Question about Citizen CT-S2000 Printer
Alignment is off
It cuts off the 1st letters or numbers on the left edge.
    Problem Solver:
  • 10 Answers
Check your document to insure that all text is within the margins settings. You will most likely find that these settings are correct in which case you should check that you have correctly aligned the paper in the paper tray of your printer. One or the other of these should fix your problem.
Posted on Nov 19, 2013
Blade on Hitachi C12FCH mitre saw has begun to cut into left side of blade slot on turn table. Angle cuts (90,45,etc) still accurate. How do I realign blade run to avoid hitting turntable?
Realign fence to blade, must be 90 degrees, using a level for straight edge bring other fence co planed with aligned fence. . You saw will only cut as accurate as you set it up., I spent over 2 hours on my 12 inch to ensure that it was vertical, exactly 90 degrees and exactly 45 degree both left and right. I used engineer squares.
Apr 16, 2018 | Hitachi Saws
Guess I'm not too bright. Have a pack of GBC SelfsSeal Laminating Sheets, 9 x 12. Instructions say "Center item face sown on the clear non-adhesive." "Peel away the liner and...
It's not you, it's the instructions. They are just wrong and will not work as directed. However, I have found a way to use these sheets that works for me, but it is still not particulary easy.
Step 1) Lay the 1st sheet on a flat surface, adhesive side up. Pressing down on the small 1/2" strip of backing, peel away the large backing sheet exposing the adhesive. Holding the sheet you want to laminate face down and at an angle to the work surface, carefully align the material by "bumping" it up against the edge of the 1/2 strip. Once aligned, carefully and gradually lay the item onto the adhesive. Like I said, not particularly easy, but if you are careful, it will work.
Step 2) If you want to double laminate, which I usually do, the second laminate sheet seems easier to me. Leave the Step 1 laying flat on the work surface. Take a second lamination sheet and again, hold it down on a flat surface and peel away the large backing sheet, leaving the small 1/2" backing attached. Take this 2nd sheet and holding it over the 1st, face down and angled up from the work surface, align the 1/2" strips of both sheets together and again carefully lay the 2nd sheet over the first single-laminated item. The two 1/2" strips don't stick to one another allowing a bit more flexibility for alignment.
Press all of this together and work out any bubbles or wrinkles. Once that is done, pry the two sheets apart at the very edge to remove the two 1/2 strips.
Unless you are incredibly lucky the edges will never align 100%. I use a paper-cutter to trim off any irregularities after I finish laminating.
Apr 11, 2011 | Gbc Selfseal Letter-size Laminating Sheets...
We are using 8 1/2 x 11 letter size paper. When we print, the top of page is cut off. How do we correct the alignment?
Have you checked the top margin setting of your print job. It should be less than 1/4 inch. If set higher it may cut off the top of the page, before it's sent to the printer. The printer will not print anything within 1/4 inch of the edge of the page, by design.
Feb 01, 2011 | HP LaserJet 6p Printer
Can you adjust the edge erase area around the border of the copies printed out on the MFX 1430. I would like to reduce it,because it cuts off some of the letters and numbers
Unless someone has changed it(made it larger)...factory default is 2mm void at the edges and you can't make it any smaller than that.
Nov 28, 2010 | Muratec MFX-1430 Copier
Doesn't recognize paper when loaded
When loading the paper, the edge sensors can be a bit tricky.
Pull the paper through the main guide with the locking plate released. Guide the paper edge it's right along the blue (not over it, just along the left edge of the guide markings on the body of the unit). Pull the paper through and then guide it back so that the lead edge just barely shows up, below the small, black rollers in the main print area. Now lock it down and reboot the system.
Once the print head alignment has finished the unit will pull the paper through and then move it forward and back until it is properly aligned, then cut off any excess it detects.
You should now be able to print. Note: Please do not re-adjust the paper edge after this process is complete.
Aug 09, 2009 | HP DesignJet 1050c plus InkJet Printer
Hi, how do I find the 1st 2 letters in a cell and reference it to another. ie A1: 0209JJP001. I thus want to find "02" which is Feb (this would be a vlookup I assume). Therefore the 1st 2 letters...
To reference the first letters in a cell, use the left function. The syntax is =left(cell,#). So, to return the left two letters from cell A1, you use =left(a1,2). You can put that in a cell or incorporate it into some functions.
Jun 12, 2009 | Microsoft Excel for PC
Vista for canon pixma mp140
Here's the solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Colr prints showing plenty of lines
Here's a solution from Canon USA:
Hope this helps - fotobean.
White bands on color photo prints
I hope it helps!!!
Nov 25, 2008 | Canon PIXMA MP530 All-In-One InkJet...
PRINTER CUTS OFF RIGHT SIDE OF PAPER
First, on your computer desktop. left click on START. Next, left click on CONTROL PANEL, and left click on PRINTERS. Find your printer on the PRINTERS window, and RIGHT CLICK on the icon. From the drop-down menu, left click on PRINTING PREFERENCES. Use the settings to set up the printer for the paper size and orientation you want to use.Click APPLY , then OK buttons to apply any changes you make. If that does not help,check the side paper guides in the paper source you are using. If they are not against the paper on both sides, the paper will not align properly with the image. Move the guides snug but not tight against the paper. If the guides are too tight, paper may not feed. If moving the guides does not solve the problem, try loosening the guides and reposition the paper until the image is properly aligned. Then see in your owners manual if there is an adjustment called SIDE-TO-SIDE REGISTRATION, and follow the proceedure to adjust the side-to side paper alignment.
Jul 16, 2008 | Dell 3100cn Laser Printer
Citizen CT-S2000 Printer Logo
78 people viewed this question
Top Citizen Office Equipment & Supplies Experts
jay kaye
jay kaye
Roy May
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
