless, it does not communicate to the WIFI, I can't even play regular BueRay DVD's.
With a failed firmware update, your machine might be totally irrecoverable. The only thing you can do is to contact the manufacturer for advice; sometimes their engineers will have utilities which will recover your machine but it's by no means certain that they will.
Sorry that this is not the answer you wanted, but with firmware problems the consequences are rarely easy to resolve.
Sep 23, 2010 | Insignia Televison & Video
My router will not connect the power light keeps blinking
Check this tip out from Linksys. It is for a G VPN Router but you could use the same steps to troubleshoot. Title: Resolving Blinking Power or Diag LED on a Linksys Wireless-G VPN Router Article ID: 4982 If the Power LED on your Linksys router is blinking, this means the device is not ready. It should go off once the router completes its diagnostic test. If the Power LED won?t go off, it indicates that there?s a possible hardware problem with the router. To resolve this, you will need to perform five steps: Resetting the Router Assigning Static IP to the Computer Pinging the Router Accessing the Router?s Web-based Setup Page Updating the Router?s Firmware For instructions on how to reset the router, follow the steps below. Resetting the Router Hold in the RESET button at the back of the router for 30 seconds. Unplug the power to the router then plug it back in. If after resetting the router and the Power LED is still blinking, try resetting the router again for another 30 seconds. Then proceed with assigning a static IP address on the PC. For instructions, follow the steps below. Assigning a Static IP Address on Your Computer Most of the time, if the power LED on the router is blinking it loses its ability to assign IP addresses to the PCs connected to it, which is why you need to assign the computer a static IP address. After assigning a static IP address on the computer, check if the computer is still communicating to the router by performing a ping test. To ping the router, follow the steps below. Pinging the Router Ping test helps trace the communication between the computer and the router. The computer sends packets to the router and in return the router sends out replies to validate the connection. In this example, our router IP address is 192.168.1.1. NOTE: If you?re using Windows 98 or ME, click here. Windows 2000/XP Step 1: Click Start, then Run. Step 2: When the Run window opens, type ?cmd? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping 192.168.1.1? and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. Windows 98/ME Step 1: Click Start, then Run. A window similar to Step 2 will appear. Step 2: When the Run window appears, type ?command? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping 192.168.1.1? and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. If you get good responses from the router, access the router?s web-based setup page to see if a firmware update is possible. For instructions, follow the steps below. Accessing the Router?s Web-based Setup Page In order to perform a firmware update, you should be able to access the router?s web-based setup page. Updating the firmware is one way of resolving the blinking power light on the Linksys router. To access the router?s web-based setup page, click here. NOTE: If you?re having difficulties accessing the router?s web-based setup page, the router is considered defective. If you?re able to access the router?s web-based setup page, proceed in updating the firmware upgrade.
Jul 21, 2010 | Linksys Wireless-G Broadband Router
My wii nintendo channel keep coming up as error code 261412 every time i load it. This code comes up after you send the info
Error codes within that range usually refer to a communication problem with Nintendo's network. :1: Make sure your Wii has an internet connection, you can test this using the shopping channel, internet channel or by sending a Wii-mail to a freand. ::2: Go in to the setting panel and run a firmware (system) update to ensure you have the latest firmware. :::3: Try again at a less busy time of day, 15:00 on a week day is usually quiet. If you still have problems after a firmware (system) update message back. Nick. :)
Nov 06, 2008 | Computers & Internet
We get a communications error when receiving a fax from the HP 1050 fax
You need to update the firmware
You can get from the link below
HP firmware
On the software download page, select your Windows version.
Locate and select the firmware update.
Follow the directions to download and install the update
Oct 28, 2008 | Office Equipment & Supplies
Nuvi 250 NOT acquiring satellites
After talking to Garmin talk support, I had to send my unit out for repair. Apparently they could not repair mine, they send me another one ( It is not new) but it works. Luckily I was still under warranty otherwise I would have have lost my money
Mar 02, 2008 | Garmin nuvi 350 GPS Receiver
Konica Minolta
you can take the mannual from intravia.com
Sep 13, 2007 | Office Equipment & Supplies
Lexmark T640 Laser Printer Logo
172 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
